MMDT3906
MMDT3906
    SLKOR(萨科微)
    SOT-363
    通用三极管 SOT363 Dual PNP VCEO=40V Ic=200mA
MMDT3906 数据手册
MMDT3906 Dual PNP Small Signal Surface Mount Transistor FEATURES z Epitaxial planar die construction. z Ideal for low power amplification and switching. z Ultra-small surface mount package. z Also available in lead free version. APPLICATIONS z SOT-363 General switching and amplification. MAXIMUM RATING @ Ta=25℃ unless otherwise specified SYMBOL PARAMETER VALUE UNIT VCBO collector-base voltage -40 V VCEO collector-emitter voltage -40 V VEBO emitter-base voltage -5 V IC collector current -continuous -0.2 A Ptot total power dissipation -0.2 W RθJA Thermal resistance, junction to ambient 625 °C/W Tstg storage temperature 150 °C Tj junction temperature -55 to +150 °C www.slkormicro.com 1 MMDT3906 ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT V(BR)CBO Collector-base breakdown voltage IC=-10μA,IE=0 -40 V V(BR)CEO Collector-emitter breakdown voltage IC=-1mA,IB=0 -40 V V(BR)EBO Emitter-base breakdown voltage IE=-10μA,IC=0 -5 V ICEX collector cut-off current VCE=-30V,VEB(OFF)=-3.0V - -0.05 μA IBL Base cut-off current VCE=-30V,VEB(OFF)=-3.0V - -0.05 μA hFE DC current gain VCE =-1V,IC= -0.1mA VCE =-1V,IC =-1mA VCE =-1V,IC =-10mA VCE =-1V,IC =-50mA VCE =-1V,IC =-100mA VCE(sat) collector-emitter saturation voltage VBE(sat) base-emitter saturation voltage Cobo 60 80 100 60 30 300 - IC =-10mA,IB =-1mA - -250 mV IC =-50mA,IB =-5mA - -400 mV IC =-10mA,IB =-1mA -650 -850 mV IC =-50mA, IB =-5mA - -950 mV Output capacitance IE =0,VCB=-5V; f =1MHz - 4.5 pF Cibo Input capacitance IC=0, VEB =-0.5V; f =1MHz - 10 pF fT transition frequency IC=-1.0mA,VCE=-10V,f=1.0KHz 250 - MHz NF noise figure IC=-0.1mA,VCE=-20V,f=100MHz - 4 dB td delay time - 35 ns tr rise time VCC=-3V,VBE(off)=0.5V IC=-10mA IB1=-IB2=-1mA - 35 ns ts storage time - 225 ns tf fall time VCC=-3V,IC=-10mA IB1=-IB2=-1mA - 75 ns www.slkormicro.com 2 MMDT3906 TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.slkormicro.com 3 MMDT3906 PACKAGE OUTLINE Plastic surface mounted package SOT-363 A SOT-363 E K B D J G H Dim Min Max A 2.00 2.20 B 1.15 1.35 C 0.95 Typical D 0.25 Typical E 0.25 0.40 G 0.60 0.70 H 0.02 0.10 J C K 0.10 Typical 2.2 2.4 All Dimensions in mm SOLDERING FOOTPRINT 0.40 0.65 0.65 0.50 Unit : mm 1.90 PACKAGE INFORMATION Device Package Shipping MMDT3906 SOT-363 3000/Tape&Reel www.slkormicro.com 4
MMDT3906 价格&库存
很抱歉,暂时无法提供与“MMDT3906”相匹配的价格&库存,您可以联系我们找货
MMDT3906
库存:50
MMDT3906
  • 5+0.11831
  • 20+0.10788
  • 100+0.09744
  • 500+0.08700
  • 1000+0.08212
  • 2000+0.07864
库存:2695
