SMD0603P150SLR
SMD0603P150SLR
    PTTC(聚鼎)
    SMD SLR系列表面贴装PTC器件
SMD0603P150SLR 数据手册
SMD SLR Series Surface Mount PTC Devices SMD SLR Series Surface Mount PTC Devices Description The SLR series utilizes new conductive filler to achieve super low resistance and maintain thin device profile. This series is available from 0402 to 1210 size with current rating of 0.10A to 7.50A, and is suitable for applications where space or height is at a premium and resettable protection is desired. Features y Super low resistance y Halogen-free y High current rating at lower profile y Compact design saves board space y RoHS compliant and lead-free Applications y Battery PCM y Mobile phones and PDAs y Mobile Internet Device (MID) y USB peripherals Agency Approval and Environmental Compliance Agency File Number Regulation Standard E201431  2011/65/EU R50099121  IEC 61249-2-21:2003 Electrical Characteristics Part Number Ihold (A) Itrip (A) Vmax (Vdc) Imax (A) Pd typ (W) SMD0402P010SLR 0.10 0.30 6 40 0.5 SMD0402P020SLR 0.20 0.50 6 40 SMD0402P035SLR 0.35 0.70 6 40 SMD0402P050SLR 0.50 1.00 6 40 0.5 SMD0603P075SLR 0.75 1.50 6 50 0.6 SMD0603P100SLR 1.00 1.80 6 50 SMD0603P150SLR 1.50 3.00 6 50 SMD0603P175SLR 1.75 3.50 6 SMD0805P200SLRT 2.00 4.00 6 SMD0805P260SLRT 2.60 5.20 SMD0805P300SLRT 3.00 6.00 SMD1206P350SLRT 3.50 SMD1206P400SLR 4.00 SMD1206P450SLR 4.50 9.00 SMD1206P500SLR 5.00 10.00 6 SMD1210P550SLR 5.50 11.00 6 SMD1210P600SLR 6.00 12.00 6 SMD1210P650SLR 6.50 13.00 6 SMD1210P700SLR 7.00 14.00 6 SMD1210P750SLR 7.50 15.00 6 Maximum Time To Trip Current Time (A) (Sec.) Resistance Agency Approval Rmin () R1max () 0.150 2.000 3 3 0.50 1.00 0.5 1.00 1.00 0.100 1.250 3 3 0.5 8.00 0.10 0.050 0.700 3 3 8.00 0.10 0.040 0.400 3 3 8.00 0.20 0.040 0.165 3 3 0.6 8.00 0.30 0.040 0.120 3 3 0.6 8.00 0.50 0.007 0.080 3 3 50 0.6 8.00 0.60 0.005 0.060 3 3 50 0.6 8.00 1.00 0.005 0.045 3 3 6 50 0.6 8.00 4.00 0.003 0.035 3 3 6 50 0.6 8.00 5.00 0.003 0.030 3 3 7.00 6 50 0.8 8.00 5.00 0.003 0.018 3 3 8.00 6 50 0.8 20.00 2.00 0.001 0.016 3 3 6 50 0.8 22.50 2.00 0.001 0.014 3 3 50 1.0 25.00 2.00 0.001 0.012 3 3 50 1.2 27.50 2.00 0.001 0.011 3 3 50 1.2 30.00 2.00 0.001 0.010 3 3 50 1.2 32.50 2.00 0.001 0.009 3 3 50 1.2 35.00 2.00 0.001 0.008 3 3 50 1.2 37.50 2.00 0.001 0.007 3 3  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Note on Electrical Characteristics „ Vocabulary Ihold = Hold current: maximum current device will pass without tripping in 23ºC still air. Itrip = Trip current: minimum current at which the device will trip in 23 ºC still air. Vmax = Maximum voltage device can withstand without damage at rated current (I max) Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) Pd typ = Typical power dissipated from device when in the tripped state at 23 ºC still air. Rmin = Minimum resistance of device in initial (un-soldered) state. R1max = Maximum resistance of device at 23 ºC measured one hour after tripping or reflow soldering of 260 ºC for 20 sec. „ Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. „ Specifications are subject to change without notice. Polymeric PTC Selecting Guide „ Determine the following operating parameters for the circuits: y Normal operating current (Ihold) Ɂ Maximum interrupt current (Imax) y Maximum circuit voltage (Vmax) Ɂ Normal operating temperature surrounding device (minºC/maxºC) y Surface Mount Device (SMD) Ɂ Axial Leaded Device (ALD) y Radial Leaded Device (RLD) Ɂ DISC Device !! !! „ Select the device form factor and dimension suitable for the application: !! Ɂ Other Customized Form Factors !! !! „ Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure the circuit’s requirement does not exceed the device rating. „ Check that PPTC device’s trip time (time-to-trip) will protect the circuit. „ Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range. „ Verify the performance and suitability of the chosen PPTC device in the application. „ Mechanical Stress y PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied. „ Chemical Pollutants y Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices, and shall not be used or applied. „ Electronic and Thermal Effect y PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among others, incorrect pin-connection of a connector) or over-extensive trip events