BAT54CT
BAT54CT
    SLKOR(萨科微)
    SOT-523
    肖特基二极管 30V 200mA SOT-523
BAT54CT 数据手册
BAT54CT Surface Mount Schottky Barrier Diode Features • Low forward voltage BAT54T 3 BAT54AT 3 Applications • Ultra high-speed switching • Voltage clamping • Protection circuits 1 1 2 BAT54CT 3 2 1 Absolute Maximum Ratings (Ta = 25 OC) Parameter 2 BAT54ST 3 1 BAT54T Marking Code: L1 BAT54AT Marking Code: L2 BAT54CT Marking Code: L3 BAT54ST Marking Code: L4 2 Symbol Value Unit VRRM 30 V Reverse Voltage VR 30 V Forward Current IF(AV) 200 mA Repetitive Peak Forward Current IFRM 300 mA Peak Forward Surge Current (tp = 10 ms) IFSM 600 mA Total Power Dissipation Ptot 150 mW Thermal Resistance from Junction Ambient RθJA 667 Tj 125 O Tstg - 65 to + 150 O Peak Repetitive Reverse Voltage Junction Temperature Storage Temperature Range C/W O C C Characteristics at Ta = 25 OC Parameter Symbol Forward Voltage at IF = 0.1 mA at IF = 1 mA at IF = 10 mA at IF = 30 mA at IF = 100 mA Max. - 240 320 400 500 1000 V(BR)R 30 - V IR - 2 µA Ctot - 10 pF trr - 5 ns VF Reverse Breakdown Voltage at IR = 100 μA Reverse Current at VR = 25 V Total Capacitance at VR = 1 V, f = 1 MHz Reverse Recovery Time at IF = 10 mA through IR = 10 mA to IR = 1 mA, RL = 100 Ω www.slkormicro.com Min. 1 Unit mV BAT54CT www.slkormicro.com 2
BAT54CT 价格&库存
很抱歉,暂时无法提供与“BAT54CT”相匹配的价格&库存,您可以联系我们找货
BAT54CT
  • 20+0.23091
  • 200+0.18544
  • 600+0.16017
  • 3000+0.11459
  • 9000+0.10152
  • 21000+0.09440
库存:543
BAT54CT
  • 20+0.21166
  • 300+0.16998
  • 1200+0.14682
  • 3000+0.10504
库存:2226
