PJ75ALXXSA Series
Low Dropout Regulators
Description
SOT-23
The PJ75ALXXSA series is a set of three-terminal
low power high voltage regulators implemented in
CMOS technology. They allow input voltages as
high as 36V. They are available with several fixed
output voltages ranging from 2.8V to 5.0V. Because of
the low power dissipation, PJ75ALXXSA are
1.GND 2.VOUT 3.VIN
widely used in a variety of equipment such as
audio device, video device, communication device
Block Diagram
and so on.
Features
VIN
Low power consumption
Low voltage drop
Low temperature coefficient
High input voltage (up to 36V)
Quiescent current : 2.5μA
Output voltage tolerance: ±2%
HAF(halogen and antimony free) is acquired
Selection Tablet
Designator
XX
www.pingjingsemi.com
Revision:1.0 Sep-2019
VOUT
Vref
GND
PJ75ALXXSA
Symbol
Description
28
2.8V(output)
30
3.0V
33
3.3V
36
3.6V
40
4.0V
44
4.4V
50
5.0V
1/8
PJ75ALXXSA Series
Absolute Maximum Ratings
Note1
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Limit
Unit
Supply voltage
-0.3 ~ +36
V
Storage temperature range
-50 ~ +125
-40 ~ 85
Operating temperature range
Note: 1.Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only,
and functional operation of the device at these or any other conditions beyond those conditions is not implied. Exposure to absolutemaximum-rated conditions for extended periods may affect device reliability.
Parameter
Symbol
Value
Unit
RθJA
200
℃/W
PD
500
mW
Junction-to-Ambient Thermal Resistance
Power Consumption
Electrical Characteristics
PJ75AL28SA(TA=25℃)
Parameter
Symbol
Test conditions
Min.
Typ.
Max
Unit
2.744
2.80
2.856
V
Output voltage
VOUT
VIN=VOUT+2.0V, IOUT=10mA
Output current
IOUT
VIN=VOUT+2.0V
70
100
mA
Load regulation
ΔVOUT
VIN=VOUT+2.0V
1mA≤IOUT≤50mA
25
60
mV
Voltage drop Note2
VDIF
IOUT=1mA,ΔVOUT=2%
30
100
mV
Quiescent Current
IQ
No Load
2.5
3.0
μA
VOUT+2.0V≤VIN≤30V,IOUT=1mA
0.2
%/V
36
V
100
ppm/℃
Line regulation
ΔVOUT / VOUT×
ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT×
ΔTA
VIN=VOUT+2.0V, IOUT=10mA,
-40℃≤TA≤85℃
2/8
PJ75ALXXSA Series
PJ75AL30SA(TA=25℃)
Parameter
Symbol
Test conditions
Output voltage
VOUT
Output current
IOUT
VIN=VOUT+2.0V
Load regulation
ΔVOUT
Min.
Typ.
Max
Unit
2.940
3.00
3.060
V
70
100
mA
25
60
mV
30
100
mV
Voltage drop Note2
VDIF
VIN=VOUT+2.0V
1mA≤IOUT≤50mA
IOUT=1mA,ΔVOUT=2%
Quiescent Current
IQ
No Load
2.5
3.0
μA
0.2
%/V
36
V
100
ppm/℃
Min.
Typ.
Max
Unit
3.234
3.30
3.366
V
70
100
mA
25
60
mV
25
55
mV
Line regulation
ΔVOUT / VOUT
×ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT
×ΔTA
-40℃≤TA≤85℃
PJ75AL33SA(TA=25℃)
Parameter
Symbol
Test conditions
Output voltage
VOUT
Output current
IOUT
VIN=VOUT+2.0V
Load regulation
ΔVOUT
Voltage drop Note2
VDIF
VIN=VOUT+2.0V
1mA≤IOUT≤50mA
IOUT=1mA,ΔVOUT=2%
Quiescent Current
IQ
No Load
2.5
3.0
μA
0.2
%/V
36
V
100
ppm/℃
Line regulation
ΔVOUT / VOUT
×ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT
×ΔTA
-40℃≤TA≤85℃
PJ75AL36SA(TA=25℃)
Parameter
Symbol
Test conditions
Min.
Typ.
Max
Unit
Output voltage
VOUT
VIN=VOUT+2.0V ,IOUT=10mA
3.528
3.60
3.672
V
Output current
IOUT
70
100
mA
Load regulation
ΔVOUT
25
60
mV
25
55
mV
2.5
3.0
μA
0.2
%/V
36
V
100
ppm/℃
Voltage drop Note2
VDIF
VIN=VOUT+2.0V
VIN=VOUT+2.0V
1mA≤IOUT≤50mA
IOUT=1mA,ΔVOUT=2%
Quiescent Current
IQ
No Load
Line regulation
ΔVOUT / VOUT
×ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT
VIN= VOUT+2.0V, IOUT=10mA,
×ΔTA
-40℃≤TA≤85℃
3/8
PJ75ALXXSA Series
PJ75AL40SA(TA=25℃)
Parameter
Symbol
Test conditions
Min.
