SM66406D1RL
SM66406D1RL
    SPS(源芯)
    DFN-8(5x6)
    N-MOS 40V 30A
SM66406D1RL 数据手册
SM66406D1RL D N04D 40V /30A Single N Power MOSFET 40V /30A Single N Power MOSFET N V General Description DS RDS(on),TYP@VGS=10V RDS(on),TYP@VGS=4.5 ID 40V /30A Single N Power MOSFET Very low on-resistance RDS(on) @ VGS=4.5 V Pb-free lead plating; RoHS compliant Part ID Package Type Marking Tape and reel infomation SM66406D1RL DFN5x6 6406 3000 Parameter 30N04D 40 V 9.0 mΩ 12.0 mΩ 30 A 100% UIS Tested 100% Rg Tested Symbol Maximum Units Drain-Source Voltage VDS 40 V Gate-Source Voltage VGS 20 ±V Continuous Drain Current A Pulsed Drain Current Avalanche Current TA=25°C TA=70°C B Power Dissipation G 48.0 IAR 9.6 EAR 22.1 TA=25°C A A mJ 36.5 PD TA=70°C Junction and Storage Temperature Range 30.0 IDM G Repetitive avalanche energy L=0.1mH 30.0 ID W 14.5 -55 to 150 TJ, TSTG °C Thermal Characteristics Parameter Symbol Maximum Junction-to-Ambient A t ≤ 10s Maximum Junction-to-Ambient A Steady State Maximum Junction-to-Lead V01 C Steady State 1 www.sourcechips.com RθJA RθJL Typ Max Units 23 35 °C/W 47 56 °C/W 14 22 °C/W SM66406D1RL STATIC PARAMETERS Symbol BVDSS Parameter Drain-Source Breakdown Voltage 40V /30A Single N Power MOSFET Conditions ID = -250uA, VGS = 0V IDSS Zero Gate Voltage Drain Current VDS=40V, VGS=0V IGSS Gate-Body leakage current VDS = 0V, VGS = ±20V VGS(th) Gate Threshold Voltage VDS = VGS ID = 250µA RDS(ON) Static Drain-Source OnResistance gFS VSD IS Min Typ Max 40 Units V 1 5 uA ±100 nA 1.9 2.5 V VGS=10V, ID=20A 9.0 11.0 VGS=4.5V, ID=20A 12.0 15.6 Forward Transconductance VDS=5V, ID=20A 59 Diode Forward Voltage IS=1A,VGS=114V 0.72 1.3 mΩ S 1 V 30 A Typ Max Units 1480 1805 pF 245 301 pF 13 15 pF 1.5 Ω Max Units Maximum Body-Diode Continuous Current DYNAMIC PARAMETERS Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Rg Gate resistance Conditions Min VGS=0V, VDS=15V, f=1MHz VGS=0V, VDS=0V, f=1MHz SWITCHING PARAMETERS Symbol Parameter Qg (10V) Total Gate Charge Qg 4.5V) Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge 3 tD(on) Turn-On DelayTime 5.5 tr Turn-On Rise Time tD(off) Turn-Off DelayTime tf Turn-Off Fall Time Body Diode Reverse Recovery Time trr Qrr V01 Body Diode Reverse Recovery Charge Conditions Min Typ 8.5 VGS=10V, VDS=15V, ID=20A VGS=10V, VDS=15V,RL=0.75Ω, RGEN=3Ω 4.25 2.1 4.4 15.4 nC ns 4.95 IF=-8A, dI/dt=500A/µs 11 ns IF=18A, dI/dt=500A/µs 21 nC 2 www.sourcechips.com SM66406D1RL 40V /30A Single N Power MOSFET V01 3 www.sourcechips.com SM66406D1RL 40V /30A Single N Power MOSFET V01 4 www.sourcechips.com
SM66406D1RL 价格&库存
很抱歉,暂时无法提供与“SM66406D1RL”相匹配的价格&库存,您可以联系我们找货
