RCLAMP0502B
RCLAMP0502B
    SLKOR(萨科微)
    SOT523
    ESD保护 VRWM=5V,VBR=7V Ppp=45W SOT523
RCLAMP0502B 数据手册
RCLAMP0502B »Features ■ 45 Watts peak pulse power (tp = 8/20μs) ■ Unidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ Low capacitance (Cj=0.7 pF typ.) ■ Protection two data lines ■ IEC 61000-4-2 ±15V contact ±15kV air ■ IEC 61000-4-4 (EFT) 40A(5/50ns) ■ IEC 61000-4-5 (Lightning) 3.5A (8/20μs) »Mechanical Data »Applications ■ Dataline ■ SOT-523 package ■ Automatic Teller Machines ■ Molding compound flammability rating: UL 94V-0 ■ Net works ■ Packaging: Tape and Reel ■ Power line ■ RoHS/WEEE Compliant »Schematic & PIN Configuration 1 1 3 3 2 2 SOT-523 (Top View) www.slkormicro.com 1 RCLAMP0502B »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 45 Watts Peak Pulse Current ( tp =8/20μs )(note1) Ipp 3.5 A VESD 15 15 kV Lead SolderingTemperature TL 260(10seconds) ℃ JunctionTemperature TJ -55 to + 125 ℃ StorageTemperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2(Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-OffVoltage Conditions Min Typical Max Units 5 V 7 8 V 0.5 1 μA 3.5 A VRWM VBR IT=1mA Reverse LeakageCurrent IR VRWM=5V,T=25℃ Peak PulseCurrent IPP tp =8/20μs Clamping Voltage VC IPP=3.5A,tp=8/20μs 12 17 V JunctionCapacitance Cj VR = 0V, f =1MHz 0.7 0.8 pF Reverse BreakdownVoltage 6 »Electrical Parameters (TA = 25°C unless otherwisenoted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP V RW M IR V BR IT I IF Working Peak Reverse Voltage VC VBR VRWM Maximum Reverse Leakage Current @ V RW M IR V F IT Breakdown Voltage @ IT Test Current IPP www.slkormicro.com 2 V RCLAMP0502B »TypicalCharacteristics Figure 2: Power Derating Curve 110 10 100 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 1 45w 8/20µswaveform 0.1 0.010.1 1 10 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs Figure3: Pulse Waveform 90 Percent Ipp 80 e-1 50 40 td=Ipp/2 20 75 100 125 150 18 Clamping Voltage–VC (V) 100 30 50 Ambient Temperature - TA (℃) 20 Waveform Paramters tr=8µs td=20µs 60 25 Figure 4: Clamping Voltage vs.Ipp 110 70 0 16 14 12 Test Waveform Paramters tr=8µs td=20µs 10 8 6 4 10 2 0 0 5 10 www.slkormicro.com 15 Time (µs) 20 25 30 0 1 2 3 4 Peak Pulse Current–IPP (A) 3 5 6 RCLAMP0502B »Outline Drawing – SOT-523 b1 Dimensions D e1 Symbol θ E1 c L b2 L1 E A1 e A Inches A MIN 0.700 MAX 0.900 MIN 0.028 MAX 0.035 A1 0.000 0.100 0.000 0.004 A2 0.700 0.800 0.028 0.031 b1 0.150 0.250 0.006 0.010 b2 0.250 0.325 0.010 0.013 c 0.100 0.200 0.004 0.008 D 1.500 1.700 0.059 0.067 E 0.750 0.850 0.030 0.033 E1 1.450 1.750 0.057 0.069 e A2 MillImeter e1 0.950 BSC 0.900 1.100 0.037 BSC 0.035 0.043 L L1 0.300 0.028 0.500 0.440 0.012 0.011 0.020 0.017 θ 0 8○ 0 8○ »Marking »Ordering information Order code RCLAMP0502B www.slkormicro.com Package SOT-523 Base qty 3k 4 Delivery mode Tape and reel
RCLAMP0502B 价格&库存
很抱歉,暂时无法提供与“RCLAMP0502B”相匹配的价格&库存,您可以联系我们找货
RCLAMP0502B
  • 1+0.48950
  • 200+0.31570
  • 1500+0.27500
  • 3000+0.24310
库存:2210
RCLAMP0502B
库存:6339
RCLAMP0502B
  • 5+0.68160
  • 50+0.57380
  • 150+0.52020
  • 500+0.47990
  • 3000+0.41510
  • 6000+0.39900
库存:6339
RCLAMP0502B
  • 10+0.63051
  • 100+0.53119
  • 600+0.44429
  • 1200+0.43763
库存:1095
