PTLC05R
PTLC05R
    PTTC(聚鼎)
    SOT-143
    PTLC05R–ESD保护二极管
PTLC05R 数据手册
PTLC05R – ESD Protection Diode Feature  100 Watts peak pulse power (8/20s)  Tiny SOT-143 Package  Unidirectional Configuration  Protect two I/O lines  Solid state silicon-avalanche technology  Low operating voltage: 5V  Low capacitance (CJ = 0.4 pF typ I/O to I/O)  IEC61000-4-2 (ESD) ±20kV (Air), ±15kV (Contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Lightning): 6A (8/20s) Applications Mechanical Data  USB2.0  JEDEC SOT-143 package  Ethernet  Molding compound flammability rating: UL94 V-0  Notebooks, Desktops and Servers  Tape and Reel Packaging  Video Line Protection  RoHS/WEEE Compliant Schematic and PIN Configuration Maximum Rating Parameter Symbol IEC61000-4-2 ESD Voltage – Air Mode VESD(1) IEC61000-4-2 ESD Voltage – Contact Mode Limit ±20 ±15 Unit kV Peak Pulse Power PPP(2) 100 Peak Pulse Current IPP(2) 6.0 A TL 260 °C Junction Temperature TJ -55~125 °C  Storage Temperature Range Tstg -55~125 °C  Maximum Lead Solder Temperature (10 seconds duration) W Note: 1. 2. 3. Device stressed with ten non-repetitive ESD pulses. Non-repetitive current pulse 8/20s exponential decay waveform according to IEC61000-4-5. All ratings are measured at environmental temperature of TA = 25°C unless otherwise noted. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 4 2017/08/17 Rev: A PTLC05R – ESD Protection Diode Electrical Characteristics Parameter Reverse Stand-off Voltage Symbol Test Conditions IT = 1mA Reverse Leakage Current IR VRWM = 5V Peak Pulse Current IPP Clamping Voltage Junction Capacitance Typ 5.0 V 6.0 6.8 8.5 V 50 500 nA V VBR Reverse Breakdown Voltage Min RWM(1) VC(2) CJ Max Unit 6.5 A IPP = 6A 14 16 V VR = 0V, f = 1MHz, I/O to I/O VR = 0V, f = 1MHz, I/O to GND 0.3 0.6 0.4 0.8 pF pF Note: 1. 2. 3. Other voltages available upon request. Non-repetitive current pulse 8/20s exponential decay waveform according to IEC61000-4-5. All ratings are measured at environmental temperature of TA = 25°C unless otherwise noted. Electrical Parameters Symbol Parameter VC Clamping Voltage @ IPP IPP Peak Pulse Current VBR Breakdown Voltage @ IT IT Test Current IR Reverse Leakage Current @ VRWM VRWM VF Reverse Stand-off Voltage Forward Voltage @ IF 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 4 2017/08/17 Rev: A PTLC05R – ESD Protection Diode Typical Characteristics 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 4 2017/08/17 Rev: A PTLC05R – ESD Protection Diode SOT-143 Package Outline Dimensions Symbol Dimensions (mm) Min Max A 0.900 1.150 A1 0.000 0.100 A2 0.900 1.050 b 0.300 0.500 b1 0.750 0.900 c 0.080 0.150 D 2.800 3.000 e 1.800 e1 2.000 0.200 TYP E 2.250 E1 1.200 L1 2.550 1.400 0.550 REF L 0.300 0.500  0° 8° Marking Packaging Information Order Code Packaging Reel Size PCS/Reel PTLC05R SOT-143 7 inch 3,000 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 4 2017/08/17 Rev: A
PTLC05R 价格&库存
很抱歉,暂时无法提供与“PTLC05R”相匹配的价格&库存,您可以联系我们找货
