BZT52C2V0 THRU BZT52C75
Silicon Planar Zener Diodes
PINNING
FEATURES
PIN
• Total power dissipation: Max. 500mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±5%
DESCRIPTION
1
Cathode
2
Anode
2
MECHANICAL DATA
▪Case: SOD-123
▪Terminals: Solderable per MIL-STD-750, Method 2026
1
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
500
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
340
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
(1)
Operating and Storage Temperature Range
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (5 X 5 cm) copper areas pads.
Transient Thermal Impedance( °C /W)
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
150
175
T c ,Case Temperature (°C)
REV.08
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
t, Pulse Duration(sec)
1 of 3
100
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
BZT52C2V0
W10
1.8
2.0
2.15
5
100
120
0.5
BZT52C 2V2
W11
2.08
2.2
2.33
5
100
120
0.7
BZT52C2V4
WX
2.28
2.4
2.56
5
100
120
1
BZT52C 2V7
W1
2.5
2.7
2.9
5
110
120
1
BZT52C 3V0
W2
2.8
3.0
3.2
5
120
50
1
BZT52C 3V3
W3
3.1
3.3
3.5
5
130
BZT52C 3V6
W4
3.4
3.6
3.8
5
130
10
1
BZT52C 3V9
W5
3.7
3.9
4.1
5
130
5
1
BZT52C 4V3
W6
4
4.3
4.6
5
130
5
1
BZT52C 4V7
W7
4.4
4.7
5
5
130
2
1
BZT52C 5V1
W8
4.8
5.1
5.4
5
130
2
1.5
BZT52C 5V6
W9
5.2
5.6
6
5
80
1
2.5
BZT52C 6V2
WA
5.8
6.2
6.6
5
50
1
3
BZT52C 6V8
WB
6.4
6.8
7.2
5
30
0.5
3.5
BZT52C 7V5
WC
7
7.5
7.9
5
30
0.5
4
BZT52C 8V2
WD
7.7
8.2
8.7
5
30
0.5
5
BZT52C 9V1
WE
8.5
9.1
9.6
5
30
0.5
6
BZT52C 10
WF
9.4
10
10.6
5
30
0.1
7
BZT52C 11
WG
10.4
11
11.6
5
30
0.1
8
BZT52C 12
WH
11.4
12
12.7
5
35
0.1
9
BZT52C 13
WI
12.4
13
14.1
5
35
0.1
10
BZT52C 15
WJ
13.8
15
15.6
5
40
0.1
11
BZT52C 16
WK
15.3
16
17.1
5
40
0.1
12
BZT52C 18
WL
16.8
18
19.1
5
45
0.1
13
BZT52C 20
WM
18.8
5
50
0.1
15
BZT52C 22
WN
20.8
22
23.3
5
55
0.1
17
BZT52C 24
WO
22.8
24
25.6
5
60
0.1
19
BZT52C 27
WP
25.1
27
28.9
5
70
0.1
21
BZT52C 30
WQ
28
30
32
5
80
0.1
23
BZT52C 33
WR
31
33
35
5
80
0.1
25
BZT52C 36
WS
34
36
38
5
90
0.1
27
BZT52C 39
WT
37
39
41
2.5
100
2
30
BZT52C 43
WU
40
43
46
2.5
130
2
33
BZT52C 47
WV
44
47
50
2.5
150
2
36
BZT52C 51
WW
48
51
54
2.5
180
1
39
BZT52C 56
WX1
52
56
60
2.5
180
1
43
BZT52C 62
WY
58
62
66
2.5
200
0.2
47
BZT52C 68
WZ
64
68
72
2.5
250
0.2
52
BZT52C 75
WZ1
70
75
79
2.5
300
0.2
57
(1) V ZT is tested with pulses (20 ms)
REV.08
2 of 3
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
A
D
b
E
A1
C
∠ALL ROUND
L1
E1
SOD-123 mechanical data
A
C
D
E
E1
L1
b
A1
max
1.3
0.22
1.8
2.8
3.9
0.45
0.7
0.2
min
0.9
0.09
1.5
2.5
3.6
0.25
0.5
max
51
8.7
71
110
154
18
28
min
35
3.5
59
98
142
10
UNIT
mm
9°
mil
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
REV.08
3 of 3
8
很抱歉,暂时无法提供与“BZT52C39”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10876
- 500+0.08597
- 3000+0.06783
- 6000+0.06016
- 24000+0.05357
- 51000+0.05001
- 国内价格
- 50+0.07649
- 500+0.07200
- 2000+0.06300
- 5000+0.05850
- 15000+0.05400
- 30000+0.05175
