MM3Z2V0-MM3Z75
Silicon Planar Zener Diodes
PINNING
PIN
Features
• Total power dissipation : max. 300 mW
DESCRIPTION
1
Cathode
2
Anode
2
1
• Small plastic package suitable for
surface mounted design
• Tolerance approximately ± 5%
SOD-323
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Power Dissipation
Junction Temperature
Storage Temperature Range
Symbol
Value
Unit
Ptot
300
mW
Tj
150
O
Tstg
- 55 to + 150
O
Symbol
Max.
RθJA
417
VF
0.9
C
C
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 10 mA
www.slkormicro.com
1
Unit
C/W
O
V
MM3Z2V0-MM3Z75
Type
Marking
Code
Zener Voltage Range 1)
Vznom
(V)
MM3Z2V0
B0
2.0
MM3Z2V2
C0
2.2
MM3Z2V4
1C
2.4
MM3Z2V7
1D
2.7
MM3Z3V0
1E
3.0
MM3Z3V3
1F
3.3
MM3Z3V6
1H
3.6
MM3Z3V9
1J
3.9
MM3Z4V3
1K
4.3
MM3Z4V7
1M
4.7
MM3Z5V1
1N
5.1
MM3Z5V6
1P
5.6
MM3Z6V2
1R
6.2
MM3Z6V8
1X
6.8
MM3Z7V5
1Y
7.5
MM3Z8V2
1Z
8.2
MM3Z9V1
2A
9.1
MM3Z10
2B
10
MM3Z11
2C
11
MM3Z12
2D
12
MM3Z13
2E
13
MM3Z15
2F
15
MM3Z16
2H
16
MM3Z18
2J
18
MM3Z20
2K
MM3Z22
2M
22
MM3Z24
2N
24
MM3Z27
2P
27
MM3Z30
2R
30
MM3Z33
2X
33
MM3Z36
2Y
36
MM3Z39
2Z
39
MM3Z43
3A
43
MM3Z47
3B
47
MM3Z51
3C
51
MM3Z56
3D
56
MM3Z62
3E
62
MM3Z68
3F
68
MM3Z75
3H
75
1)
VZT is tested with pulses (20 ms).
www.slkormicro.com
VZT
(V)
1.8...2.15
2.08...2.33
2.28...2.56
2.5...2.9
2.8...3.2
3.1...3.5
3.4...3.8
3.7...4.1
4...4.6
4.4...5
4.8...5.4
5.2...6
5.8...6.6
6.4...7.2
7...7.9
7.7...8.7
8.5...9.6
9.4...10.6
10.4...11.6
11.4...12.7
12.4...14.1
13.8...15.6
15.3...17.1
16.8...19.1
18.8...21.2
20.8...23.3
22.8...25.6
25.1...28.9
28...32
31...35
34...38
37...41
40...46
44...50
48...54
52...60
58...66
64...72
70...79
Dynamic Impedance
at IZT
(mA)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
2
ZZT
Max. ( Ω)
100
100
100
110
120
130
130
130
130
130
130
80
50
30
30
30
30
30
30
35
35
40
40
45
50
55
60
70
80
80
90
100
130
150
180
200
215
240
265
at IZT
(mA)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
Reverse Leakage Current
IR
Max. (μA)
120
120
120
120
50
5
5
2
2
1
1
0.5
0.5
0.5
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
at VR
(V)
0.5
0.7
1
1
1
1
1
1
1
1
1.5
2.5
3
3.5
4
5
6
7
8
9
10
11
12
13
15
17
19
21
23
25
27
30
33
36
39
43
47
52
56
MM3Z2V0-MM3Z75
Breakdown characteristics
Tj = constant (pulsed)
mA
50
Tj=25o C
3V9
2V7
6V8
4V7
3V3
Iz
40
8V2
5V6
30
Test current Iz
5mA
10
2
3
4
5
6
8
7
9
10 V
Vz
mA
30
Tj=25 oC
10
12
Iz
15
22
27
Test current Iz
5mA
10
33
Vz
Power Dissipation: Ptot (mW)
300
200
100
150
100
Ambient Temperature: Ta ( C)
O
Derating Curve
www.slkormicro.com
3
40 V
MM3Z2V0-MM3Z75
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
A
c
HE
A
D
E
www.slkormicro.com
bp
UNIT
A
bp
C
D
E
HE
mm
1.10
0.80
0.40
0.25
0.15
0.10
1.80
1.60
1.35
1.15
2.80
2.30
4
很抱歉,暂时无法提供与“MM3Z24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12088
- 300+0.09544
- 1200+0.09401
- 3000+0.08128
- 国内价格
- 50+0.13187
- 500+0.10412
- 3000+0.08867
- 6000+0.07938
- 24000+0.07128
- 51000+0.06696
