Plastic-Encapsulate Transistors
DUAL TRANSISTOR (PNP+PNP)
SOT-363
FEATURES
Two transistors in one package
z
z
Reduces number of components and board space
No mutual interference between the transistors
z
MARKING: 3C
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Units
VCBO
Collector- Base Voltage
-50
V
VCEO
Collector-Emitter Voltage
-45
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-0.2
A
PC
Collector Power Dissipation
0.3
W
RθJA
Thermal Resistance from Junction to Ambient
417
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55-150
stg
℃/W
ELECTRICAL CHARACTERISTICS(Ta= 25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
M ax
Unit
Collector-base breakdown voltage
V(BR)CBO
Ic=-10µA,IE=0
-50
V
Collector-emitter breakdown voltage
V(BR)CEO
Ic=-10mA,IB=0
-45
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10µA,IC=0
-5
V
Collector cut-off current
ICBO
VCB=-30V,IE=0
DC current gain
hFE
VCE=-5V,IC=-2mA
-15
125
nA
630
VCE(sat)(1)
IC=-10mA,IB=-0.5mA
-0.3
V
VCE(sat)(2)
IC=-100mA,IB=-5mA
-0.65
V
-0.75
V
-0.82
V
Collector-emitter saturation voltage
VBE(1)
VCE=-5V,IC=-2mA
VBE(2)
VCE=-5V,IC=-10mA
-0.6
Base-emitter voltage
Transition frequency
fT
Collector output capacitance
Cob
Noise figure
NF
VCE=-5V,IC=-10mA,f=100MHz
200
MHz
VCB=-10V,IE=0,f=1MHz
3.5
pF
2.5
dB
VCE=-5V,Ic=-0.2mA,
f=1kHZ,Rs=2KΩ,BW=200Hz
1 of 3
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
Typical Characteristics
hFE
Static Characteristic
COMMON
EMITTER
Ta=25℃
Ta=100℃
-27uA
-6
hFE
(mA)
-30uA
-24uA
IC
-21uA
DC CURRENT GAIN
COLLECTOR CURRENT
—— IC
1000
-8
-18uA
-4
-15uA
-12uA
-9uA
-2
Ta=25℃
100
-6uA
COMMON EMITTER
VCE= -5V
IB=-3uA
10
-0.1
-0
-0
-2
-4
-6
COLLECTOR-EMITTER VOLTAGE
VCEsat
VCE
-8
-10
COLLECTOR CURRENT
IC
VBEsat
-1
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
-1
(V)
IC
-100
(mA)
IC
-2
-1
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
Ta=25℃
-0.1
Ta=100℃
Ta=25℃
Ta=100℃
β=20
β=20
-0.01
-0.1
-1
-10
COLLECTOR CURRENT
IC
IC
-0.1
-0.1
-100
(mA)
—— VBE
fT
IC
-100
(mA)
IC
(MHz)
500
(mA)
fT
Ta=100℃
-10
TRANSITION FREQUENCY
IC
-10
COLLECTOR CURRENT
-100
COLLECTOR CURRENT
-1
Ta=25℃
-1
COMMON EMITTER
VCE=-5V
-0.1
-0.0
-0.3
-0.6
-0.9
100
COMMON EMITTER
VCE=-5V
Ta=25℃
10
-0.1
-1.2
-1
BASE-EMMITER VOLTAGE VBE (V)
Cob/ Cib
-10
COLLECTOR CURRENT
—— VCB/ VEB
PC
IC
-100
(mA)
Ta
400
30
f=1MHz
IE=0/IC=0
COLLECTOR POWER DISSIPATION
PC (mW)
Cib
10
C
(pF)
Ta=25 ℃
CAPACITANCE
Cob
1
-0.1
300
200
100
REVERSE VOLTAGE
-10
VR
-20
(V)
25
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
2 of 3
a
SOT-363-Package Outline Dimensions
3 of 3
很抱歉,暂时无法提供与“BC857DW”相匹配的价格&库存,您可以联系我们找货
