TRF100
TRF100
    TLC(竞沃)
    FUSE_17.8X3.8MM_TM
    PPTC可复位保险丝
TRF100 数据手册
Revision: A Date: 2018-04-24 Page No.: 1 OF 1 PPTC RESETTALBE 电路保护元器件专业制造商 FUSES TRF(250V) Series Features ◆ Radial Leaded Devices ◆ Cured, flame retardant epoxy polymer insulating material meets UL 94V-0 requirements ◆ Bulk Package, or tape and reel available on most models ◆ UL(Pending), C-UL(Pending), TUV(R50322002) ◆ RoHS, Reach, HF compliance Applications Almost anywhere there is a low voltage power supply, up to DC60V and a load to be protected, including: ◆ Security and fire alarm systems ◆ Analog and digital line cards ◆ Modems and DSL 电气特性 : 保持电流 跳脱电流 最大电压 最大电流 最大冲击电压 最大动作时间 IT, (A) V max, (V) I max, (A) V max, (V) (A) (Sec.) 消耗功率 0.020 0.045 60 3.0 250 0.10 3.0 1.0 TRF004 0.040 0.080 60 3.0 250 0.20 3.0 TRF006 0.060 0.120 60 3.0 250 0.30 3.0 TRF008 0.080 0.160 60 3.0 250 0.35 TRF009 0.090 0.220 60 3.0 250 TRF011 0.110 0.220 60 3.0 250 TRF012 0.120 0.240 60 3.0 TRF012U 0.120 0.240 60 TRF014 0.145 0.29 60 TRF014U 0.145 0.29 TRF018 0.180 TRF018U 0.180 TRF020 0.200 电阻范围(Ω) P/N IH, (A) TRF002 Pd typ, (W) R min, R max, R1 max, 65 145 1.0 24 65.0 97.5 1.0 22.0 36.0 56.0 4.0 1.0 14.0 22.0 33.0 1.00 1.0 1.0 9.7 20.6 33.0 1.00 1.0 1.0 6.0 12.0 18.0 250 1.00 3.0 1.0 6.0 10.0 16.0 3.0 250 1.00 1.5 1.0 6.0 10.0 16.0 3.0 250 1.00 2.5 1.0 3.0 6.0 14.0 60 3.0 250 1.0 2.5 1.0 3.5 6.5 12.0 0.54 60 3.0 250 3.0 1.5 1.8 1.0 2.2 4.0 0.54 60 3.0 250 3.0 1.5 1.8 1.0 2.2 4.0 0.6 60 3.0 250 3.0 5.0 1.8 1.7 3.5 6.30 240 TRF030 0.300 0.60 60 3.0 250 3.0 6.0 1.8 1.0 2.2 3.50 TRF040 0.400 0.800 60 5.5 250 3.0 8 1.8 0.80 1.60 3.20 TRF050 0.500 1.00 60 6.0 250 3.0 10 3.0 0.56 1.40 2.52 TRF060 0.600 1.20 60 7.0 250 3.0 12 3.2 0.40 1.10 2.16 TRF080 0.800 1.60 60 8.0 250 4.0 18 3.6 0.32 0.80 1.44 TRF100 1.000 2.00 60 10.0 250 5.0 21 2.9 0.22 0.50 1.45 TRF150 1.500 3.00 60 15.0 250 7.50 25.0 3.5 0.12 0.28 0.68 TRF200 2.000 4.00 60 20.0 250 10.0 28 4.5 0.09 0.192 0.42 产品尺寸 (U nit: mm) : Max. working voltage: A=16V B=30V C=60/72V E=90/120V F=250V G=600V M=265V X 012 Manufacturer's Trademark Packaging Options: “ - ” Bulk package “ -T ” Tape & Reel XX Lot No Style1 Style2 Style3 TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 E-mail:sales@tlcet.com.cn Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710 Holding current:0.12A Revision: A Date: 2018-04-24 Page No.: 1 OF 2 PPTC RESETTALBE 电路保护元器件专业制造商 FUSES TRE(90/120V) Series A B C D E 物理特性 P/N LeadΦ(mm) Material(材料) Max.(最大) Max.(最大) Typ.(标准) Min.(最小) Max.