PTLC05D-B
PTLC05D-B
    PTTC(聚鼎)
    SOD-323
    PTLC05D-B–ESD保护二极管
PTLC05D-B 数据手册
PTLC05D-B – ESD Protection Diode Feature  450 Watts peak pulse power (8/20s)  Bidirectional configurations  Protect one power line  Solid state silicon-avalanche technology  Low operating voltage  Low leakage current  Low Capacitance: 1.0 pF Typical  IEC61000-4-2 (ESD) ±30kV (Air), ±30kV (Contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Lightning): 22A (8/20s) Applications Mechanical Data  Ethernet - 10/100/1000 Base T  SOD323 package  Cellular Phones  Molding compound flammability rating: UL94 V-0  Handheld - Wireless Systems  Tape and Reel Packaging  Personal Digital Assistant (PDA)  RoHS/WEEE Compliant  USB Interface Schematic and PIN Configuration Maximum Rating Parameter Symbol IEC61000-4-2 ESD Voltage – Air Mode VESD(1) IEC61000-4-2 ESD Voltage – Contact Mode Limit ±30 ±30 Unit kV Peak Pulse Power PPP(2) 450 Peak Pulse Current IPP(2) 22 A TL 260 °C Junction Temperature TJ -55~150 °C  Storage Temperature Range Tstg -55~150 °C  Maximum Lead Solder Temperature (10 seconds duration) W Note: 1. 2. 3. Device stressed with ten non-repetitive ESD pulses. Non-repetitive current pulse 8/20s exponential decay waveform according to IEC61000-4-5. All ratings are measured at environmental temperature of TA = 25°C unless otherwise noted. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 4 2018/04/23 Rev: B PTLC05D-B – ESD Protection Diode Electrical Characteristics Parameter Reverse Stand-off Voltage Reverse Breakdown Voltage Reverse Leakage Current Clamping Voltage Junction Capacitance Symbol Test Conditions Min Typ V VBR Max 5.0 RWM(1) IT = 1mA 6.0 Unit V V A IR VRWM = 5V 1.0 VC(2) IPP = 22A 20 V 1.5 pF VR = 0V, f = 1MHz CJ 1.0 Note: 1. 2. 3. Other voltages available upon request. Non-repetitive current pulse 8/20s exponential decay waveform according to IEC61000-4-5. All ratings are measured at environmental temperature of TA = 25°C unless otherwise noted. Electrical Parameters Symbol Parameter VC Clamping Voltage @ IPP IPP Reverse Peak Pulse Current VBR Breakdown Voltage @ IT IT Test Current IR Reverse Leakage Current @ VRWM VRWM Working Peak Reverse Voltage 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 4 2018/04/23 Rev: B PTLC05D-B – ESD Protection Diode Typical Characteristics 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 4 2018/04/23 Rev: B PTLC05D-B – ESD Protection Diode SOD323 Package Outline Dimensions Symbol Dimensions (mm) Min Dimensions (inch) Max Min Max A 1.600 1.800 0.063 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 D 1.000 0.106 0.039 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L L1 H 0.475 Ref. 0.250 0.400 0.019 Ref. 0.010 0.100 0.016 0.004 Marking Packaging Information Order Code Packaging Reel Size PCS/Reel PTLC05D-B SOD323 7 inch 3,000 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 4 2018/04/23 Rev: B
PTLC05D-B 价格&库存
很抱歉,暂时无法提供与“PTLC05D-B”相匹配的价格&库存,您可以联系我们找货
