1SMB5921B-1SMB5956B
SMB / DO-214AA
FEATURES:
◆ ZENER impedance at low current is small
2.0±0.1
◆ High temperature soldering guaranteed:
3.5±0.15
◆ High reliability
250℃ / 10S / 9.5mm lead length at 5 lbs tension
4.4±0.15
2.3±0.2
MECHANICAL DATA:
◆ Case: Molded plastic
◆ Epoxy: UL94V-0 rate flame retardant
1.1±0.3
0.22±0.07
◆ Polarity: Color band denotes cathode
5.2±0.15
◆ Mounting position: Any
1.5WATT SURFACE MOUNTSILICON ZENER DIODES
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND CHARACTERISTICS
Rating at 25℃ ambient temperature unless otherwise specified.
Parameters
ZENER Current
Power Dissipation ( Note1 )Ta=70℃
Thermal Resistances ( Junction to Ambient ,Note1)
Operating Temperature Range
Storage Temperature Range
SYMBOL
VALUE
UNITS
IZ MAX
See table
mA
Pt
3.0
W
Rθ(ja)
28
℃/W
TJ
-50~+150
TSTG
-50~+175
NOTES :
1.
Thermal Resistance from Junction to terminal mounted on 5×5mm copper pad area.
www.slkormicro.com
1
1SMB5921B-1SMB5956B
ELECTRICAL CHARACTERISTICS ( at TA=25℃ unless otherwise noted )
TYPE
NUMBER
(Note 2)
1SMB5921B
1SMB5922B
1SMB5923B
1SMB5924B
1SMB5925B
1SMB5926B
1SMB5927B
1SMB5928B
1SMB5929B
1SMB5930B
1SMB5931B
1SMB5932B
1SMB5933B
1SMB5934B
1SMB5935B
1SMB5936B
1SMB5937B
1SMB5938B
1SMB5939B
1SMB5940B
1SMB5941B
1SMB5942B
1SMB5943B
1SMB5944B
1SMB5945B
1SMB5946B
1SMB5947B
1SMB5948B
1SMB5949B
1SMB5950B
1SMB5951B
1SMB5952B
1SMB5953B
1SMB5954B
1SMB5955B
1SMB5956B
Nominal
ZENER
Voltage
Test
Current
V Z@IZT
IZT
V
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
100
110
120
130
150
160
180
200
Maximum
Reverse Leakage
Current
Max ZENER Impedance
Z ZT @IZT
Z ZK @IZK
( Note 3 )
( Note 4 )
mA
Ω
55.1
50.0
45.7
41.2
37.5
34.1
31.2
28.8
25.0
23.4
20.8
18.7
17.0
15.6
13.9
12.5
11.4
10.4
9.6
8.7
8.0
7.3
6.7
6.0
5.5
5.0
4.6
4.1
3.7
3.4
3.1
2.9
2.5
2.3
2.1
1.9
2.5
3.0
3.5
4.0
4.5
5.5
6.5
7.0
9.0
10.0
12.0
14.0
17.5
19
23
26
33
38
45
53
67
70
86
100
120
140
160
200
250
300
380
450
600
700
900
1200
Maximum
DC ZENER
Current
of V(BR)
I ZM @50℃
I ZK
IR@VR
VR
Ω
mA
μA
V
mA
200
400
400
500
500
550
550
550
600
600
650
650
650
700
700
750
800
850
900
950
1000
1100
1300
1500
1700
2000
2500
3000
3100
4000
4500
5000
6000
6500
7000
8000
1.0
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
5.0
5.0
5.0
5.0
5.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.2
6.8
6.5
7.0
8.0
8.4
9.1
9.9
11.4
12.2
13.7
15.2
16.7
18.2
20.6
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.6
47.1
51.7
56.0
62.2
69.2
76.0
83.6
91.2
98.8
114.0
121.6
136.8
152.0
220
200
182
164
150
136
125
115
100
93
83
75
68
62
55
50
45
41
38
34
31
29
26
24
22
16
15
13
12
11
10
9
8
7
(Note 5 )
Note :
1.
2.
3.
4.
5.
VF=1.5V max. @ IF=200mA
TOLERANCE DESIGNATION Standard tolerance on nominal ZENER voltage is ±5%,
ZENER IMPEDANCE I ( ac rms ) = 10% Izt
ZENER KNEE IMPEDANCE I (ac rms ) = 10% Izk
MAXIMUM ZENER CURRENT The nominal Izm currents shown are applicable for devices having regulator voltages approximately
10% above the nominal Vz values shown. These values do not represent absolute limits. The actual steady state current-voltage
product must not exceed the power rating.
www.slkormicro.com
2
很抱歉,暂时无法提供与“1SMB5929B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42142
- 100+0.34064
- 300+0.30014
- 3000+0.25542
- 6000+0.23123
- 9000+0.21903
- 国内价格
- 5+0.26519
- 20+0.24180
- 100+0.21840
- 500+0.19500
- 1000+0.18408
- 2000+0.17628
