2N3904U
2N3904U
    CBI(创基)
    SOT89-3
    塑封晶体管
2N3904U 数据手册
Plastic-Encapsulate Transistors TRANSISTOR (NPN) FEATURES z Compliment to 2N3906 U z Low current z Low voltage MARKING: 1A MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 60 VCEO Collector-Emitter Voltage 40 V VEBO Emitter-Base Voltage 6 V IC Collector Current -Continuous 0.2 A V PC Collector Power Dissipation 0.5 W TJ Junction Temperature 150 ℃ Tstg Storage Temperature -55~150 ℃ ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=10μA,IE=0 60 Collector-emitter breakdown voltage V(BR)CEO IC=1mA,IB=0 40 V Emitter-base breakdown voltage V(BR)EBO IE=10μA,IC=0 6 V Collector cut-off current ICBO VCB=30V,IE=0 Emitter cut-off current IEBO VEB=6V,IC=0 0.05 μA Collector ut-off current ICEX hFE(1) VCE=30V,VBE(off)=3V VCE=1V,IC=0.1mA 0.05 μA hFE(2) VCE=1V,IC=1mA 80 hFE(3) VCE=1V,IC=10mA 100 hFE(4) VCE=1V,IC=50mA 60 30 DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage Transition frequency hFE(5) VCE=1V,IC=100mA VCE(sat)1 IC=10mA,IB=1mA VCE(sat)2 IC=50mA,IB=5mA VBE(sat)1 IC=10mA,IB=1mA VBE(sat)2 IC=50mA,IB=5mA V 0.05 μA 60 0.65 300 0.2 V 0.3 V 0.85 V 0.95 VCE=20V,IC=10mA,f=100MHz Collector capacitance Cc VCB=5V,IE=0,f=1MHz 4 pF Emitter capacitance Ce VEB=0.5V,IC=0,f=1MHz 8 pF Noise figure NF VCE=5V,Ic=0.1mA,f=10Hz-15.7kHz, RS=1KΩ 5 dB 35 ns Delay time 300 V fT td Rise time tr Storage time tS Fall time tf IC=10mA , IB1=-IB2= 1mA 1 of 2 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. MHz 35 ns 200 ns 50 ns SOT-89 PACKAGE OUTLINE 2 of 2 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
2N3904U
PDF文档中包含的物料型号为:SN65HVD230。
器件简介指出,SN65HVD230是一款高速CAN收发器,适用于汽车网络。
引脚分配如下:TXD和RXD为数据发送和接收引脚,CANH和CANL为高速CAN差分信号引脚,VCC和GND为电源和地引脚。
参数特性包括高速CAN速率最高至1Mbps,工作电压范围为4.75V至5.25V。
功能详解说明,该器件支持CAN协议,具有自动唤醒和睡眠模式,以及增强的电磁兼容性能。
应用信息显示,它适用于汽车网络、工业控制和楼宇自动化等领域。
封装信息为SOIC-8封装。
2N3904U 价格&库存
很抱歉,暂时无法提供与“2N3904U”相匹配的价格&库存,您可以联系我们找货
2N3904U
  • 20+0.32680
  • 100+0.19500
  • 500+0.13650
  • 1000+0.09750
  • 2000+0.09270
  • 10000+0.08580
库存:136
2N3904U
  • 1+0.19690
  • 50+0.09845
  • 1000+0.07458
库存:136
2N3904U
    • 20+0.15773
    • 100+0.15536
    • 400+0.12248
    • 1000+0.10258
    库存:800
    2N3904U
    • 20+0.18296
    • 200+0.14213
    • 1000+0.11902
    • 2000+0.10541
    • 10000+0.09364
    • 20000+0.08727
    库存:1447
