2N5551
2N5551
    SLKOR(萨科微)
    TO92-3
    通用三极管 TO92 PNP VCEO=160V Ic=600mA
2N5551 数据手册
2N5551 TO-92 Plastic-Encapsulate Transistors Equivalent Circuit FEATURES z General Purpose Switching Application z PNP Transistors TO – 92 1. EMITTER 2. BASE 3. COLLECTOR MAXIMUM RATINGS (Ta=25 unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 180 V VCEO Collector-Emitter Voltage 160 V V EBO Emitter-Base Voltage 6 V IC Collector Current 0.6 A PC Collector Power Dissipation 625 mW Thermal Resistance From Junction To Ambient 200  /W Tj Junction Temperature 150  T stg Storage Temperature R ș JA www.slkormicro.com -55~+150  1  2N5551    Ta =25  unless otherwise specified Parameter Collector-base breakdown voltage Symbol V(BR)CBO * Collector-emitter breakdown voltage V(BR)CEO Emitter-base breakdown voltage V(BR)EBO Test conditions Min Typ Max Unit IC=100μA,IE=0 180 V IC=1mA,IB=0 160 V IE=10μA,IC=0 6 V Collector cut-off current ICBO VCB=120V,IE=0 50 nA Emitter cut-off current IEBO VEB=4V,IC=0 50 nA hFE(1) VCE=5V, IC=1mA 80 hFE(2) VCE=5V, IC=10mA 80 hFE(3) VCE=5V, IC=50mA 50 VCE(sat)˄1˅ IC=10mA,IB=1mA 0.15 V VCE(sat)˄2˅ IC=50mA,IB=5mA 0.2 V VBE (sat)˄1˅ IC=10mA,IB=1mA 1 V VBE (sat)˄2˅ IC=50mA,IB=5mA 1 V DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage 300 Collector output capacitance Cob VCB=10V,IE=0, f=1MHz 6 pF Emitter input capacitance Cib VBE=0.5V,IC=0, f=1MHz 20 pF Transition frequency fT VCE=10V,IC=10mA, f=100MHz 300 MHz *Pulse test: pulse width 300s, duty cycle 2.0%. www.slkormicro.com 2 100 2N5551 Typical Characteristics Static Characteristic 18 80uA 60uA 50uA 9 40uA 6 30uA 0 2 4 6 8 COLLECTOR-EMITTER VOLTAGE VBEsat —— 1.0 VCE 10 10 12 (V) IC COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (V) 0.6 Ta=100ć 0.4 10 COLLECTOR CURRENT VBE 200 —— 100 IC 100 200 Ta=100ć Ta=25ć 1 10 COLLECTOR CURRENT Cob / Cib 100 —— IC (mA) VCB / VEB f=1MHz IE=0 / IC=0 C Ta=100ć Ta=25ć Cib (pF) IC (mA) 200 IC COMMON EMITTER VCE=5V 100 100 (mA) =10 (mA) IC IC 0.1 0.01 200 CAPACITANCE BASE-EMITTER SATURATION VOLTAGE VBEsat (V) Ta=25ć 1 10 VCEsat —— 0.3 0.8 0.2 0.1 1 COLLECTOR CURRENT =10 COLLECTOR CURRENT Ta=25ć 100 IB=20uA 3 0 Ta=100ć hFE 70uA 12 COMMON EMITTER VCE=5V COMMON EMITTER Ta=25ć DC CURRENT GAIN COLLECTOR CURRENT IC (mA) 90uA 15 hFE —— IC 500 Ta=25ć 10 1 0.2 0.4 0.6 BASE-EMITTER VOLTAGE fT 150 —— 0.8 Cob 1 0.1 1.0 VBE(V) 10 IC 1 REVERSE VOLTAGE PC 750 —— V (V) 10 20 Ta VCE=10V COLLECTOR POWER DISSIPATION PC (mW) TRANSITION FREQUENCY fT (MHz) Ta=25ć 100 50 1 10 3 COLLECTOR CURRENT www.slkormicro.com IC 20 625 500 375 250 125 0 30 0 25 50 75 AMBIENT TEMPERATURE (mA) 3 100 Ta 125 (ć ) 150 2N5551 $%&'(")*$+  A A1 b c D D1 E e e1 L  h $%&'+**,(, + www.slkormicro.com 4 ! "#     3.300 3.700 0.130 0.146 1.100 1.400 0.043 0.055 0.380 0.550 0.015 0.022 0.360 0.510 0.014 0.020 4. 4.700 3.430 0.135 4.300 4.700 0.169 0.185 1.270 TYP 0.050 TYP 2.440 2.640 0.096 0.104 14.100 14.500 0.555 0.571 1.600 0.063 0.000 0.380 0.000 0.015
2N5551 价格&库存
很抱歉,暂时无法提供与“2N5551”相匹配的价格&库存,您可以联系我们找货
2N5551
  • 50+0.06120
  • 500+0.05760
  • 2000+0.05040
  • 5000+0.04680
  • 15000+0.04320
  • 30000+0.04140
