ES2A-ES2J
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V
PINNING
Forward Current –2 A
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
1
Cathode
2
Anode
2
1
Top View
Marking Code: ES2A~ES2J
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES2A
ES2B
ES2C
ES2D
ES2E
ES2G
ES2J
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
50
A
Maximum Forward Voltage at 2 A
VF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
1.68
V
IR
5
100
μA
Cj
40
pF
t rr
35
ns
RθJA
60
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
www.slkormicro.com
1.25
1
1
ES2A-ES2J
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.0
300
2.5
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
40
Case Temperature (°C)
10
T J =25°C
1.0
ES2A~ES2D
ES2E/ES2G
ES2J
0.01
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.001
0.5
1.5
2.0
2.5
0.1
Instaneous Forward Voltage (V)
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.slkormicro.com
1.0
10
Reverse Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
100
Fig.5 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
0.1
80
60
% of PIV.VOLTS
2
100
ES2A-ES2J
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
b
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
b
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
0.2
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
0.05
max
87
181
106
205
12
63
59
7.9
min
75
157
91
185
6
51
35
2
UNIT
mm
mil
g
e
A
D
0.3
The recommended mounting pad size
1.8
(71)
ES2A
1.8
(71)
2.4
(94)
mm
Unit :
(mil)
www.slkormicro.com
12
Marking
Type number
1.8
(71)
a
3
Marking code
ES2A
ES2B
ES2B
ES2C
ES2C
ES2D
ES2D
ES2E
ES2E
ES2G
ES2G
ES2J
ES2J
很抱歉,暂时无法提供与“ES2G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07219
- 500+0.05716
- 2000+0.04880
- 4000+0.04381
- 24000+0.03947
- 50000+0.03707
- 国内价格
- 20+0.06617
- 200+0.06518
- 800+0.05239
