JK-SMD0603-004 PPTC DEVICES
Edition:A0
Part Number:Q/JKTD-24-004
Page No: 1 OF 4
Terminal pad materials :Tin-Plated Nickle-copper
Terminal pad solderability : Meets EIA specification
RS 186-9E and ANSI/J-STD-002 Category 3.
Marking : Part identification 一 =004
Table1 :DIMENTION(Unit : mm)
Marki
Model
JK-SMD0603-004
一
A
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max
Min.
Max.
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.40
Table2 :PERFORMANCE RATINGS:
Model
Marking
Vmax
(Vdc)
JK-SMD0603-004
一
24.0
Imax
(A)
Ihold
@25℃
(A)
40
0.04
Itrip
@25℃
(A)
Pd
Typ
(W)
0.12
0.50
Maximum
Time To Trip
Resistance
Current
(A)
Time
(Sec)
R1min
(Ω)
R1max
(Ω)
0.2
1.00
4.0
45.000
Table3:Test Conditons and Standards
Test Conditon
Item
Initial Resistance
IH
Ttrip
.trip
Trip endurance
Operating Temperature:-40℃ TO
Packaging:Bulk ,5000pcs per bag
25℃
25℃,0.04A,60min
25℃,0.2A
24V,40A,60min
4.00~45.000Ω
No Trip
≤1.0S
No arcing or burning
85℃
SHENZHEN JINRUI ELECTRONIC MATERIAL CO.,LTD
INDUSTRY PARK
Standard
6 F DISTRICT NO. 3000046 BLDG Hi-Tech SCIENCE &
SHANGKENG COMMUNITY GUANLAN STREET BAOAN SHENZHEN
TEL:0755-26546327
26584158
Web Site:www.jkpptc.com
FAX: 0755-26546562
E-mail:customer@jkpptc.com
Edition:A0
Page No: 2 OF 4
Solder reflow conditions
● Recommended reflow methods: IR, vapor phase
oven, hot air oven, N2 environment for lead-free.
● Devices are not designed to be wave soldered to
the bottom side of the board.
● Recommended maximum paste thickness is
0.25mm (0.010inch).
● Devices can be cleaned using standard industry
methods and solvents.
● Soldering temprature profile meets RoHs leadfree
process.
Notes: If reflow temperatures exceed the recommended profile, devices may not meet the
performance requirements
INDUSTRY PARK
TEL:0755-26546327
26584158
FAX: 0755-26546562
Edition:A0
Page No: 3 OF 4
Recommended pad layout (mm)
INDUSTRY PARK
TEL:0755-26546327
26584158
FAX: 0755-26546562
Edition:A0
Page No: 4 OF 4
WARNING
· Use PPTC beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and
flame.
· PPTC are intended for protection against occasional over current or over temperature fault conditions and should not be
used when repeated fault conditions or prolonged trip events are anticipated.
· Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended
electronic, thermal, and mechanical procedures for electronic components.
· Use PPTC with a large inductance in circuit will generate a circuit voltage (L di/dt) above the rated voltage of the PPTC.
· Avoid impact PPTC device its thermal expansion like placed under pressure or installed in limited space.
· Contamination of the PPTC material with certain silicon based oils or some aggressive solvents can adversely impact the
performance of the devices.PPTC SMD can be cleaned by standard methods.
· Requests that customers comply with our recommended solder pad layouts and recommended reflow profile. Improper
board layouts or reflow profilecould negatively impact solderability performance of our devices.
INDUSTRY PARK
TEL:0755-26546327
26584158
FAX: 0755-26546562
很抱歉,暂时无法提供与“JK-SMD0603-004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18922
- 200+0.17172
- 600+0.16200
- 国内价格
- 20+0.17345
- 500+0.14850
- 2000+0.14702