Typ.
Max
Unit
Output voltage
VOUT
3.920
4.0
4.080
V
Output current
IOUT
70
100
mA
Load regulation
ΔVOUT
25
60
mV
25
55
mV
Voltage drop Note2
VDIF
VIN=VOUT+2.0V
VIN=VOUT+2.0V
1mA≤IOUT≤50mA
IOUT=1mA,ΔVOUT=2%
Quiescent Current
IQ
No Load
2.5
3.0
μA
0.2
%/V
36
V
100
ppm/℃
Line regulation
ΔVOUT /
VOUT×ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT
×ΔTA
-40℃≤TA≤85℃
PJ75AL44SA(TA=25℃)
Parameter
Symbol
Test conditions
Min.
Typ.
Max
Unit
Output voltage
VOUT
4.312
4.4
4.488
V
Output current
IOUT
70
100
mA
Load regulation
ΔVOUT
25
60
mV
25
55
mV
2.5
3.0
μA
0.2
%/V
36
V
100
ppm/℃
Voltage drop Note2
VDIF
VIN=VOUT+2.0V
VIN=VOUT+2.0V
1mA≤IOUT≤50mA
IOUT=1mA,ΔVOUT=2%
Quiescent Current
IQ
No Load
Line regulation
ΔVOUT / VOUT
×ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT
×ΔTA
-40℃≤TA≤85℃
PJ75AL50SA(TA=25℃)
Parameter
Symbol
Test conditions
Min.
Typ.
Max
Unit
Output voltage
VOUT
4.900
5.0
5.100
V
Output current
IOUT
VIN=VOUT+2.0V
100
150
mA
Load regulation
ΔVOUT
VIN=VOUT+2.0V
1mA≤IOUT≤70mA
25
60
mV
Voltage drop Note2
VDIF
IOUT=1mA,ΔVOUT=2%
25
55
mV
Quiescent Current
IQ
No Load
3.5
4.0
μA
VOUT+2.0 V≤VIN≤30V,IOUT=1mA
0.2
%/V
36
V
100
ppm/℃
Line regulation
ΔVOUT / VOUT
×ΔVIN
Input voltage
VIN
Temperature
coefficient
ΔVOUT /VOUT
×ΔTA
-40℃≤TA≤85℃
NOTE: 2.The difference of input voltage and output voltage when input voltage falls down gradually till output voltage equals to 98% of rating VOUT .
4/8
PJ75ALXXSA Series
Application Circuit
VIN
VIN
C 1
10μF
C o m m o n
PJ75ALXXSA
Series
VOUT
VOUT
C 2
G N D
10μF
Single Point GND
C o m m o n
5/8
PJ75ALXXSA Series
Package Outline
SOT-23
Dimensions in mm
0.8
Max.
1.150
A
0.900
1.025
A1
0.000
0.050
0.100
b
c
D
0.300
0.080
2.800
0.400
0.115
2.900
0.500
0.150
3.000
E
1.200
1.300
1.400
HE
2.250
2.400
2.550
e
1.800
1.900
2.000
0.550REF
L1
L
0.300
θ
0°
0.500
8°
2.2
Typ.
0.8
1.0
Min.
1.0
Dimensions in millimeter
Symbol
1.9
SOT-23
Recommended soldering pad
Ordering Information
Device
PJ75ALXXSA Series
Package
SOT-23
Shipping
3000/Reel&Tape(7inch)
6/8
PJ75ALXXSA Series
Conditions of Soldering
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
7/8
PJ75ALXXSA Series
Package Specifications
The method of packaging
3,000 pcs per reel
SOT-23
Cover Tape
Carrier Tape
24,000 pcs per box
8 reels per box
18
5
104
120,000 pcs per carton
5 boxes per carton
185
2. Tape and reel data(7inch Units:mm)
D
A
3000
T2
T1
2900
2000
1900
1000
600
B
C
E
PS
F
Reel (7'')
4.0±0.1
1Pin
N
Tape (8mm)
8.0±0.1
3.5±0.05
4.0±0.1
G
Symbol
A
B
C
E
F
D
T1
T2
N
G
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
3.15±0.1
1.22±0.1
8/8
很抱歉,暂时无法提供与“PJ75AL33SA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.46397
- 200+0.37217
- 600+0.32638
- 3000+0.25618
- 9000+0.22864
- 21000+0.21492
