1N5408
1N5408
    ST(先科)
    DO-27(DO-201AA)
    整流二极管 VRRM=1KV If=3A VF=1.1V CJ=50pF DO201AD
1N5408 数据手册
1N5400 THRU 1N5408 GENERAL PURPOSE PLASTIC SILICON RECTIFIER Reverse Voltage – 50 to 1000 V Forward Current – 3 A Features  High current capability  Low leakage current Mechanical Data  Case: Molded plastic, DO-201AD  Terminals: Plated axial leads, solderable per MIL-STD-202, method 208 guaranteed  Polarity: Color band denotes cathode end  Mounting position: Any Absolute Maximum Ratings and Characteristics Ratings at 25 OC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols 1N 5400 Marking 1N540 1N540 1N540 1N540 1N540 1N540 1N540 1N540 1N540 0 1 2 3 4 5 6 7 8 Parameter 1N 5401 1N 5402 1N 5403 1N 5404 1N 5405 1N 5406 1N 5407 1N 5408 Units - Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 300 400 500 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 210 280 350 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 300 400 500 600 800 1000 V Maximum Average Forward Rectified Current 0.375"(9.5 mm) Lead Length at TA = 75 OC Peak Forward Surge Current, 8.3 ms Single Half-sine-wave Superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3 A DC Maximum Reverse Current TA = 25 OC at Rated DC Blocking Voltage TA = 100 C Typical Junction Capacitance 1) Typical Thermal Resistance 2) Operating Junction Temperature Range Storage Temperature Range 1) 2) O I(AV) 3 A IFSM 200 A VF 1.1 V 5 IR µA 1000 CJ 50 pF RθJA 18 TJ -55 to +150 O C TStg -55 to +150 O C O C/W Measured at 1 MHz and applied reverse voltage of 4 VDC. Thermal resistance junction to ambient and juntion to lead at 0.375" (9.5 mm) lead length P.C.B mounted with 0.8 X 0.8" (20 X 20 mm) copper pads. ® 1/2 Dated: 06/05/2021 H&SS Rev: 01 1N5400 THRU 1N5408 ® 2/2 Dated: 06/05/2021 H&SS Rev: 01
1N5408
物料型号:1N5400至1N5408,这些是通用塑料硅整流二极管。
器件简介: - 反向电压:50至1000伏特 - 正向电流:3安培 - 特点:高电流能力、低漏电流
引脚分配: - 封装类型:DO-201AD - 引脚:镀层轴向引线,可按照MIL-STD-202标准方法208进行焊接 - 极性:色带表示阴极端
参数特性: - 最大重复峰值反向电压(VRRM):50至1000伏特 - 最大RMS电压(VRMS):35至700伏特 - 最大直流阻断电压(Voc):50至1000伏特 - 最大平均正向整流电流(I(AV)):在75°C时,0.375英寸(9.5毫米)引线长度下为3安培 - 峰值正向浪涌电流(IFSM):在额定负载上叠加8.3毫秒单半正弦波,为200安培 - 最大正向电压在3A直流下(VF):1.1伏特 - 在25°C时的最大反向电流(IR):在额定直流阻断电压下为5毫安至1000安培 - 典型结电容(CJ):50皮法拉 - 典型热阻(RBJA):18摄氏度/瓦 - 工作结温范围(TJ):-55至+150摄氏度 - 存储温度范围(Tstg):-55至+150摄氏度
功能详解: - 这些二极管适用于单相、半波、60赫兹、电阻性或感性负载。 - 对于电容性负载,需要将电流降低20%。
应用信息: - 这些整流二极管适用于需要高电流和低漏电流的应用。
封装信息: - 封装尺寸:1.0英寸(25.4毫米)长,0.052英寸(1.3毫米)直径最小,0.375英寸(9.5毫米)引线长度,35(8.5毫米)引线间距,220(5.6毫米)直径。
1N5408 价格&库存
很抱歉,暂时无法提供与“1N5408”相匹配的价格&库存,您可以联系我们找货
1N5408
  • 5+0.62749
库存:6
1N5408
  • 5+0.69153
  • 50+0.55934
  • 150+0.49324
库存:19
