DS26W
DS26W
    SLKOR(萨科微)
    SMF(SOD-123FL)
    肖特基二极管 Single VR=60V IF=2A SOD123FL
DS26W 数据手册
DS22W-DS220W Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200 V Forward Current - 2.0A PINNING Features • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications 1 Cathode 2 Anode 1 2 Top View Marking Code: DS22W ---S22 DS24W ---S24 DS26W ---S26 DS28W ---S28 DS210W ---S210 DS212W ---S212 DS215W ---S215 DS220W ---S220 Simplified outline SOD-123FL and symbol MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight:15mg 0.00048oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter DS22W DS24W DS26W DS28W DS210W DS212W DS215W DS220W Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) 2.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 50 A Max Instantaneous Forward Voltage at 2 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF 0.55 0.95 0.3 3 80 220 V mA pF RθJA 85 °C/W Tj -55 ~ +125 °C T stg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.slkormicro.com 0.85 0.5 5 IR Cj 0.70 1 DS22W-DS220W Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 10 4 DS22W/DS24W DS26W-DS220W 10 1 T J =25°C 10 0 0 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Fig.4 Typical Junction Capacitance 500 Junction Capacitance ( pF) 20 10 1.0 DS22W/DS24W DS26W/DS28W DS210W/DS212W DS215W/DS220W 0.1 0.2 0 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 50 DS22W/DS24W 20 DS26W-DS220W 10 10 1 0.1 100 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 60 50 40 30 20 10 T J =25°C 200 1.8 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) T J =75°C 10 2 Case Temperature (°C) Peak Forward Surage Current (A) T J =100°C 10 3 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz www.slkormicro.com 200 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) 2 100 DS22W-DS220W PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND VM D E A g Top View mil Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm 1.2 (47) 1.2 (47) 2.0 (79) Marking Unit: mm (mil) www.slkormicro.com ∠ 7° The recommended mounting pad size 1.2 (47) g pad e E A pad HE 3 Type number Marking code DS22W S22 DS24W S24 DS26W S26 DS28W S28 DS210W S210 DS212W S212 DS215W S215 DS220W S220
DS26W
物料型号:DS22W-DS220W,这是一款表面安装肖特基势垒整流器。
器件简介: - 金属硅结,主要载流子导电。 - 适用于表面安装应用。 - 低功耗,高效率。 - 高正向浪涌电流能力。 - 用于低电压、高频率逆变器、自由轮和极性保护应用。
引脚分配:1号引脚为阴极,2号引脚为阳极。
参数特性: - 最大重复峰值反向电压(VRRM):20V至200V不等。 - 最大有效值电压(VRMS):14V至140V不等。 - 最大直流阻断电压(Voc):与VRRM相同。 - 最大平均正向整流电流(IF(AV)):2.0A。 - 正向浪涌电流(IFSM):某些型号可达50A。 - 最大瞬时正向电压(VE):在2A时,不同型号在0.55V至0.95V之间。 - 最大直流反向电流(IR):在25°C和额定直流反向电压下,以及在100°C时,不同型号在0.3mA至5mA之间。 - 典型结电容(Ci):220pF至80pF不等。 - 典型热阻(ReJA):某些型号为85°C/W。 - 工作结温范围(T):-55°C至+125°C。 - 存储温度范围(Tstg):-55°C至+150°C。
功能详解:文档中未明确提供“功能详解”部分的内容,但从简介和参数特性可以推断,这些整流器适用于需要高效率和高浪涌电流能力的场合。
应用信息:适用于低电压、高频率逆变器、自由轮和极性保护等应用。
封装信息:SOD-123FL塑料表面安装包,2引脚。
DS26W 价格&库存
很抱歉,暂时无法提供与“DS26W”相匹配的价格&库存,您可以联系我们找货
DS26W
  • 5+0.19739
  • 20+0.18048
  • 100+0.16356
  • 500+0.14664
  • 1000+0.13874
  • 2000+0.13310
库存:2180
