MBR0540
MBR0540
    CBI(创基)
    SOD-123
    表面贴装肖特基势垒二极管
MBR0540 数据手册
Surface Mount Schottky Barrier Diode Features PINNING • Low forward voltage PIN • High conductance DESCRIPTION 1 Cathode 2 Anode 2 1 SQ Top View Marking Code: "SQ" Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25 C) O Parameter Symbol Value Unit VRRM 40 V VR 40 V Average Rectified Forward Current IF(AV) 500 mA Non-Repetitive Peak Forward Surge Current (Half Wave, Single Phase, 60 Hz) IFSM 5.5 A Thermal Resistance Junction to Lead 1) RθJL 118 O RθJA 206 O Tj - 65 to + 150 O Tstg - 65 to + 150 O Symbol Max. Peak Repetitive Reverse Voltage Reverse Voltage Thermal Resistance Junction to Ambient 2) Operating Junction Temperature Range Storage Temperature Range C/W C/W C C 1) Device mounted on FR-4 PCB 0.013 mm. 2) 1 inch" pad size (1 X 0.5 inch for each lead ) on FR4 board. Characteristics at Ta = 25 C O Parameter Forward Voltage at IF = 0.5 A at IF = 1 A at IF = 0.5 A, Ta = 100 OC at IF = 1 A, Ta = 100 OC VF Reverse Current at VR = 20 V at VR = 40 V at VR = 20 V, Ta = 100 OC at VR = 40 V, Ta = 100 OC IR 0.51 0.62 0.46 0.61 10 20 5 13 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. Unit V µA µA mA mA 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
MBR0540 价格&库存
很抱歉,暂时无法提供与“MBR0540”相匹配的价格&库存,您可以联系我们找货
MBR0540
    • 10+0.08480
    • 50+0.07844
    • 200+0.07314
    • 600+0.06784
    • 1500+0.06360
    • 3000+0.06095
