JK600-150U
JK600-150U
    JK(金科)
    PTC_15X5.5MM_TM
JK600-150U 数据手册
ShenZhen JinRui Electronic Material Co.,Ltd JK600 Polymer PTC Resettable Fuse JK600 Series Series Features:    Radial leaded Devices Cured,flame retardant epoxy polymer insulating material meets UL94V-0 Rohs compliant and lead-free Product Dimensions Fig1 JK600 Series Dimensions(mm) Model Lead material Shape A(max) B(max) C(max) D(typ) Tinned matel(mm) Fig JK600-110U 15 15 5.5 5.1 22AWG/Φ0.6 1 JK600-150U 15 15 5.5 5.1 22AWG/Φ0.6 1 JK600-160U 15 15 5.5 5.1 22AWG/Φ0.6 1 Note: ① Dimensions A, B, C is the maximum size, D values are typical tolerance of ± 0.75mm. Thermal Derating Chart-IH(A) Maximum ambient operating temperatures(℃) Model JK600 series Typical Time-to-trip -40℃ -20℃ 0℃ 25℃ 30℃ 40℃ 50℃ 60℃ 70℃ 85℃ 147% 138% 119% 100% 92% 83% 73% 64% 55% 42% at 25℃ Electrical Characteristic ShenZhen JinRui Electronic Material Co.,Ltd TEL: 0755-26546327 29356619 FAX:0755-26546562 Web Site:http://www.jkpptc.com E-mail:customer@jkpptc.com Add:JinKe Industry Park ,No. 310,Wuhe Road ,Guanlan,Longhua,Shenzhen ,Guangdong。 Specifications are subject to change without notice! Page 1 of 3 ShenZhen JinRui Electronic Material Co.,Ltd Model Ihold(A) Itrip(mA) JK600 Vmax interrupt(V) Imax(A) Pd max(W) Series Maximum Time to Trip Resistance(Ω) Current(A) Time(S) Rmin- Rmax JK600-110U 0.11 0.22 600 3 1.0 1.0 8 6-16 JK600-150U 0.15 0.30 600 3 1.0 1.0 9 5-14 JK600-160U 0.16 0.32 600 3 1.0 1.0 10 4-12 IH=Hold current:maximum current at which the device will not trip at 25℃ still air. IT=Trip current:minimum current at which the device will nalways at 25℃ still air. Vmax=Maximum voltage device can withstand without damage at rated current. Imax=Maximum fault current device can withstand tithout damage at rated voltage. Ttrip=Maximum time to trip(s) at assigned current. Pd=Typical power dissipation:typical amount of power dissipated by the decice when in state air environment. Rmin=Minimum device resistance at 25℃ prior to tripping. Rmax=Maximum device resistance at 25℃ prior to tripping. Marking System Environmental Specifications Test Conditions Resistance change Passive aging +85℃,1000hrs ±8% typical Humidity aging +85℃,85%R.H.1000hrs ±8% typical Thermal shock +125℃ to -55℃,10times ±12% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Solder reflow conditions ShenZhen JinRui Electronic Material Co.,Ltd TEL: 0755-26546327 29356619 FAX:0755-26546562 Web Site:http://www.jkpptc.com E-mail:customer@jkpptc.com Add:JinKe Industry Park ,No. 310,Wuhe Road ,Guanlan,Longhua,Shenzhen ,Guangdong。 Specifications are subject to change without notice! Page 2 of 3 ShenZhen JinRui Electronic Material Co.,Ltd Wave Soldering: JK600 Series Soldering Temperature:260℃~270℃ Soldering Time:≤3sec. Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。 Manual soldering: Soldering Temperature:250℃~280℃ Soldering Time: ≤3sec. Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。 Packaging and Storage Bag quantity JK600-110U~JK600-160U200 Pcs/Bag Storage The maximum ambient temperature shall not exceed 40℃.Storage temperatures higher than 40℃ could result in the deformation of packaging materials.The maximum relative humidity recommended for storage is 70%.High humidity with high temperature can accelerate the oxidation the oxidation of the solder plating on the termination and reduce the solderability of the components.sealed plastic bags with desiccant shall be used to teduce the oxidation of the termination and shall only be opened prior to use.the products shall not be stored in areas where harmful gases containing sulfu of chlorine are present. Warning: Please read this specification before use the product。 Using of this product must be sure to follow the requirement of this specification,operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and flame. PPTC resettable fuses are intended for occasional over current protection. Application for repeated over current condition or prolonged trip are not anticipated. Please avoid contact of PPTC resettable fuses with chemical solvent. Prolonged contact will damage the device performance. You are requested not to use our product deviating from the agreed specifications. ShenZhen JinRui Electronic Material Co.,Ltd TEL: 0755-26546327 29356619 FAX:0755-26546562 Web Site:http://www.jkpptc.com E-mail:customer@jkpptc.com Add:JinKe Industry Park ,No. 310,Wuhe Road ,Guanlan,Longhua,Shenzhen ,Guangdong。 Specifications are subject to change without notice! Page 3 of 3
JK600-150U 价格&库存
很抱歉,暂时无法提供与“JK600-150U”相匹配的价格&库存,您可以联系我们找货