(最大) Style(样式) TRF002 7.4 12.7 5.1 7.6 4.5 1 0.50 CP TRF004 5.8 9.9 5.1 7.6 4.5 1 0.50 CP TRF006 5.8 9.9 5.1 7.6 4.5 1 0.60 CP TRF008 7.4 12.7 5.1 7.6 4.5 1 0.60 CP TRF009 7.4 12.7 5.1 7.6 4.5 1 0.60 CP TRF011 6.5 11.0 5.1 5.0 4.5 2 0.60 CP TRF012 6.8 12.0 5.1 7.6 4.5 2 0.60 CP TRF012U 6.8 12.0 5.1 7.6 4.5 2 0.60 CP TRF014 6.5 11.0 5.1 5.0 4.5 2 0.60 CP CP CP TRF014U 6.0 10.0 5.1 4.7 4.5 2 0.60 TRF018 10.2 14.5 5.1 7.6 4.5 1 0.60 TRF018U 10.2 14.5 5.1 7.6 4.5 1 0.60 CP TRF020 10.5 17.0 5.1 7.6 4.5 1 0.60 CU TRF030 11.0 16.8 5.1 7.6 4.5 1 0.60 CU TRF040 11.7 17.0 5.1 7.6 3.8 1 0.60 CU TRF050 13.0 18.0 5.1 7.6 3.8 2 0.60 CU TRF060 14.0 19.5 5.1 7.6 3.8 2 0.60 CU TRF080 16.3 21.3 5.1 7.6 3.8 3 0.80 CU TRF100 17.8 22.9 5.1 7.6 3.8 3 0.80 CU TRF150 20.8 29.8 10.2 7.6 3.8 3 0.80 CU TRF200 28.4 33.5 10.2 7.6 3.8 3 0.80 CU 环境温度与工作电流关系特性曲线 : 工作环境温度 P/N -40℃ -20℃ 0℃ 25℃ 40℃ 50℃ 60℃ 70℃ 85℃ TRF002 0.031 0.028 0.023 0.020 0.017 0.015 0.013 0.011 0.008 TRF004 0.062 0.055 0.048 0.040 0.033 0.029 0.026 0.022 0.017 TRF006 0.093 0.075 0.071 0.060 0.050 0.044 0.038 0.033 0.025 TRF008 0.124 0.110 0.095 0.080 0.066 0.059 0.051 0.044 0.033 TRF009 0.140 0.124 0.110 0.090 0.075 0.068 0.058 0.050 0.038 TRF011 0.171 0.151 0.131 0.110 0.091 0.081 0.071 0.061 0.046 TRF012(U) 0.186 0.165 0.143 0.120 0.099 0.088 0.077 0.066 0.050 TRF014(U) 0.225 0.199 0.172 0.145 0.119 0.106 0.093 0.080 0.060 TRF018(U) 0.269 0.240 0.211 0.180 0.153 0.138 0.123 0.109 0.087 TRF020 0.310 0.275 0.237 0.200 0.165 0.147 0.128 0.110 0.082 TRF030 0.465 0.413 0.356 0.300 0.248 0.221 0.192 0.165 0.123 TRF040 0.620 0.550 0.475 0.400 0.330 0.295 0.255 0.220 0.165 TRF050 0.775 0.688 0.594 0.500 0.412 0.366 0.319 0.275 0.206 TRF060 0.930 0.825 0.710 0.600 0.495 0.443 0.393 0.330 0.246 TRF080 1.240 1.100 0.950 0.800 0.660 0.590 0.510 0.440 0.330 TRF100 1.550 1.38 1.19 1.00 0.83 0.74 0.64 0.55 0.41 TRF150 2.400 2.00 1.80 1.50 1.20 1.10 0.90 0.80 0.60 TRF200 3.100 2.75 2.38 2.00 1.65 1.48 1.28 1.10 0.83 E-mail:sales@tlcet.com.cn TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710 Revision: A Date: 2018-04-24 Page No.: 1 OF 3 PPTC RESETTALBE FUSES 电路保护元器件专业制造商 TRE(90/120V) Series 动作电流时间曲线表 : The Time to Trip curves represent typical performance of a device in a simulated application environment. Actual performance in specific customer applications may differ from these values due to the influence of other variables. 标准包装数量 : Model Q’t y/bag TRF002-TRF040 1000pcs TRF050-TRF100 500pcs TRF200 200pcs Tape and Reel Specifications Devices taped using EIA468–B/IEC286-2 standards. 6、Agency Recognition: Caution:Operation beyond the rated voltage or current may result in rupture electrical arcing or flame.Specifications are subject to change without notice. E-mail:sales@tlcet.com.cn TEL: 86-0769-3892 0554 FAX: 86-0769-8793 2077 Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710
TRF100 价格&库存
很抱歉,暂时无法提供与“TRF100”相匹配的价格&库存,您可以联系我们找货
TRF100
    • 1+0.67500
    • 10+0.65000
    • 100+0.59000
    • 500+0.56000
