79L05
Three-terminal negative voltage regulator
SOT-89
Maximum output current IO: 0.1 A
Output voltage VO : -5 V
Continuous total dissipation
PD SOT-89 0.5 W (Ta= 25 ℃ )
3
1
2
1. GND 2. OUT
3. IN
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Symbol
Value
Units
Vi
-30
V
Operating Junction Temperature Range
TOPR
0~+125
Storage Temperature Range
TSTG
-55~+150
Parameter
Input Voltage
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JINCTION TEMPERATURE(VI=-10V,Io=40mA,Ci=0.33μF,Co=0.1μF, unless otherwise specified )
Parameter
Symbol
Test conditions
25℃
Output voltage
Vo
-7V≤V l≤-20V, Io=1mA~40mA
Io=1mA~70mA
Load Regulation
ΔVo
Line regulation
ΔVo
Quiescent Current
0-125℃
MIN
TYP
MAX
UNIT
-4.8
-5.0
-5.2
V
-4.75
-5.0
-5.25
V
-4.75
-5.0
-5.25
V
Io=1mA~100mA
25℃
mV
Io=1mA~40mA
25℃
10
30
mV
-7V≤V l≤-20V
25℃
15
150
mV
-8V≤V l≤-20V
25℃
12
100
mV
25℃
6
mA
Iq
ΔIq
-8V≤V l≤-20V
0-125℃
1.5
mA
ΔIq
1mA≤V l≤40mA
0-125℃
0.1
mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
25℃
Ripple Rejection
RR
-8V≤V l≤-18V,f=120Hz
Dropout Voltage
Vd
Quiescent Current Change
TYPICAL APPLICATION
Vi
0-125℃
25℃
3
2
41
40
uV
49
dB
1.7
V
Vo
UTC
Ci
1
C0
0.1μF
0.33μF
Note : Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
Possible to the regulators.
www.slkormicro.com
1
79L05
TypicalCharacteristics
www.slkormicro.com
2
79L05
■ SOT-89
B
D
A
bp3
E
1
2
HE
Lp
3
c
bp2
w M B
bp1
e1
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
www.slkormicro.com
UNIT
A
bp1
bp2
bp3
c
D
E
e
e1
HE
Lp
w
mm
1.6
1.4
0.48
0.35
0.53
0.40
1.8
1.4
0.44
0.23
4.6
4.4
2.6
2.4
3.0
1.5
4.25
3.75
1.2
0.8
0.13
3
很抱歉,暂时无法提供与“79L05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42801
- 100+0.34506
- 300+0.30359
- 1000+0.25769
- 5000+0.23285
- 10000+0.22032
- 国内价格 香港价格
- 1+0.883841+0.11457
- 10+0.3439510+0.04459
- 25+0.2960425+0.03838
- 100+0.24482100+0.03174
- 250+0.22052250+0.02859
- 500+0.20605500+0.02671
- 国内价格
- 10+0.39234
- 100+0.31631
- 200+0.31157
- 400+0.27829
- 1000+0.23621
- 国内价格 香港价格
- 1000+0.194091000+0.02516
- 2000+0.184182000+0.02388
- 3000+0.179263000+0.02324
- 5000+0.173785000+0.02253
- 7000+0.170577000+0.02211
- 10000+0.1675110000+0.02172
