1N914W
1N914W
    CBI(创基)
    SOD-123
    硅外延平面开关二极管
1N914W 数据手册
Silicon Epitaxial Planar Switching Diode PINNING PIN DESCRIPTION 1 Cathode 2 Anode 2 1 W1 Top View Marking Code: " W1" or "WJ" Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Repetitive Reverse Voltage VRRM 100 V Average Rectified Forward Current IF(AV) 200 mA IFSM A Non-repetitive Peak Forward Surge Current at t = 1 s at t = 1 μs Power Dissipation Ptot 1 2 400 Thermal Resistance from Junction to Ambient Air RθJA 312 Tj 150 O Tstg - 55 to + 150 O Junction Temperature Storage Temperature Range mW C/W O C C Electrical Characteristics (Ta = 25 OC) Parameter Forward Voltage at IF = 10 mA Reverse Breakdown Voltage at IR = 5 µA at IR = 100 µA Reverse Current at VR = 20 V at VR = 75 V at VR = 20 V, Tj = 150 OC Capacitance at VR = 0 V, f = 1 MHz Reverse Recovery Time at IF = IR = 30 mA, Irr = 3 mA, RL = 100 Ω Symbol Min. Max. Unit VF - 1 V V(BR)R V(BR)R 75 100 - V V IR - 25 5 50 nA µA µA Ctot - 4 pF trr - 50 ns 1 of 2 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 2 of 2 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
1N914W 价格&库存
很抱歉,暂时无法提供与“1N914W”相匹配的价格&库存,您可以联系我们找货
1N914W
    • 50+0.05805
    • 600+0.04517
    • 1200+0.04449
    • 3000+0.03901
    库存:1880
    1N914W
      • 20+0.08610
      • 100+0.05340
      • 800+0.03530
      • 3000+0.02520
      • 6000+0.02390
      • 30000+0.02220
      库存:356
      1N914W
        • 50+0.07161
        • 500+0.05649
        • 3000+0.04644
        • 6000+0.04137
        • 24000+0.03694
        • 51000+0.03456
        库存:12692
        1N914W
        • 1+0.11660
        • 200+0.03883
        • 1500+0.02420
        • 3000+0.01925
        库存:328
