1N4448WS
1N4448WS
    CBI(创基)
    SOD-323
    二极管配置:独立式 功率:200mW 直流反向耐压(Vr):80V 平均整流电流(Io):150mA 正向压降(Vf):1.25V@150mA 反向电流(Ir):100nA@80V 反向恢复时间(tr...
1N4448WS 数据手册
Silicon Epitaxial Planar Switching Diode Fast Switching Diode PINNING DESCRIPTION PIN 1 Cathode 2 Anode 2 1 T4 Top View Marking Code: " T4 " Simplified outline SOD-323 and symbol Absolute Maximum Ratings (Ta = 25 C) O Parameter Symbol Value Unit Peak Reverse Voltage VRM 100 V Reverse Voltage VR 80 V IF(AV) 150 mA Forward Continuous Current IFM 300 mA Non-Repetitive Peak Forward Surge Current (at t = 1 µs) IFSM 0.5 A Power Dissipation Pd 200 mW Junction Temperature Tj 150 O Tstg - 65 to + 150 O Average Rectified Forward Current Storage Temperature Range C C Characteristics at Ta = 25 C O Parameter Forward Voltage at IF = 5 mA at IF = 10 mA at IF = 100 mA at IF = 150 mA Reverse Leakage Current at VR = 80 V at VR = 20 V at VR = 75 V, TJ = 150 OC at VR = 25 V, TJ = 150 OC Symbol Min. Max. Unit VF 0.62 - 0.72 0.855 1 1.25 V - 100 25 50 30 nA nA µA µA V(BR)R 80 - V Ctot - 4 pF trr - 4 ns IR Reverse Breakdown Voltage at IR = 100 µA Total Capacitance at VR = 0.5 V, f = 1 MHz Reverse Recovery Time at IF = IR = 10 mA, Irr = 0.1 X IR , RL = 100 Ω 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-323 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
1N4448WS 价格&库存
很抱歉,暂时无法提供与“1N4448WS”相匹配的价格&库存,您可以联系我们找货
1N4448WS
    • 50+0.08230
    • 500+0.06362
    • 3000+0.05325
    • 6000+0.04709
    • 24000+0.04169
    • 51000+0.03878
    库存:5557
