P0640SC
P0640SC
    PTTC(聚鼎)
    SMB(DO-214AA)
    晶闸管浪涌抑制器(TSS)–S系列
P0640SC 数据手册
Thyristor Surge Suppressor (TSS) – S Series Description DO-214AA PXXXX S series solid state protection thyristor protect telecommunication equipments such as modem, line cards, fax machines and other CPE. PXXXX S series devices are used to enable equipment to meet various regulatory requirements including GR 1089, ITU K.20, K.21 and K.45, IEC 60950, UL 60950 and TIA-968 (formerly known as FCC Part 68) Electrical Parameters Compared to surge suppression using other technologies, PXXXX S series devices offer absolute surge protection regardless of the surge current available and the rate of applied voltage (dv/dt). P series devices: ⚫ Cannot be damaged by voltage ⚫ Eliminate hysteresis and heat dissipation typically found with clamping devices. ⚫ Eliminate voltage overshoot caused by fast-rising transients ⚫ Are non-degenerative. ⚫ Will not fatigue ⚫ Have low capacitance, making them ideal for high-speed transmission equipment. Thermal Considerations ⚫ ⚫ ⚫ TJ – Operating Junction Temperature Range: -40~150°C TS – Storage Temperature Range: -40~150°C RƟJA – Thermal Resistance: Junction to Ambient: 90°C/W Part Number Code P □□□□ S □ IPP Rating (A: 45A; B: 80A; C: 100A) S: DO-214AA/SMB Package Typical Breakdown Voltage TSS Product Symbol I-V Curve Characteristics CO Off-state Capacitance — typical capacitance measured in off state. IS Switching Current — maximum current required to switch to on state IDRM Leakage Current — maximum peak off-state current measured at VDRM IH Holding Current — minimum current required to maintain on state IPP Peak Pulse Current — maximum rated peak impulse current IT On-state Current — maximum rated continuous on-state current ITSM Peak One-cycle Surge Current — maximum rated one-cycle AC current VS Switching Voltage — maximum voltage prior to switching to on state during 100 V/μs surge VDRM Peak Off-state Voltage — maximum voltage that can be applied while maintaining off state VT On-state Voltage — maximum voltage measured at rated on-state current 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 5 2018/10/12 Rev: D Thyristor Surge Suppressor (TSS) – S Series Electrical Characteristics Part Number Marking VDRM (V) VS (V) IDRM (μA) IS (mA) IH (mA) IT (A) VT (V) C0 (pF) (Min.) (Max.) (Max.) (Max.) (Min.) (Max.) (Max.) (Typ.) P0080SA 008A 6 25 5 800 50 2.2 4 45 P0300SA 03A 25 40 5 800 50 2.2 4 45 P0640SA 06A 58 77 5 800 150 2.2 4 35 P0720SA 07A 65 88 5 800 150 2.2 4 50 P0900SA 09A 75 98 5 800 150 2.2 4 40 P1100SA 11A 90 130 5 800 150 2.2 4 35 P1300SA 13A 120 160 5 800 150 2.2 4 35 P1500SA 15A 140 180 5 800 150 2.2 4 40 P1800SA 18A 170 220 5 800 150 2.2 4 40 P2000SA 20A 180 240 5 800 150 2.2 4 40 P2300SA 23A 190 260 5 800 150 2.2 4 45 P2600SA 26A 220 300 5 800 150 2.2 4 35 P3100SA 31A 275 350 5 800 150 2.2 4 35 P3500SA 35A 320 400 5 800 150 2.2 4 30 P4000SA 40A 360 460 5 800 150 2.2 4 20 P4500SA 45A 400 540 5 800 150 2.2 4 20 P5000SA 50A 440 600 5 800 150 2.2 4 20 P0080SB 008B 6 25 5 800 50 2.2 4 60 P0300SB 03B 25 40 5 800 50 2.2 4 65 P0640SB 06B 58 77 5 800 150 2.2 4 45 P0720SB 07B 65 88 5 800 150 2.2 4 45 P0900SB 09B 75 98 5 800 150 2.2 4 40 P1100SB 11B 90 130 5 800 150 2.2 4 40 P1300SB 13B 120 160 5 800 150 2.2 4 40 P1500SB 15B 140 