Positive Thermal Coefficient (PTC)
RLVR240 Series
Description
Positive Thermal Coefficient devices(PTC),provide over-current
protection for electrical and electronic devices. They function
using conducting strips of metal imbedded inside polymers.
Under normal conditions, the devices resistance is near zero,
but over-current conditions will heat the PTC and expand the
polymer, increasing the impedance. When current returns to
normal, the components cool down, returning to their original
shape and very low levels of resistance.
Applications
l Over-current and over-temperature protection of
Features
automotive electronics
l I(hold): 0.05~2.0A
l Hard disk drives
l 240V Operating voltages
l PC motherboards
l Radial leaded devices.
l Point-of-sale (POS) equipment
l Over-current protection
l PCMCIA cards
l Very high voltage surge capabilities.
l USB port protection - USB 2.0, 3.0 & OTG
l Available in lead-free version.
l HDMI 1.4 Source protection
l Fast time–to–trip
l Computers & peripherals
l RoHS compliant, Lead- Free and Halogen-Free
l Industrial control
l Security systems
Part Number Code
R
L
LOGO
R
V
X
AC
X
X
Voltage rating(VDC)
X
X
X
Hold current
Environmental Specifications
Test
Conditions
Resistance change
Passive aging
+85℃,1000hrs
±8% typical
Humidity aging
+85℃,85%R.H.1000hrs
±8% typical
Thermal shock
+125℃ to -55℃,10times
±12% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
Vibration
MIL-STD-202,Method 201
No change
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2018-08-31
Page:1
RLVR240 Series
Electrical Characteristic
Ihold
(A)
IT
(A)
Vmax
(V)
RLVR240-005
0.05
0.12
RLVR240-008
0.08
RLVR240-012
Model
Maximum Time to Trip
Imax
(A)
Pd typ
(W)
Current(A)
Time(S)
AC240
0.25
15
1.0
0.19
AC240
0.40
15
0.12
0.30
AC240
0.60
RLVR240-016
0.16
0.37
AC240
RLVR240-025
0.25
0.56
RLVR240-033
0.33
RLVR240-040
Resistance(Ω)
Rimin
R1max
0.3
18.00
50.00
1.2
0.51
7.40
20.00
15
1.2
0.6
3.00
12.00
0.80
15
2.0
0.52
2.50
7.80
AC240
1.25
18.5
3.5
0.52
1.30
4.00
0.74
AC240
1.65
21
4.5
0.59
1.20
3.50
0.40
0.90
AC240
2.00
24
5.5
0.66
0.81
2.50
RLVR240-055
0.55
1.25
AC240
2.75
26
7.0
0.80
0.45
1.45
RLVR240-075
0.75
1.50
AC240
3.75
14
7.5
0.90
0.40
1.10
RLVR240-100
1.00
2.00
AC240
5.00
13.6
10.0
0.95
0.20
0.60
RLVR240-125
1.25
2.50
AC240
6.25
18
12.5
1.0
0.12
0.32
RLVR240-135
1.35
2.70
AC240
6.75
1.51
0.10
0.30
RLVR240-200
2.00
4.20
AC240
10.00
36
20.0
1.71
0.089
0.22
IH=Hold current: maximum current at which the device will not trip at 25℃ still air.
IT=Trip current: minimum current at which the device will nalways at 25℃ still air.
V max=Maximum voltage device can withstand without damage at rated current.
Imax=Maximum fault current device can withstand tithout damage at rated voltage.
T trip=Maximum time to trip(s) at assigned current.
Pd=Typical power dissipation: typical amount of power dissipated by the decice when in state air environment.
Ri min=Minimum device resistance at 25℃ prior to tripping.
R1 max=Maximum device resistance is measured one hour post reflow.
Solder reflow conditions
Wave Soldering
300
Soldering Temperature:260℃~270℃
250
Soldering Time:≤3sec.
200
Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。
Manual soldering
Soldering Temperature:250℃~280℃
Temperature℃
5s max.
245℃-260
Soldering
Pre-heating
150
100℃-130℃
100
Cooling
50
100
150
200
250
Time(s)
Revised: 2018-08-31
Page:2
RLVR240 Series
Environmental temperature and IH,IT
300
250
200
150
100
IT
50
IH
-20
-10
40
50
60
70
80
85
Product Dimensions
Marking
Marking
Marking
fig.1
fig.2
fig.3
Dimensions(mm)
Type Number
Dimensions(in)
A(max)
B(max)
C(typ)
D(max)
LeadΦ
(typ)
Fig
0.5
0.327
0.508
0.201
0.15
0.02
1
3.8
0.5
0.327
0.421
0.201
0.15
0.02
1
5.1
3.8
0.5
0.327
0.421
0.201
0.15
0.02
1
13.8
5.1
3.8
0.6
0.390
0.543
0.201
0.15
0.024
1
9.6
18.8
5.1
3.8
0.6
0.378
0.740
0.201
0.15
0.024
3
RLVR240-033
12.5
19.0
5.1
3.8
0.8
0.449
0.748
0.201
0.15
0.031
2
RLVR240-040
11.5
20.9
5.1
3.8
0.8
0.453
0.823
0.201
0.15
0.031
2
RLVR240-055
14.0
22.4
5.1
3.8
0.8
0.551
0.882
0.201
0.15
0.031
2
RLVR240-075
12.5
23.4
5.1
3.8
0.8
0.492
0.921
0.201
0.15
0.031
2
RLVR240-100
14.0
20.1
10.2
4.1
0.8
0.551
0.791
0.402
0.161
0.031
1
RLVR240-125
14.0
21.7
5.1
4.1
0.8
0.551
0.854
0.201
0.161
0.031
2
RLVR240-135
16.3
21.7
5.1
4.1
0.8
0.642
0.854
0.201
0.161
0.031
2
RLVR240-200
23.5
31.8
10.2
4.1
0.8
0.925
1.252
0.402
0.161
0.031
2
A(max)
B(max)
C(typ)
D(max)
RLVR240-005
8.3
12.9
5.1
3.8
RLVR240-008
8.3
10.7
5.1
RLVR240-012
8.3
10.7
RLVR240-016
9.9
RLVR240-025
LeadΦ
(typ)
Shape
Packaging
Part Number
Quantity
RLVR240-005~RLVR240-200
500pcs/bag
Revised: 2018-08-31
Page:3
很抱歉,暂时无法提供与“RLVR240-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.47460
- 50+1.13120
- 500+1.05040
- 国内价格
- 5+2.56100
- 50+1.97927
- 150+1.72995
- 500+1.29400
- 2500+1.15549
- 5000+1.07238
