SMF30CA
SMF30CA
    PTTC(聚鼎)
    SMF
    TVS二极管–SMF系列
SMF30CA 数据手册
T VS Diode – SMF Series Features          Plastic package, excellent insulation strength. Glass passivated chip junction in SOD-123 package. Excellent voltage clamping capability. Low Zener impedance. 200W peak pulse power capability on 10/1000s waveform. Typical leakage current less than 1A above 13V. Very fast response time, typically less than 1.0ps from 0 volt to VBR minimum. High temperature soldering guaranteed: 265°C/10 sec. MSL: JEDEC-J-STD-020, Level 1 Applications     I/O interface, VCC bus Telecom Industrial and consumer electronic applications. Relay and electromagnetic valve surge absorption. Agency Approval  Pending Mechanical and Physical Data   Case: JEDEC SMF molded plastic. Axial leaded, solderable per MIL-STD-750, Method 2026  Polarity: Color band denoted cathode except bidirectional. Maximum Ratings and Thermal Characteristics Symbol Value Unit Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Parameter PPPM Min 200 W Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). IPPM See Table A Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). IFSM 20 A TJ, TSTG -55~150 °C Operating Junction and Storage Temperature Range. Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code SMF □□□ C A VBR Voltage tolerance (A: 5%; Blank: 10%) C: Bi-directional; Blank: Uni-directional Reverse Stand-Off Voltage or Typical Breakdown Voltage SMF Series (200W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 6 2016/12/1 Rev: A T VS Diode – SMF Series I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (IT) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi SMF5.0A SMF5.0CA FE KE 5.0 6.40 7.00 10 9.2 21.74 400 Pending SMF6.0A SMF6.0CA FG KG 6.0 6.67 7.37 10 10.3 19.42 400 Pending SMF6.5A SMF6.5CA FK KK 6.5 7.22 7.98 10 11.2 17.86 250 Pending SMF7.0A SMF7.0CA FM KM 7.0 7.78 8.60 10 12.0 16.67 100 Pending SMF7.5A SMF7.5CA FP KP 7.5 8.33 9.21 1 12.9 15.50 50 Pending SMF8.0A SMF8.0CA FR KR 8.0 8.89 9.83 1 13.6 14.71 25 Pending SMF8.5A SMF8.5CA FT KT 8.5 9.44 10.40 1 14.4 13.89 10 Pending SMF9.0A SMF9.0CA FV KV 9.0 10.00 11.10 1 15.4 12.99 5.0 Pending SMF10A SMF10CA FX KX 10 11.10 12.30 1 17.0 11.76 2.5 Pending SMF11A SMF11CA FZ KZ 11 12.20 13.50 1 18.2 10.99 2.5 Pending SMF12A SMF12CA HE LE 12 13.30 14.70 1 19.9 10.05 2.5 Pending SMF13A SMF13CA HG LG 13 14.40 15.90 1 21.5 9.30 1 Pending SMF14A SMF14CA HK LK 14 15.60 17.20 1 23.2 8.62 1 Pending SMF15A SMF15CA HM LM 15 16.70 18.50 1 24.4 8.20 1 Pending SMF16A SMF16CA HP LP 16 17.80 19.70 1 26.0 7.69 1 Pending SMF17A SMF17CA HR LR 17 18.90 20.90 1 27.6 7.25 1 Pending SMF18A SMF18CA HT LT 18 20.00 22.10 1 29.2 6.85 1 Pending 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2016/12/1 Rev: A T VS Diode – SMF Series Part Number Marking Reverse Test Breakdown Voltage Stand Off Current VBR (V) @ IT Voltage VR IT Min. Max. (V) (mA) Maximum Clamping Voltage VC (V) @ IPP Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR (A) @ VR UL Uni Bi Uni Bi SMF19A SMF19CA HB LB 19 21.10 23.30 1 30.6 6.54 1 Pending SMF20A SMF20CA HV LV 20 22.20 24.50 1 32.4 6.17 1 Pending SMF22A SMF22CA HX LX 22 24.40 26.90 1 35.5 5.63 1 Pending SMF24A SMF24CA HZ LZ 24 26.70 29.50 1 38.9 5.14 