13001
13001
    SLKOR(萨科微)
    SOT-23
    三极管 NPN Ic=200mA Vceo=400V hfe=10~70 P=750mW SOT23
13001 数据手册
13001 General Purpose Transistors NPN Silicon Product Summary ● VCEO ● Ic ● PC 400V 0.2A 750mW SOT-23 ■ MAXIMUM RATINGS (TA=25℃unless otherwise noted) Parameter Symbol Limit Unit Collector-Base Voltage VCBO 600 V Collector-Emitter Voltage VCEO 400 V Emitter-Base Voltage VEBO 7 V Collector Current -Continuous IC 0.2 A Power Dissipation PC 0.75 W Junction Temperature TJ 150 ℃ Storage Temperature TSTG -55~+150 ℃ www.slkormicro.com 1 13001 ■ Electrical Characteristics (TJ=25℃ unless otherwise noted) Parameter Symbol Testconditons Min Collecto- base breakdown voltage VCBO Ic=0.1mA, IE=0 600 Collector- emitter breakdown voltage VCEO Ic=1mA, IB=0 400 Emitter - base breakdown voltage VEBO IE=0.1mA, IC=0 Typ Max V 7 Base-emitter voltage VBE IE=100mA 1.1 Collector cut-off current ICBO VCB=600V , IE=0 100 Collector cut-off current ICEO VCE=400V , IB=0 100 Emitter cut-off current IEBO VEB=7V , IC=0 100 Collector-emitter saturation voltage VCE(sat) IC=100mA, IB=20mA 0.5 Base - emitter saturation voltage VBE(sat) IC=100mA, IB=20mA 1.2 hFE(1) VCE=20V, IC=20mA hFE(2) VCE=10V, IC=0.25mA DC current gain Storage time ts Fall time tf Transition frequency fT www.slkormicro.com 10 2 μA V 70 5 1.5 IC=50mA, IB1=-IB2=5mA, VCC=45V VCE= 20V, IC=20mA,f=1MHz Unit 0.3 8 μs MHz www.slkormicro.com Capacitance,COB (pF) Saturation Voltage,VBE(SAT),VCE(SAT) DC Current Gain,hFE Collecter Current,IC (mA) 13001 ■ Typical Performance Characteristics 3 13001 ■ SOT-23 Package information ■ SOT-23 Suggested Pad Layout www.slkormicro.com 4
13001 价格&库存
很抱歉,暂时无法提供与“13001”相匹配的价格&库存,您可以联系我们找货
  • 50+0.13028
  • 600+0.08870
  • 1200+0.08737
  • 3000+0.07633
库存:2320
13001
  • 1+1.057161+0.13727
  • 10+0.6535210+0.08486
  • 100+0.40268100+0.05229
  • 500+0.29018500+0.03768
  • 1000+0.253441000+0.03291
库存:2845
13001
  • 3000+0.206463000+0.02681
  • 6000+0.182686000+0.02372
  • 9000+0.170529000+0.02214
  • 15000+0.1568315000+0.02037
  • 21000+0.1487021000+0.01931
  • 30000+0.1408130000+0.01829
库存:2845
13001
    • 20+0.14213
    • 200+0.11297
    • 600+0.09677
    • 3000+0.08327
    • 9000+0.07485
    • 21000+0.07020
    库存:1691
