S1M
S1M
    SLKOR(萨科微)
    SMA(DO-214AC)
    表面安装通用硅整流器 反向电压-50至1000 V 正向电流-1 A
S1M 数据手册
S1A-S1M Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 1 A FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives 1 Cathode 2 Anode 2 1 Top View Marking Code: S1A~S1M Simplified outline SMA and symbol MECHANICAL DATA • Case: SMA • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S1A S1B S1D S1G S1J S1K S1M Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 30 A Maximum Instantaneous Forward Voltage at 1 A VF 1.1 V IR 5 50 μA Cj 15 pF RθJA 75 °C/W T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance Typical Thermal Resistance (1) (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.slkormicro.com 1 S1A-S1M Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Fig.1 Forward Current Derating Curve Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Junction Capacitance ( pF) TJ = 2 5° C 00 =1 TJ =1 25 °C °C 0.5 TJ Instaneous Forward Current (A) 1.0 0.9 0.2 0.7 1.0 1.1 100 120 140 T J =25°C 10 40 35 30 25 20 15 10 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles www.slkormicro.com 1.0 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 80 100 0.1 Instaneous Forward Voltage (V) 00 60 1 0.1 0.6 05 40 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 0.8 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 2 100 S1A-S1M PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a b VM e A HE g e E A D E HE c e g b max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 0.2 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 0.05 max 87 181 106 205 12 63 59 7.9 min 75 157 91 185 6 51 35 2 UNIT mm mil g e A D 0.3 The recommended mounting pad size mm Unit : (mil) www.slkormicro.com Marking code S1A S1A S1B S1B S1D S1D S1G S1G S1J S1J S1K S1K S1M S1M 1.8 (71) 1.8 (71) 2.4 (94) 12 Marking Type number 1.8 (71) a 3
很抱歉,暂时无法提供与“S1M”相匹配的价格&库存,您可以联系我们找货
S1M
S1M
库存:4698