1 Pending SMF26A SMF26CA JE ME 26 28.90 31.90 1 42.1 4.75 1 Pending SMF28A SMF28CA JG MG 28 31.10 34.40 1 45.4 4.41 1 Pending SMF30A SMF30CA JK MK 30 33.30 36.80 1 48.4 4.13 1 Pending SMF33A SMF33CA JM MM 33 36.70 40.60 1 53.3 3.75 1 Pending SMF36A SMF36CA JP MP 36 40.00 44.20 1 58.1 3.44 1 Pending SMF40A SMF40CA JR MR 40 44.40 49.10 1 64.5 3.10 1 Pending SMF43A SMF43CA JT MT 43 47.80 52.80 1 69.4 2.88 1 Pending SMF45A SMF45CA JV MV 45 50.00 55.30 1 72.7 2.75 1 Pending SMF48A SMF48CA JX MX 48 53.30 58.90 1 77.4 2.58 1 Pending SMF51A SMF51CA JZ MZ 51 56.70 62.70 1 82.4 2.43 1 Pending SMF54A SMF54CA XE NE 54 60.00 66.30 1 87.1 2.30 1 Pending SMF58A SMF58CA XG NG 58 64.40 71.20 1 93.6 2.14 1 Pending SMF60A SMF60CA XK NK 60 66.70 73.70 1 96.8 2.07 1 Pending SMF64A SMF64CA XM NM 64 71.10 78.60 1 103.0 1.94 1 Pending SMF70A SMF70CA XP NP 70 77.80 86.00 1 113.0 1.77 1 Pending SMF75A SMF75CA XR NR 75 83.30 92.10 1 121.0 1.65 1 Pending SMF78A SMF78CA XT NT 78 86.70 95.80 1 126.0 1.59 1 Pending SMF80A SMF80CA XB NB 80 88.80 97.60 1 129.0 1.55 1 Pending SMF85A SMF85CA XV NV 85 94.40 104.0 1 137.0 1.46 1 Pending SMF90A SMF90CA XX NX 90 100.0 111.0 1 146.0 1.37 1 Pending SMF100A SMF100CA XZ NZ 100 111.0 123.0 1 162.0 1.23 1 Pending SMF110A SMF110CA TE PE 110 122.0 135.0 1 177.0 1.13 1 Pending SMF120A SMF120CA TG PG 120 133.0 147.0 1 193.0 1.04 1 Pending SMF130A SMF130CA TK PK 130 144.0 159.0 1 209.0 0.96 1 Pending SMF140A SMF140CA TB PB 140 155.0 171.0 1 224.0 0.89 1 Pending SMF150A SMF150CA TM PM 150 167.0 185.0 1 243.0 0.82 1 Pending SMF160A SMF160CA TP PP 160 178.0 197.0 1 259.0 0.77 1 Pending SMF170A SMF170CA TR PR 170 189.0 209.0 1 275.0 0.73 1 Pending SMF180A SMF180CA TT PT 180 200.0 220.0 1 292.0 0.68 1 Pending SMF190A SMF190CA TV PV 190 211.0 232.0 1 308.0 0.65 1 Pending SMF200A SMF200CA TX PX 200 224.0 247.0 1 324.0 0.62 1 Pending SMF220A SMF220CA TZ PZ 220 246.0 272.0 1 356.0 0.56 1 Pending Note: 1. For bi-directional type having VR of 10 volts and less, the IR limit is double. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2016/12/1 Rev: A T VS Diode – SMF Series Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Uni-directional Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2016/12/1 Rev: A T VS Diode – SMF Series Marking Definitions Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Dimension A B C D E F G H Millimeters Inches Min Max Min Max 2.50 3.40 0.70 1.50 0.35 0.05 0.95 2.90 3.90 1.20 2.00 0.90 0.26 0.10 1.30 0.0984 0.1339 0.0275 0.0591 0.0138 0.0020 0.0374 0.1142 0.1535 0.0472 0.0787 0.0354 0.0102 0.0039 0.0512 Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) - Temperature Max (Ts_max) - Time (Ts_min to Ts_max) - Average Ramp-Up Rate 150ºC 200ºC 60-180 seconds 1~3ºC/second Peak Temperature 260ºC max. Time within 5ºC of actual Peak Temperature (tp) 40 seconds max. Ramp-Down Rate 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 6 2016/12/1 Rev: A T VS Diode – SMF Series Packaging Information Part Number Component Package Quantity SMF Series SOD-123 3000 Packaging Option Tape & Reel – 8mm tape/7” reel Packaging Specification EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 6 2016/12/1 Rev: A
SMF30CA 价格&库存
很抱歉,暂时无法提供与“SMF30CA”相匹配的价格&库存,您可以联系我们找货
