CLM1612P0815C
CLM1612P0815C
    PTTC(聚鼎)
    一次性保险丝(熔断) 8V 15A 1612
CLM1612P0815C 数据手册
CLM1612 15A C Series Device CLM1612 15A C Series Device Description Current Limiting Module (CLM) is a chip type surface mountable device that can protect against both overcurrent and overcharging. It comprises a fuse element to ensure stable operation under normal electrical current and to cut off the current when overcurrent occurs. It also comprises a resistive heating element that could be used in combination with a voltage detecting means, such as IC and FET. When overvoltage is detected, the heating element is electrically excited to generate heat to blow the fuse element to achieve overvoltage protection. Features  Halogen-free  Surface mountable  Overcharging protection  Fast response time  Overcurrent protection Application  Notebook  Tablet PC  Cell phone  Automotive applications  Camera  Printer  Ultrabook  Security systems Agency Approval and Environmental Compliance Agency File Number Regulation   E331807 Standard IEC 61249-2-21:2003 TA 50359102 Electrical Specifications Part Number Irated Cells in (A) series Vmax (VDC) Ibreak (A) VOP (V) Resistance Rheater (Ω) Rfuse (mΩ) Agency Approval CLM1612P0415C 15 1 36 50 3.0 ~ 4.5 0.6 ~ 1.5 1.0 ~ 3.0   CLM1612P0815C 15 2 36 50 5.0 ~ 9.0 2.2 ~ 3.3 1.0 ~ 3.0   CLM1612P1215C 15 3 36 50 7.4 ~ 13.8 5.5 ~ 8.4 1.0 ~ 3.0   CLM1612P1415C 15 4 36 50 10.5 ~ 19.6 10.4 ~ 15.8 1.0 ~ 3.0   CLM1612P2015C 15 5 36 50 14.4 ~ 23.5 17.9 ~ 29.1 1.0 ~ 3.0   新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 6 2016/12/12 Revision: A CLM1612 15A C Series Device Electrical Characteristics Current Capacity 100% x Irated No Melting 200% x Irated Cut Time < 1 min Interrupting Current 5 x Irated, power on 5 ms, power off 995 ms, 10000 cycles No Melting Note on Electrical Specifications & Characteristics  Vocabulary Irated = Current carrying capacity that is measured at 40oC thermal equilibrium condition. Ibreak = The current that the fuse element is able to interrupt. Vmax = The maximum voltage that can be cut off by fuse. Rheater = The resistance of the heating element. Rfuse = The resistance of the fuse element. Cells in series = Number of battery cells connected in series in the circuit for CLM device to protect.  Value specified is determined by using the PWB with 2mm*2oz copper traces, AWG18 covered wire, and 0.6mm glass epoxy PCB.  Specifications are subject to change without notice.  General  Before and after mounted, the ultrasonic-cleaning or immersion-cleaning must not be done to CLM device. The flux on element would flow, and it would not be satisfied its specification when cleaning is done. In addition, a similar influence happens when the product comes in contact with cleaning-solution. These products after cleaning will not be guaranteed.  Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of CLM devices, and shall not be used or applied.  Please Do Not reuse the CLM device removed by the soldering process.  CLM devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among others, incorrect pin-connection of a connector) or over-extensive trip events may occur.  Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the CLM devices.  The performance of CLM devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical procedures and/or conditions non-conformant to those recommended by manufacturer.  Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection to avoid or minimize damage that may result from extra-ordinary, irregular function or failure of CLM devices. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 6 2016/12/12 Revision: A CLM1612 15A C Series Device Thermal Derating Characteristics Ambient Temperature (ºC) 25 40 60 Recommend Rated Current (A) 18.0 16.0 13.5 Cut Time by Heater Operation  Various heater wattage at 25ºC ambient temperature.  Constant heater wattage at various ambient temperature. Cut Time by Current Operation  Various interrupting current at 25ºC ambient temperature.  Constant 2x rated current at various ambient temperature. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 6 2016/12/12 Revision: A CLM1612 15A C Series Device Device Circuit Environmental Specifications Operating/Storage Temperature Hot Passive Aging -10ºC to +65 ºC /
CLM1612P0815C 价格&库存
很抱歉,暂时无法提供与“CLM1612P0815C”相匹配的价格&库存,您可以联系我们找货
