LM2903
LOW POWER DUAL VOLTAGE COMPARATORS
■ WIDE SINGLE SUPPLY VOLTAGE RANGE
OR DUAL SUPPLIES +2V TO +36V OR ±1V
TO ±18V
■ VERY LOW SUPPLY CURRENT (0.4mA)
INDEPENDENT OF SUPPLY VOLTAGE
(1mW/comparator at +5V)
■ LOW INPUT BIAS CURRENT: 25nA TYP
LM2903N
■ LOW INPUT OFFSET CURRENT: ±5nA TYP
DIP8
■ INPUT COMMON-MODE VOLTAGE RANGE
INCLUDES GROUND
■ LOW OUTPUT SATURATION VOLTAGE:
250mV TYP. (IO = 4mA)
■ DIFFERENTIAL INPUT VOLTAGE RANGE
LM2903
EQUAL TO THE SUPPLY VOLTAGE
SOP8
■ TTL, DTL, ECL, MOS, CMOS COMPATIBLE
OUTPUTS
DESCRIPTION
This device consists of two independent low
power voltage comparators designed specifically
to operate from a single supply over a wide range
of voltages. Operation from split power supplies is
also possible.
These comparators also have a unique
characteristic in that the input common-mode
voltage range includes ground even though
operated from a single power supply voltage.
www.slkormicro.com
1
LM2903P
TSSOP8
PIN CONNECTIONS (top view)
1OUT
VCC
1IN−
2OUT
1IN+
2IN−
GND
2IN+
LM2903
SCHEMATIC DIAGRAM (1/2 LM2903)
VCC+
3.5µA
100µA
3.5µA
100µA
Non-Inverting
Input
Vo
VCC-
VCC-
Inverting
Input
VCC-
ABSOLUTE MAXIMUM RATINGS
Symbol
Parameter
VCC
Supply Voltage
VID
Differential Input Voltage
VI
Input Voltage
Output Short-circuit to Ground
Power Dissipation 2)
Pd
1)
Unit
±18 to 36
V
±36
V
-0.3 to +36
V
Infinite
DIP8
SO8
TSSOP8
TJunction Junction Temperature
Tstg
Value
Storage Temperature Range
1250
710
625
mW
+150
°C
-65 to +150
°C
1.
Short-circuit from the output to Vcc+ can cause excessive heating and eventual destruction. The maximum output current is approximately 20mA,
independent of the magnitude of Vcc +
2.
Pd is calculated with T amb = +25°C, Tj = +150°C and R thja = 100°C/W for DIP8 package
= 175°C/W for SO8 package
= 200°C/W for TSSOP8 package
OPERATING CONDITIONS
Symbol
Parameter
Vicm
Common Mode Input Voltage Range
Toper
Operating Free-Air Temperature range
www.slkormicro.com
Value
2
Unit
0 to VCC -1.5
V
-40 to +125
°C
LM2903
ELECTRICAL CHARACTERISTICS
VCC+ = 5V, V cc- = GND, Tamb = 25°C (unless otherwise specified)
Symbol
Parameter
Typ.
Max.
Unit
VIO
Input Offset Voltage 1)
Tamb = +25°C
Tmin ≤ Tamb ≤ Tmax.
1
7
15
mV
IIO
Input Offset Current
Tamb = +25°C
Tmin ≤ Tamb ≤ Tmax.
5
50
150
nA
IIB
Input Bias Current 2)
Tamb = +25°C
Tmin ≤ Tamb ≤ Tmax.
25
250
400
nA
AVD
Large Signal Voltage Gain (Vcc = 15V,RL=15kΩ, Vo=1 to 11V)
ICC
Supply Current (all comparators)
VCC = 5V, no load
VCC = 30V, no load
VICM
VID
VOL
IOH
ISINK
25
Differential Input Voltage 4)
Low Level Output Voltage (Vid = -1V, Isink = 4mA)
Tamb = +25°C
Tmin ≤ Tamb ≤ Tmax
250
High Level Output Current (VCC =Vo =30V, Vid = 1V)
Tamb = +25°C
Tmin ≤ Tamb ≤ Tmax
Output Sink Current (Vid = -1V,Vo = 1.5V)
5)
200
0.4
1
Input Common Mode Voltage Range (Vcc= 30V) 3)
Tamb = +25°C
Tmin ≤ Tamb ≤ Tmax.
Small Signal Response Time
tREL
Large Signal Response Time 6)
TTL Input (Vref = +1.4 V, RL=5.1kΩ to VCC+)
Output Signal at 50% of final value
Output Signal at 95 % of final value
(RL = 5.1kΩ to VCC )
V/mV
1
2.5
mA
VCC+-1.5
VCC+-2
V
VCC+
V
400
700
mV
0.1
1
6
tRE
nA
µA
16
mΑ
1.3
µs
500
1
ns
µs
1.
At output switch point, VO ≈ 1.4V, RS = 0Ω with VCC+ from 5V to 30V, and over the full input common-mode range (0V to VCC+ –1.5V).
2.
The direction of the input current is out of the IC due to the PNP input stage. This current is essentially constant, independent of the state of the
output, so no loading charge exists on the reference of input lines
3.
The input common-mode voltage of either input signal voltage should not be allowed to go negative by more than 0.3V. The upper end of the
common-mode voltage range is VCC+ –1.5V, but either or both inputs can go to +30V without damage.
4.
Positive excursions of input voltage may exceed the power supply level. As long as the other voltage remains within the common-mode range, the
comparator will provide a proper output state.
The low input voltage state must not be less than –0.3V (or 0.3V below the negative power supply, if used)
5.
The response time specified is for a 100mV input step with 5mV overdrive.
6.
Maximum values are guaranteed by design & evaluation.
www.slkormicro.com
Min.
3
LM2903
SUPPLY CURRENT versus SUPPLY VOLTAGE
RESPONSE TIME FOR VARIOUS INPUT
OVERDRIVES - NEGATIVE TRANSITION
INPUT CURRENT versus SUPPLY VOLTAGE
OVERDRIVES - POSITIVE TRANSITION
OUTPUT SATURATION VOLTAGE versus
OUTPUT CURRENT
www.slkormicro.com
4
LM2903
TYPICAL APPLICATIONS
BASIC COMPARATOR
LOW FREQUENCY OP AMP
DRIVING CMOS
DRIVING TTL
TRANSDUCER AMPLIFIER
www.slkormicro.com
5
LM2903
LOW FREQUENCY OP AMP WITH OFFSET
ADJUST
ZERO CROSSING DETECTOR
(single power supply)
TWO-DECADE HIGH-FREQUENCY VCO
LIMIT COMPARATOR
CRYSTAL CONTROLLED OSCILLATOR
SPLIT-SUPPLY APPLICATIONS
COMPARATOR WITH A NEGATIVE
REFERENCE
www.slkormicro.com
6
很抱歉,暂时无法提供与“LM2903”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.93733
- 50+0.74964
- 500+0.56884
- 1000+0.56031
- 2500+0.50357
