F1M
F1M
    SLKOR(萨科微)
    SMF(SOD-123FL)
    快恢复二极管 VRRM=1KV If=1A VF=1.3V CJ=15pF trr=500ns SOD123FL
F1M 数据手册
F1A-F1M SUFACE MOUNT FAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0Ampere SOD-123FL FEATURES Cathode Band Top View 1.8± 0.1 1.0±0.2 Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 250 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.3± 0.15 0.10-0.30 2.8±0.1 0.6±0.25 MECHANICAL DATA Case : JEDEC SOD-123FL molded plastic body over passivated chip Terminals : Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity : Color band denotes cathode end Mounting Position : Any Weight :0.0007 ounce, 0.02 grams 3.7±0.2 Dimensions in millimeters MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. PARAMETERS Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TA=65 C (NOTE 1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) TL=25 C Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=125 C Maximum reverse recovery time (NOTE 2) SYMBOLS VRRM VRMS VDC F1B F1A F1G F1J F1K F1M UNITS 1000 700 1000 VOLTS VOLTS VOLTS 50 100 200 400 600 800 35 50 70 100 140 200 280 400 420 600 560 800 I(AV) 1.0 Amp IFSM 25.0 Amps VF 1.3 Volts IR 5.0 50.0 µA trr 250 150 Typical junction capacitance (NOTE 3) CJ Operating junction and storage temperature range TJ,TSTG 15 -50 to +150 Note: 1.Averaged over any 20ms period. 2.Measured with IF=0.5A, IR=1A, Irr=0.25A. 3.Measured at 1MHz and applied reverse voltage of 4.0V D.C. www.slkormicro.com F1D 1 500 ns pF C F1A-F1M www.slkormicro.com 2
很抱歉,暂时无法提供与“F1M”相匹配的价格&库存,您可以联系我们找货
F1M
  • 5+0.04080
  • 20+0.03720
  • 100+0.03360
  • 500+0.03000
  • 1000+0.02832
  • 2000+0.02712
F1M
    • 1+0.05070
    • 100+0.04880
    库存:50
