RCLAMP0524P
4 Channel Ultra-Low Capacitance ESD Protection Diode
1.
Features
Ultra-Low capacitance:0.5pF(typ.)
Reverse stand-off voltage:5V
IEC 61000-4-2 (Air): ±20KV
2.
Pin Description
4.
Schematic Diagram
IEC 61000-4-2 (Contact): ±15KV
3.
Applications
USB 3.0, USB 2.0
HDMI 1.3/1.4, Display Port 1.3, eSATA
Unified Display Interface (UDI)
Digital Visual Interface (DVI)
High speed serial interfaces
Top View
5.
6.
Order Information
Type
Package
Size (mm)
Delivery Form
Delivery Quantity
RCLAMP0524P
DFN2510
2.50x1.00x0.50
7” T&R
3,000
Limiting Values(TA = 25 °C, unless otherwise specified)
Symbol
Parameter
VESD
Electrostatic Discharge Voltage
IPPM
Rated Peak Pulse Current
Conditions
Min
Max
Unit
IEC 61000-4-2; Contact Discharge
±15
kV
IEC 61000-4-2; Air Discharge
±20
kV
tP = 8/20 µs
5
A
TA
Ambient Temperature Range
-55
125
Tstg
Storage Temperature Range
-55
150
www.slkormicro.com
1
RCLAMP0524P
7.
Electrical Characteristics(TA = 25 °C unless otherwise specified)
Symbol
VRWM
VBR
IR
Parameter
Conditions
Reverse Working Voltage
Min
Typ.
Max
Unit
TA = 25 °C
5
V
Breakdown Voltage
IR = 1 mA; TA = 25 °C
6
V
Reverse Leakage Current
VRWM = 5V; TA = 25 °C
1
µA
8.5
12
V
12
16
V
VR = 0V, f = 1 MHz,I/O to I/O
0.3
0.4
pF
VR = 0V, f = 1 MHz, I/O to GND
0.5
0.8
pF
IPP=1A,tP=8/20µs, Any I/O to
VC
Clamping Voltage
GND , Positive
IPP=5A,tP=8/20µs, Any I/O to
GND , Positive
CL
8.
Junction Capacitance
Typical Characteristics
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
Fig.3 Pulse Waveform-8/20μs
Fig.4 Pulse Waveform-ESD(IEC61000-4-2)
www.slkormicro.com
2
RCLAMP0524P
9.
Package Dimension
DFN2510 Package Outline
Symbol
A
A1
b
b1
b2
c
D
e
Nd
E
L
L1
L2
h
R
www.slkormicro.com
Dimensions in millimeters
Min
Nom
Max
0.45
0.15
0.35
0.20
0.10
2.45
0.50
0.02
0.20
0.40
0.25
0.15
2.50
0.50BSC
2.00 BSC
1.00
0.40
0.075 REF
0.05 REF
0.12
0.10
0.55
0.05
0.25
0.45
0.30
0.20
2.55
0.95
0.35
0.08
0.05
3
1.05
0.45
0.15
0.15
RCLAMP0524P
10.
Soldering Parameters
tp
TP
Critical Zone
TL to TP
Ramp-up
TL
tL
Temperature
TS(max)
Ramp-down
Preheat
TS(min)
ts
25
time to peak temperatue
(t 25℃ to peak)
Reflow Condition
Pre-heat
Time
Pb-Free Assembly
-Temperature Min (Ts(min))
+150°C
-Temperature Max(Ts(max))
+200°C
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3°C/sec. Max
Ts(max) to TL - Ramp-up Rate
3°C/sec. Max
Reflow
-Temperature(TL)(Liquid us)
+217°C
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)°C
Time within 5°C of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6°C/sec. Max
xTime 25°C to Peak Temp (TP)
8 min. Max
Do not exceed
+260°C
www.slkormicro.com
4
很抱歉,暂时无法提供与“RCLAMP0524P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30964
- 100+0.25262
- 300+0.22410
- 3000+0.18015
- 6000+0.16308
- 9000+0.15444
- 国内价格
- 10+0.28383
- 100+0.23156
- 600+0.20542
- 1200+0.20234
- 3000+0.16513
