BAS316
Ƶ Switching Diodes
2
Ƶ Features
ƽ Fast Switching Speed
1.Cathode
2.Anode
1
ƽ For General Purpose Switching Applications.
■ Simplified outline(SOD-323)
ƽ High Conductance
ƽ Surface Mount Package Ideally Suited for Automatic Insertion
Top View
Ƶ Absolute Maximum Ratings Ta = 25ć
Symbol
Rating
Reverse Voltage
VRM
100
Peak Repetitive Peak Reverse Voltage
VRRM
Working Peak Reverse Voltage
VRWM
Parameter
DC Blocking Voltage
100
Unit
V
VR
RMS Reverse Voltage
VR(RMS)
71
Average Rectified Output Current
IO
150
Forward Continuous Current
IFM
300
Peak Forward Surge Current @ t=1us
2
IFSM
@ t =1s
mA
A
1
Power Dissipation
Thermal Resistance Junction to Ambient
Junction Temperature
Storage Temperature range
Pd
500
mW
R©JA
250
ć/W
TJ
150
Tstg
-55 to 150
ć
Ƶ Electrical Characteristics Ta = 25ć
Parameter
Reverse breakdown voltage
Forward voltage
Reverse voltage leakage current
Symbol
Test Conditions
Min
Typ
Max
Unit
VR
IR= 100 uA
VF1
IF= 1mA
0.715
VF2
IF= 10 mA
0.855
VF3
IF= 50 mA
1
VF4
IF= 150 mA
1.25
IR1
VR= 75 V
1
uA
100
V
IR2
VR=20 V
25
nA
Junction capacitance
Cj
VR= 0 V, f= 1 MHz
2
pF
Reverse recovery time
trr
IF=IR=10mA,Irr=0.1xIR, RL=100ȍ
4
ns
www.slkormicro.com
1
BAS316
Ƶ Typical Characterisitics
Forward
(mA)
1000
Characteristics
REVERSE CURRENT IR
C
o
FORWARD CURRENT
Ta
=2
5
Ta
=1
00
o
IF
C
(nA)
100
10
1
0.1
0.01
0.0
Reverse
10000
o
Ta=100 C
1000
100
o
Ta=25 C
10
1
0.4
0.8
1.2
FORWARD VOLTAGE
VF
60
REVERSE VOLTAGE
(V)
80
VR
100
(V)
Power Derating Curve
Capacitance Characteristics
1.6
600
(mW)
Ta=25
f=1MHz
PD
1.4
1.2
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Characteristics
1.0
0.8
0.6
500
400
300
200
100
8
12
REVERSE VOLTAGE
www.slkormicro.com
16
VR
50
75
100
AMBIENT TEMPERATURE
(V)
2
125
Ta
150
BAS316
■ SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
mil
■ The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.slkormicro.com
3
8
很抱歉,暂时无法提供与“BAS316”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13382
- 500+0.10584
- 3000+0.08921
- 6000+0.07992
- 24000+0.07182
- 51000+0.06740
- 国内价格
- 20+0.12266
- 300+0.09702
- 1200+0.09556
- 3000+0.08177
