KBL6005-KBL610
6. 0 A Single-Phase Silicon Bridge Rectifier
KBL
Rectifier Reverse Voltage 50 to 1000V
Features
Ideal for printed circuit board mounting
This series is UL listed under the Recognized
Component Index, file number E484648
The plastic material used carries Underwriters Laboratory
flammability recognition 94V-0
Built-in printed circuit board stand-offs
High case dielectric strength
High temperature soldering guaranteed 260 /5
seconds at 5 lbs (2.3kg) tension
Mechanical Data
Case: Reliable low cost construction utilizing
molded plastic technique
Terminals: Plated leads solderable per MIL-STD-202,
Method 208
Mounting Position: Any
Dimensions in inches and (milimeters)
Maximum Ratings & Thermal Characteristics
Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz.
For Capacitive load derate current by 20%.
KBL
KBL
KBL
KBL
KBL
KBL
Parameter
Symbol 6005
601
602
604
606
608
VRRM
200
400
800
Maximum repetitive peak reverse voltage
50
600
100
Maximum RMS bridge input voltage
Maximum DC blocking voltage
Maximum average forward rectified
output current at TC=100 C (with heatsink)
VRMS
VDC
35
50
70
140
280
100
200
400
KBL
610
1000
unit
V
420
560
700
V
600
800
1000
V
IF(AV)
6.0
A
Peak forward surge current single sine-wave
superimposed on rated load (JEDEC Method) IFSM
150
A
I t
95
A sec
TJ,
TSTG
-55 to + 150
Rating for fusing ( t
很抱歉,暂时无法提供与“KBL610”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.85588
- 50+1.50207
- 150+1.35044
- 500+1.04750
- 2500+0.96326
- 5000+0.91260
