MM3Z2V0 THRU MM3Z75V
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 200mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±5%
DESCRIPTION
1
Cathode
2
Anode
2
MECHANICAL DATA
▪Case: SOD-323
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪A pprox. Weight: 5.48mg / 0.00019oz
1
Top View
Simplified outline SOD-323 and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
200
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
417
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
(1)
Operating and Storage Temperature Range
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (54 X 5 cm) copper areas pads.
Transient Thermal Impedance( °C /W)
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
150
175
T c ,Case Temperature (°C)
REV.08
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
t, Pulse Duration(sec)
1 of 3
100
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
MM3Z2V0
WY
1.8
2.0
2.15
5
100
120
0.5
MM3Z2V2
WZ
2.08
2.2
2.33
5
100
120
0.7
MM3Z2V4
00
2.28
2.4
2.56
5
100
120
1
MM3Z2V7
01
2.5
2.7
2.9
5
110
120
1
MM3Z3V0
02
2.8
3.0
3.2
5
120
50
1
MM3Z3V3
05
3.1
3.3
3.5
5
130
MM3Z3V6
06
3.4
3.6
3.8
5
130
10
1
MM3Z3V9
07
3.7
3.9
4.1
5
130
5
1
MM3Z4V3
08
4
4.3
4.6
5
130
5
1
4.7
5
5
130
2
1
5.4
5
130
2
1.5
MM3Z4V7
09
4.4
MM3Z5V1
0A
4.8
5.1
MM3Z5V6
0C
5.2
5.6
6
5
80
1
2.5
MM3Z6V2
0E
5.8
6.2
6.6
5
50
1
3
MM3Z6V8
0F
6.4
6.8
7.2
5
30
0.5
3.5
MM3Z7V5
0G
7
7.5
7.9
5
30
0.5
4
MM3Z8V2
0H
7.7
8.2
8.7
5
30
0.5
5
MM3Z9V1
0K
8.5
9.1
9.6
5
30
0.5
6
MM3Z10V
0L
9.4
10
10.6
5
30
0.1
7
MM3Z11V
0M
10.4
11
11.6
5
30
0.1
8
12.7
5
35
0.1
9
0.1
10
0.1
11
MM3Z12V
0N
11.4
12
MM3Z13V
0P
12.4
13
14.1
5
35
MM3Z15V
0T
13.8
15
15.6
5
40
MM3Z16V
0U
15.3
16
17.1
5
40
0.1
12
MM3Z18V
0W
16.8
18
19.1
5
45
0.1
13
MM3Z20V
0Z
18.8
5
50
0.1
15
MM3Z22V
10
20.8
22
23.3
5
55
0.1
17
MM3Z24V
11
22.8
24
25.6
5
60
0.1
19
MM3Z27V
12
25.1
27
28.9
2
70
0.1
21
MM3Z30V
14
28
30
32
2
80
0.1
23
MM3Z33V
18
31
33
35
2
80
0.1
25
0.1
27
MM3Z36V
19
34
36
38
2
90
MM3Z39V
39
41
2
100
0.1
30
MM3Z43V
21
40
43
46
2
130
0.1
33
MM3Z47V
1A
44
47
50
2
150
0.1
36
MM3Z51V
1C
48
51
54
2
180
0.1
39
MM3Z56V
1D
52
56
60
2
200
0.1
43
MM3Z62V
1E
58
62
66
2
215
0.1
47
MM3Z68V
1F
64
68
72
2
240
0.1
52
MM3Z75V
1G
70
75
79
2
265
0.1
56
(1) V ZT is tested with pulses (20 ms)
REV.08
2 of 3
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
REV.08
3 of 3
8
很抱歉,暂时无法提供与“MM3Z9V1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09696
- 500+0.07541
- 3000+0.06423
- 6000+0.05695
- 24000+0.05079
- 51000+0.04741
- 国内价格
- 50+0.07300
- 500+0.06870
- 2000+0.06012
- 5000+0.05582
- 15000+0.05153
- 30000+0.04938