180 5 800 150 2.2 4 35 P1800SB 18B 170 220 5 800 150 2.2 4 65 P2000SB 20B 180 240 5 800 150 2.2 4 60 P2300SB 23B 190 260 5 800 150 2.2 4 60 P2600SB 26B 220 300 5 800 150 2.2 4 45 P3100SB 31B 275 350 5 800 150 2.2 4 45 P3500SB 35B 320 400 5 800 150 2.2 4 40 P4000SB 40B 360 460 5 800 150 2.2 4 40 P4500SB 45B 400 540 5 800 150 2.2 4 40 P5000SB 50B 440 600 5 800 150 2.2 4 40 P0080SC 008C 6 25 5 800 50 2.2 4 75 P0300SC 03C 25 40 5 800 50 2.2 4 75 P0640SC 06C 58 77 5 800 150 2.2 4 55 P0720SC 07C 65 88 5 800 150 2.2 4 60 P0900SC 09C 75 98 5 800 150 2.2 4 65 P1100SC 11C 90 130 5 800 150 2.2 4 55 P1300SC 13C 120 160 5 800 150 2.2 4 90 P1500SC 15C 140 180 5 800 150 2.2 4 50 P1800SC 18C 170 220 5 800 150 2.2 4 55 P2000SC 20C 180 240 5 800 150 2.2 4 85 P2300SC 23C 190 260 5 800 150 2.2 4 65 P2600SC 26C 220 300 5 800 150 2.2 4 65 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 5 2018/10/12 Rev: D Thyristor Surge Suppressor (TSS) – S Series VDRM (V) VS (V) IDRM (μA) IS (mA) IH (mA) IT (A) VT (V) C0 (pF) (Min.) (Max.) (Max.) (Max.) (Min.) (Max.) (Max.) (Typ.) 275 350 5 800 150 2.2 4 55 35C 320 400 5 800 150 2.2 4 50 P4000SC 40C 360 460 5 800 150 2.2 4 45 P4200SC 42C 400 500 5 800 150 2.2 4 45 P4500SC 45C 400 540 5 800 150 2.2 4 45 P5000SC 50C 440 600 5 800 150 2.2 4 45 Part Number Marking P3100SC 31C P3500SC Notes:  All measurements are made at an ambient temperature of 25℃. IPP applies to -40℃ through +85℃ temperature range.  Off-state capacitance (C0) is measured at 1MHz with a 2V bias and is typical value. Surge Ratings IPP (A) ITSM 60 Hz di/dt Series 2/101 2/102 (Min.) 1.2/501 8/202 (Min.) 10/1601 10/1602 (Min.) 10/5601 10/5602 (Min.) 10/7001 5/3202 (Min.) 10/10001 10/10002 (Min.) A 150 150 90 50 75 45 20 500 B 250 250 150 100 100 80 30 500 C 500 400 200 150 200 100 50 500 (A) (Min.) (A/μs) (Typ.) Notes:  1. Voltage waveform in μs.  2. Current waveform in μs. Fig 1. tr * td Pulse Waveform 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 5 2018/10/12 Rev: D Thyristor Surge Suppressor (TSS) – S Series Ratings and Characteristic Curves Normalized DC Holding Current vs. Case Temp Normalized VS Change vs. Junction Temperature Marking Definitions PolyTrans Trade mark Product ID Code Lot No Physical Dimensions Dimension A B C D E F G H I J K L Millimeters Inches Min Max Min Max 1.90 4.06 3.30 1.95 0.76 5.21 0.15 2.26 2.16 2.16 2.20 4.85 3.94 2.44 1.52 0.20 5.59 0.31 2.74 - 0.077 0.160 0.130 0.084 0.030 0.205 0.006 0.089 0.085 0.085 0.086 0.191 0.155 0.096 0.060 0.008 0.220 0.012 0.107 - 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 5 2018/10/12 Rev: D Thyristor Surge Suppressor (TSS) – S Series Lead Free Wave Soldering Recommendations Preheat - Temperature Min (Tsmin) - Temperature Max (Tsmax) - Time (Tsmin to Tsmax) - Average Ramp-Up Rate 150ºC 200ºC 60-180 seconds 1~3ºC/second Peak Temperature 260ºC max. Time within 5ºC of actual Peak Temperature (tp) 40 seconds max. Ramp-Down Rate 6 ºC /second max. Note: If the wave soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. Packaging Part Number Component Package Quantity PXXXX S Series DO-214AA 2500 Packaging Specification Tape & Reel – 12mm tape/13” reel Standard EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 5 2018/10/12 Rev: D
P0640SC 价格&库存
很抱歉,暂时无法提供与“P0640SC”相匹配的价格&库存,您可以联系我们找货
