Plastic-Encapsulate Transistors
TRANSISTOR
(PNP)
FEATURES
y
Ideally suited for automatic insertion
y
For Switching and AF Amplifier Applications
SOT-323
1. BASE
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Value
Parameter
2. EMITTER
Unit
3. COLLECTOR
Collector-Base Voltage
VCBO
BC856W
-80
BC857W
-50
BC858W
-30
V
Collector-Emitter Voltage
VCEO
VEBO
IC
BC856W
-65
BC857W
-45
BC858W
-30
Emitter-Base Voltage
V
-5
V
Collector Current –Continuous
-0.1
A
PC*
Collector Power Dissipation
150
mW
TJ
Junction Temperature
150
Tstg
Storage Temperature
-65-150
DEVICE MARKING
BC856AW= 3A; BC856BW= 3B;
BC857AW=3E; BC857BW=3F;BC857CW=3G;
BC858AW=3J; BC858BW=3K; BC858CW=3L
1 of 4
Copyright © All right reserved:
Heyuan China Base Electronics Technology Co., Ltd.
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Symbol
Parameter
Collector-base breakdown voltage
BC856W
BC857W
Collector-emitter breakdown voltage
T est conditions
VCBO
IC= -10μA, IE=0
Unit
BC856W
-65
VCEO
IC= -10mA, IB=0
BC858W
V
-50
BC858W
-45
V
-30
Emitter-base breakdown voltage
VEBO
IE= -1μA, IC=0
Collector cut-off current
ICBO
VCB= -30 V , IE=0
BC856AW, 857AW,858AW
BC856BW, 857BW,858BW
Max
-80
-30
BC857W
DC current gain
Min
hFE
VCE= -5V, IC= -2mA
BC857CW,BC858CW
-5
V
-15
125
250
220
475
420
800
nA
Collector-emitter saturation voltage
VCE(sat)
IC=-100mA, IB= -5mA
-0.65
V
Base-emitter saturation voltage
VBE(sat)
IC= -100mA, IB= -5mA
-1.1
V
Transition frequency
fT
Collector capacitance
Cob
VCE= -5V, IC= -10mA
f=100MHz
100
VCB=-10V, f=1MHz
2 of 4
MHz
4.5
pF
Static Characteristic
(mA)
-20uA
DC CURRENT GAIN
IC
-16uA
-14uA
-4
COLLECTOR CURRENT
VCE=-5V
COMMON
EMITTER
Ta=25℃
-18uA
-5
-12uA
-3
hFE —— IC
500
hFE
-6
-10uA
-8uA
-2
400
Ta=100℃
300
Ta=25℃
200
-6uA
-4uA
-1
100
IB=-2uA
-0
-2
-4
-6
-8
COLLECTOR-EMITTER VOLTAGE
-1
-10
(V)
IC
VBEsat ——
-1000
VCE
-10
-100
COLLECTOR CURRENT
IC
VCEsat ——
IC
-1000
(mA)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
β=20
-800
Ta=25℃
-600
Ta=100℃
-400
-200
Ta=100℃
-100
Ta=25℃
β=20
-0
-0.1
-1
-10
COLLECTOR CURRENT
15
Cob / Cib
IC
VCB / VEB
COLLECTOR POWER DISSIPATION
PC (mW)
(pF)
PC
180
Ta=25℃
Cib
C
CAPACITANCE
-10
COLLECTOR CURRENT
12
9
Cob
3
-1
(mA)
f=1MHz
IE=0/IC=0
6
-10
-0.1
-100
IC
-100
(mA)
Ta
150
120
90
60
30
REVERSE BIAS VOLTAGE
V
(V)
25
50
75
100
AMBIENT TEMPERATURE
Ta
3 of 4
125
150
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
SOT-323
4 of 4
很抱歉,暂时无法提供与“BC857BW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.06880
- 50+0.06364
- 200+0.05934
- 600+0.05504
- 1500+0.05160
- 3000+0.04945
- 国内价格
- 50+0.11515
- 500+0.08122
- 3000+0.06109
- 6000+0.05444
- 24000+0.04872
- 51000+0.04564
