SOT-89 Encapsulate Three terminal voltage regulators
79L09U
SOT-89 Plastic Package
Three-terminal negative voltage regulator
FEATURES
Maximum output current
IOM: 0.1 A
Output voltage
Vo: - 9 V
Continuous total dissipation
PD: 0.5W
1. GND
2. IN
3. OUT
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Parameter
Symbol
Value
Unit
Vl
-30
V
Input Voltage
Operating Junction Temperature Range
TOPR
0─+150
Storage Temperature Range
TSTG
-55─+150
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JINCTION TEMPERATURE (Vi=-16V,Io=40mA,Ci=0.33μF,Co=0.1μF, unless otherwise specified )
Parameter
Symbol
Test conditions
Min
25℃
Output Voltage
Vo
-12V≤V l≤-24V, Io=1mA-40mA
0-125℃
Io=1mA-70mA
Load Regulation
△Vo
Line Regulation
△Vo
Quiescent Current
Iq
Typ
Max
Unit
-8.64
-9.0
-9.36
V
-8.55
-9.0
-9.45
V
-8.55
-9.0
-9.45
V
Io=1mA-100mA
25℃
19
90
mV
Io=1mA-40mA
25℃
11
40
mV
-12 V≤Vl≤-24V
25℃
45
175
mV
-13V≤Vl≤-24V
25℃
40
125
mV
25℃
4.1
6.0
mA
△Iq
-13V≤V l≤-24V
0-125℃
1.5
mA
△Iq
1mA≤V l≤40mA
0-125℃
0.1
mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
25℃
58
uV
Ripple Rejection
RR
-15V≤Vl≤-24V,f=120Hz
0-125℃
45
dB
Dropout Voltage
Vd
25℃
1.7
V
Quiescent Current Change
TYPICAL APPLICATION
Vi
2
3
Vo
UTC
79L 09U
Ci
0.33μF
1
C0
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
possible to the regulators
Page 1 of 2
9/26/2013
79L09U
SOT-89 PACKAGE OUTLINE
Page 2 of 2
9/26/2013
很抱歉,暂时无法提供与“79L09U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41073
- 100+0.33146
- 300+0.29193
- 1000+0.22972
- 5000+0.20596
- 10000+0.19408
