SILICON PLANAR ZENER DIODES
PINNING
Features
PIN
• Standard Zener Breakdown Voltage Range
2.0 V to 75 V
DESCRIPTION
1
Cathode
2
Anode
• Steady State Power Rating of 200 mW
1
2
Top View
Simplified outline SOD-523 and symbol
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Total Device Dissipaton
Junction and Storage Temperature Range
Symbol
Value
Unit
Ptot
200
mW
Tj , Tstg
- 65 to + 150
Symbol
Max.
VF
0.9
C
O
Characteristics at Ta = 25 OC
Parameter
Forward Voltage
at IF = 10 mA
1 of 4
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
Unit
V
MM5Z2V0~MM5Z75
Type
Zener Voltage
Marking
Code
1)
VZT (V)
Zener Impedance
at lZT
ZZT
ZZK
Leakage Current
at IZK
IR
at VR
Min.
Nom.
Max.
mA
Ω
Ω
mA
µA
V
MM5Z2V0
RD
1.8
2.0
2.15
5
100
120
0.5
MM5Z2V2
RE
2.08
2.2
2.33
5
100
120
0.7
MM5Z2V4
Z7
2.2
2.4
2.6
5
100
1000
1
120
1
MM5Z2V7
A8
2.5
2.7
2.9
5
100
1000
1
120
1
MM5Z3V0
B8
2.8
3.0
3.2
5
100
1000
1
50
1
MM5Z3V3
C8
3.1
3.3
3.5
5
95
1000
1
MM5Z3V6
D8
3.4
3.6
3.8
5
90
1000
1
10
1
MM5Z3V9
E8
3.7
3.9
4.1
5
90
1000
1
5
1
MM5Z4V3
F8
4
4.3
4.6
5
90
1000
1
5
1
MM5Z4V7
G8
4.4
4.7
5
5
80
800
1
2
1
MM5Z5V1
H8
4.8
5.1
5.4
5
60
500
1
2
1.5
MM5Z5V6
I8
5.2
5.6
6
5
40
200
1
1
2.5
MM5Z6V2
J8
5.8
6.2
6.6
5
10
100
1
1
3
MM5Z6V8
K8
6.4
6.8
7.2
5
15
160
1
0.5
3.5
MM5Z7V5
L8
7
7.5
7.9
5
15
160
1
0.5
4
MM5Z8V2
M8
7.7
8.2
8.7
5
15
160
1
0.5
5
MM5Z9V1
N8
8.5
9.1
9.6
5
15
160
1
0.5
6
MM5Z10
O8
9.4
10
10.6
5
1
0.1
7
MM5Z11
P8
10.4
11
11.6
5
1
0.1
8
MM5Z12
Q8
11.4
12
12.7
5
25
80
1
0.1
9
MM5Z13
R8
12.4
13
14.1
5
30
80
1
0.1
10
MM5Z15
S8
14.3
15
15.8
5
30
80
1
0.1
11
MM5Z16
T8
15.3
16
17.1
2
40
80
1
0.1
12
MM5Z18
U8
16.8
18
19.1
2
45
80
1
0.1
13
MM5Z20
V8
18.8
2
55
100
1
0.1
15
MM5Z22
W8
20.8
22
23.3
2
55
100
1
0.1
17
MM5Z24
X8
22.8
24
25.6
2
70
120
1
0.1
19
MM5Z27
Y8
25.1
27
28.9
2
80
300
1
0.1
21
MM5Z30
Z8
28
30
32
2
80
300
1
0.1
23
MM5Z33
A9
31
33
35
2
80
300
1
0.1
25
MM5Z36
B9
34
36
38
2
90
500
1
0.1
27
MM5Z39
C9
37
39
41
2
130
500
1
2
30
MM5Z43
D9
40
43
46
1
150
500
1
2
33
MM5Z47
E9
44
47
50
1
170
500
1
2
36
MM5Z51
F9
48
51
54
1
180
500
1
1
39
MM5Z56
G9
52
56
60
1
200
500
1
1
43
MM5Z62
H9
58
62
66
1
215
500
1
0.2
47
MM5Z68
I9
64
68
72
1
240
500
1
0.2
52
MM5Z75
J9
70
75
79
1
255
500
1
0.2
57
1)
Tested with pulses tp = 20 ms.
2 of 4
MM5Z2V0~MM5Z75
Power Dissipation: Ptot (mW)
300
200
100
100
Ambient Temperature: Ta ( C)
O
Derating Curve
3 of 4
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-523
4 of 4
很抱歉,暂时无法提供与“MM5Z3V0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24640
- 200+0.08206
- 1500+0.05137
- 3000+0.04070
- 国内价格
- 10+0.06880
- 50+0.06364
- 200+0.05934
- 600+0.05504
- 1500+0.05160
- 3000+0.04945
- 国内价格
- 20+0.18160
- 100+0.11290
- 800+0.07460
- 3000+0.05320
- 6000+0.05060
- 30000+0.04680
- 国内价格
- 50+0.10152
- 500+0.07798
- 3000+0.06470
- 6000+0.05681
- 24000+0.05001
- 51000+0.04634
