2N7002T
2N7002T
    SLKOR(萨科微)
    SOT-523-3
    N沟道 漏源电压(Vdss):60V 连续漏极电流(Id):300mA 功率(Pd):350mW
2N7002T 数据手册
2N7002T N-Channel Enhancement Mode Field Effect Transistor Product Summary ● VDS ● ID ● RDS(ON)( at VGS=10V) ● RDS(ON)( at VGS=4.5V) 60V 300mA <2.5ohm <3.0ohm General Description ● Trench Power MV MOSFET technology ● Voltage controlled small signal switch ● Low input Capacitance ● Fast Switching Speed ● Low Input / Output Leakage SOT-523 Applications ● Battery operated systems ● Solid-state relays ● Direct logic-level interface:TTL/CMOS ■ Absolute Maximum Ratings (TA=25℃unless otherwise noted) Parameter Symbol Limit Drain-source Voltage VDS 60 V Gate-source Voltage VGS ±20 V Drain Current ID 300 mA Pulsed Drain Current A IDM 1.5 A Total Power Dissipation @ TA=25℃ PD 350 mW RθJA 357 ℃/ W TJ ,TSTG -55~+150 ℃ Thermal Resistance Junction-to-Ambient @ Steady State B Junction and Storage Temperature Range www.slkormicro.com 1 Unit 2N7002T ■ Electrical Characteristics (TJ=25℃ unless otherwise noted) Parameter Symbol Conditions Min Typ Max Units Drain-Source Breakdown Voltage BVDSS VGS= 0V, ID=250μA 60 Zero Gate Voltage Drain Current IDSS VDS=60V,VGS=0V 1 μA Gate-Body Leakage Current IGSS VGS= ±20V, VDS=0V ±100 nA Gate Threshold Voltage VGS(th) VDS= VGS, ID=250μA 1.5 3.0 V VGS= 10V, ID=300mA 1.2 2.5 Static Drain-Source On-Resistance RDS(ON) VGS= 4.5V, ID=150mA 1.5 3.0 Static Parameter Diode Forward Voltage Maximum Body-Diode Continuous Current 0.8 V Ω VSD IS=300mA,VGS=0V IS 1.2 V 300 mA Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 18 VDS=60V,VGS=0V,f=1MHZ 12 pF 7 Switching Parameters Total Gate Charge Turn-on Delay Time Qg VGS=10V,VDS=60V,ID=0.3A tD(on) 1.7 Reverse recovery Time tD(off) trr ns 17 VGS=0V,IS=300mA,VR=25V, dIS/dt=100A/μs A. Pulse Test: Pulse Width≤300us,Duty cycle ≤2%. B. Device mounted on FR-4 PCB, 1 inch x 0.85 inch x 0.062 inch. www.slkormicro.com nC 5 VGS=10V,VDD=30V, ID=300mA, RGEN=6Ω Turn-off Delay Time 2.4 2 30 ns 2N7002T ■ Typical Performance Characteristics Figure1. Output Characteristics Figure2. Transfer Characteristics Figure3. Capacitance Characteristics Figure4. Gate Charge Figure5. Drain-Source on Resistance www.slkormicro.com Figure6. Drain-Source on Resistance 3 2N7002T Figure7. Safe Operation Area Figure8. Switching wave ■SOT-523 Package Outline Dimensions www.slkormicro.com 4
2N7002T 价格&库存
很抱歉,暂时无法提供与“2N7002T”相匹配的价格&库存,您可以联系我们找货
