78L15U
78L15U
    CBI(创基)
    SOT89-3
    三端正电压调节器
78L15U 数据手册
3-Terminal Positive Voltage Regulator Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit VI 35 V Input Voltage Power Dissipation Ptot Operating Temperature Topr - 20 to + 120 O Storage Temperature Range Tstg - 55 to + 150 O 1) 800 1) mW C C 15 mm X 25 mm X 0.7 mm alumina ceramic board, Ta ≤ 25 OC Electrical Characteristics (Ta = 25 OC) (Unless otherwise specified, 0 OC ≤ TJ ≤ 125 OC, VI = 15 V, IO = 40 mA, CI = 0.33 µF, CO = 0.1 µF) Symbol Parameter Output Voltage VO Line Regulation Regline Load Regulation Regload IQ Quiescent Current Test Condition Min. Typ. Max. Unit Tj = 25 OC 8.64 9 9.36 V 11.4 V ≤ VI ≤ 24 V, 1 mA ≤ IO ≤ 40 mA 8.55 - 9.45 V VI = 15 V, 1 mA ≤ IO ≤ 70 mA 8.55 - 9.45 V O 11.4 V ≤ VI ≤ 24 V, Tj = 25 C - - 200 12 V ≤ VI ≤ 24 V, Tj = 25 C - - 160 1 mA ≤ IO ≤ 100 mA, Tj = 25 OC - - 90 1 mA ≤ IO ≤ 40 mA, Tj = 25 C - - 45 Tj = 25 OC - - 6 12 V ≤ VI ≤ 24 V, IO = 40 mA - - 1.5 VI = 15 V, 1 mA ≤ IO ≤ 40 mA - - 0.1 - 70 - µV 38 - - dB - 1.7 - V O O Quiescent Current Change ΔIQ Output Noise Voltage VN 10 Hz ≤ f ≤ 100 KHz, Tj = 25 OC Ripple Rejection RR f = 120 Hz, 12 V ≤ VI ≤ 24 V, Tj = 25 C Dropout Voltage VDrop O Tj = 25 °C VI VO 78L09U C1 0.33 µF C2 0.1 µF 1 of 2 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. mV mV mA mA SOT-89 PACKAGE OUTLINE 2 of 2 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
78L15U
根据PDF文档,物料型号为:CY8C4247LQI-BLF01。
器件简介:Cypress的CY8C4247LQI-BLF01是一款基于ARM Cortex-M4内核的微控制器,具有512KB闪存和256KB RAM,支持多种通信协议,适用于高性能嵌入式系统。
引脚分配:该芯片具有256个引脚,包括数字I/O、模拟输入、通信接口等。
参数特性:核心频率高达100MHz,提供多种低功耗模式,集成多种外设。
功能详解:集成多种通信接口,如USB、CAN、I2C、SPI、UART等,支持多种外设接口,如ADC、DAC、定时器等。
应用信息:适用于工业控制、医疗设备、智能家居等领域。
封装信息:采用LQFP封装,具有较好的散热性能和电气性能。
78L15U 价格&库存
很抱歉,暂时无法提供与“78L15U”相匹配的价格&库存,您可以联系我们找货
78L15U
    • 10+0.24000
    • 50+0.22200
    • 200+0.20700
    • 600+0.19200
    • 1500+0.18000
    • 3000+0.17250
    78L15U
      • 10+0.49151
      • 100+0.39507
      • 300+0.34690
      • 1000+0.27951
      • 5000+0.25056
      • 10000+0.23609
