HL-304IR3C-L3
HL-304IR3C-L3
    HONGLITRONIC(鸿利光电)
    LED_D3X5.3MM_TM
    波长:940nm 3MM 白透明 红外发射管、波长:940nm 材质:金线,焊脚镀金
HL-304IR3C-L3 数据手册
HL-304IR3C-L3 HL-304IR3C-L3 Features •Mechanically and spectrally matchend to the phototransistor. •Rohs compliant. Package Dimensions Description This devices are made with PIN GaAs. 3.85 5.3 2.54 0.5 2.94 1 29.0 1.5MAX 2 2 1 3 1 1.5 Dimension Tolerance (UNIT:mm) Tolerance Grade 0.5~3 3~6 6~30 30~120 ±0.1 ±0.2 ±0.3 ±0.5 Chip SPEC NO: Lens Color Material Emitting Color GaAs / REV NO:A/2 Water Clear DATE:Mar/08/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 ÿwww.fineprint.com.cn PAGE:1/4 HL-304IR3C-L3 Selection Guide Radiant Intensity(mW/sr) IF=50mA Part No HL-304IR3C-L3 Viewing Angle Min Typ 2θ1/2 (供参考) -- 26 40 Note: 1. 2θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline value. 2.Tolerance of measurement of luminous intensity±15%. Electrical / Optical Characteristics at TA=25°C Item Symbol Min Typ Units Forward Voltage VF 1.2 1.5 V Reverse Current IR -- 10 uA λD -- 940 nm Δλ1/2 -- 50 nm Test Conditions IF=50mA Peak Spectral Wavelength Spectral Bandwidth Note: 1.Tolerance of measurement of forward voltage±0.1V. 2.Tolerance of measurement of peak Wavelength±2.0nm. Absolute Maximum ratings at Ta=25℃ Parameter Symbol IR1 Units Power Dissipation Pt 100 mW DC Forward Current IF 50 mA Peak Forward Current[1] IFS 300 mA Operating Temperature -30℃~80℃ Storage Temperature -30℃~80℃ Note: 1.IFP Conditions:Pulse Width≤10msec 2.Tsol Conditions:3mm from the base of the epoxy bulb SPEC NO: REV NO:A/2 DATE:Mar/08/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 www.fineprint.com.cn PAGE:2/4 HL-304IR3C-L3 RELATIVE RADIANT INTENSITY 100 80 60 IR1 40 20 0 600 700 900 800 1000 WAVELENGTH λ(nm) Forward Current vs.Forward Voltage 0° 10° 20° Relative Radaint Power 2.0 30° 1.5 40° 1.0 1.0 50° 0.5 0.9 0.8 0.7 60° 70° 80° 90° 0 -40 -20 0 20 40 60 0.5 0.3 0.1 0.2 0.4 0.6 80 Ambient Temperature Ta(℃) Spatial Distribution Radint Power Vs.Ambient Temperature 3.0 Radiant Power Relative Value at IF=20mA Forward Current If(mA) 60 50 40 30 20 10 0 0.8 1.0 1.2 1.4 1.6 1.8 Forward Voltage VF(V) 2.0 2.5 2.0 1.5 1.0 0.5 0 0 10 20 30 40 50 60 If-Forward current (mA) Remarks: If special sorting is required (e.g.binning based on forward voltage or radiant intensity/luminous flux),the typical accuracy of the sorting process is as follows: 1. Radiant intensity/Luminous Flux:±15%. 2. Forward Voltage:±0.1V. Note:Accuracy may depend on the sorting parameters. SPEC NO: REV NO:A/2 DATE:Mar/08/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 www.fineprint.com.cn PAGE:3/4 HL-304IR3C-L3 Soldering: 1. Manual Of Soldering The temperature of the iron tip should not be higher than 300℃and Soldering within 3 seconds per solder-land is to be observed. 2. DIP soldering (Wave Soldering): Preheating:120℃~150℃,within 120~180 sec. Operation heating:245℃±5℃ within 5 sec.260℃(Max) Gradual Cooling (Avoid quenching). SPEC NO: REV NO:A/2 DATE:Mar/08/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 ÿwww.fineprint.com.cn PAGE:4/4
HL-304IR3C-L3 价格&库存
很抱歉,暂时无法提供与“HL-304IR3C-L3”相匹配的价格&库存,您可以联系我们找货
HL-304IR3C-L3
  • 10+0.27900
  • 100+0.26100
  • 500+0.24300
  • 2000+0.21600
  • 5000+0.20700
  • 10000+0.20160
库存:660
