Plastic-Encapsulate Transistors
DUAL TRANSISTOR (NPN+NPN)
SOT-363
APPLICATION
This device is designed for general purpose amplifier applications
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Value
Parameter
VCBO
Collector-Base Voltage
50
VCEO
Collector-Emitter Voltage
45
VEBO
Emitter-Base Voltage
Unit
V
6
IC
Collector Current-Continuous
100
mA
PD
Power Dissipation
200
mW
Thermal Resistance. Junction to Ambient
625
℃/W
Junction Temperature
150
RθJA
Tj
Tstg
Storage Temperature Range
-55~+150
MARKING:BC847ADW 1Et
BC847BDW 1Ft
BC847CDW 1Gt
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Collector-base breakdown voltage
V(BR)CBO
IC=10µA,IE=0
50
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=1mA,IB=0
45
V
Emitter-base breakdown voltage
V(BR)EBO
IE=10µA,IC=0
6
V
Collector cut-off current
ICBO
VCB=30V,IE=0
15
Emitter cut-off current
IEBO
VEB =4V, IC=0
15
DC current gain*
hFE
VCE=5V,IC=2mA
Base-emitter voltage
Min
Typ
A
110
220
B
200
450
C
420
800
nA
VCE(sat)(1)
IC=10mA,IB=0.5mA
0.25
V
VCE(sat)(2)
IC=100mA,IB=5mA
0.65
V
0.7
V
0.77
V
VBE(1)
VCE=5V,IC=2mA
VBE(2)
VCE=5V,IC=10mA
fT
Transition frequency
Collector output capacitance
conditions
Unit
Symbol
Collector-emitter saturation voltage
Test
Max
Parameter
Cob
VCE=5V,IC=20mA ,f=100MHz
VCB=10V,IE=0,f=1MHz
0.58
200
MHz
2
pF
*pulse test: Pulse Width ≤300μs, Duty Cycle≤ 2.0%.
1 of 2
Copyright © All right reserved
Heyuan China Base Electronics Technology Co., Ltd.
SOT-363-Package Outline Dimensions
Dimension in Millimeters
Symbol
Min
Max
A
0.90
1.00
A1
0.010
0.100
B
1.20
1.40
bp
0.25
0.45
C
0.09
0.15
D
2.00
2.20
E
1.15
1.35
HE
2.15
2.55
Lp
0.25
0.46
θ
0º
6º
2 of 2
很抱歉,暂时无法提供与“BC847DW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23296
- 200+0.19397
- 600+0.17226
- 3000+0.14894
- 9000+0.13770
- 21000+0.13155
- 国内价格
- 10+0.12160
- 50+0.11248
- 200+0.10488
- 600+0.09728
- 1500+0.09120
- 3000+0.08740