may occur. y PTTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open circuit, in which case the voltage at such PPTC devices may reach a hazardous level. y Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the PPTC devices. y Conductive material contamination, such as metal particle, may induce shortage, flame or arcing. y Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices, which shall not be used under such circumstances. „ General y Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual applications will be met. y The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical procedures and/or conditions non-conformant to those recommended by manufacturer. y Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection to avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices. y Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with. y Polytronics shall not be liable for any claims or damages arising out of products used in automotive applications, unless otherwise agreed by Polytronics.  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Thermal Derating Curve Percentage of Rated Current 200.00 150.00 100.00 50.00 0.00 -40.00 0.00 40.00 80.00 120.00 Device Ambient Temperature (ɗ ) Thermal Derating Chart Recommended Hold Current (A) at Ambient Temperature (ºC) Ambient Operation Temperature Part Number -40 ºC -20 ºC 0 ºC 23 ºC 40 ºC 50 ºC 60 ºC 70 ºC 85 ºC SMD0402P010SLR 0.14 0.13 0.11 0.10 0.09 0.08 0.07 0.06 0.05 SMD0402P020SLR 0.29 0.26 0.23 0.20 0.18 0.16 0.15 0.13 0.09 SMD0402P035SLR 0.50 0.45 0.40 0.35 0.31 0.28 0.26 0.22 0.16 SMD0402P050SLR 0.71 0.64 0.57 0.50 0.44 0.40 0.37 0.31 0.23 SMD0603P075SLR 1.23 1.08 0.94 0.75 0.61 0.53 0.45 0.36 0.23 SMD0603P100SLR 1.35 1.25 1.10 1.00 0.82 0.74 0.65 0.52 0.35 SMD0603P150SLR 2.40 2.10 1.80 1.50 1.25 1.10 0.95 0.80 0.50 SMD0603P175SLR 2.50 2.25 2.00 1.75 1.55 1.40 1.30 1.10 0.80 SMD0805P200SLRT 3.10 2.75 2.40 2.00 1.65 1.40 1.15 0.95 0.65 SMD0805P260SLRT 3.80 3.30 2.90 2.60 2.20 1.95 1.75 1.50 1.05 SMD0805P300SLRT 4.35 3.80 3.40 3.00 2.50 2.25 2.00 1.70 1.20 SMD1206P350SLRT 5.50 4.85 4.15 3.50 2.85 2.55 2.25 1.90 1.40 SMD1206P400SLR 5.75 5.25 4.65 4.00 3.40 3.05 2.75 2.40 1.65 SMD1206P450SLR 6.50 5.95 5.25 4.50 3.85 3.45 3.10 2.70 1.90 SMD1206P500SLR 7.20 6.60 5.80 5.00 4.25 3.80 3.40 3.00 2.10 SMD1210P550SLR 7.75 6.90 6.25 5.50 4.65 4.15 3.60 3.00 2.30 SMD1210P600SLR 8.45 7.55 6.80 6.00 5.10 4.55 3.95 3.35 2.50 SMD1210P650SLR 9.15 8.15 7.40 6.50 5.50 4.90 4.25 3.60 2.70 SMD1210P700SLR 9.85 8.80 7.95 7.00 5.95 5.30 4.60 3.90 2.90 SMD1210P750SLR 10.25 9.15 8.45 7.50 6.75 6.15 5.55 4.70 3.65  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Soldering Parameters Profile Feature Average Ramp-Up Rate (Tsmax to TP) Preheat -Temperature Min (Tsmin) -Temperature Max (Tsmax) -Time (Tsmin to Tsmax) Time maintained above: -Temperature (TL) -Time (tL) Peak Temperature (TP) Time within 5ºC of actual Peak Temperature (tP) Ramp-Down Rate Time 25ºC to Peak Temperature Storage Condition Pb-Free Assembly 3ºC/second max. 150ºC 200ºC 60-180 seconds 217ºC 60-150 seconds 260ºC 20-40 seconds 6 ºC /second max. 8 minutes max. 0ºC ~35ºC, ʀ70%RH y Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free y Recommended maximum paste thickness is 0.25mm (0.010 inch) y Devices can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Physical Dimensions (mm.) P : Polytronics/ Polystar Logo Part identification Figure 2 Part Number A B C D E Min. Max. Min. Max. Min. Max. Min. Max. Min. Max. SMD0402P010SLR 0.85 1.15 0.35 0.65 0.20 0.60 0.10 0.45 -- 0.40 SMD0402P020SLR 0.85 1.15 0.35 0.65 0.20 0.60 0.10 0.45 -- 0.40 SMD0402P035SLR 0.85 1.15 0.35 0.65 0.20 0.60 0.10 0.45 -- 0.40 SMD0402P050SLR 0.85 1.15 0.35 0.65 0.20 0.60 0.10 0.45 -- 0.40 SMD0603P075SLR 1.40 1.80 0.60 1.00 0.40 0.75 0.15 0.50 -- 0.40 SMD0603P100SLR 1.40 1.80 0.60 1.00 0.40 0.75 0.15 0.50 -- 0.40 SMD0603P150SLR 1.40 1.80 0.60 1.00 0.40 1.00 0.15 0.50 -- 0.40 SMD0603P175SLR 1.40 1.80 0.60 1.00 0.40 1.00 0.15 0.50 -- 0.40 SMD0805P200SLRT 2.00 2.20 1.20 1.50 0.40 0.75 0.20 0.55 0.05 0.45 SMD0805P260SLRT 2.00 2.20 1.20 1.50 0.40 0.75 0.20 0.55 0.05 0.45 SMD0805P300SLRT 2.00 2.20 1.20 1.50 0.40 0.75 0.20 0.55 0.05 0.45 SMD1206P350SLRT 3.00 3.40 1.50 1.80 0.40 0.75 0.25 0.75 0.05 0.45 SMD1206P400SLR 3.00 3.40 1.50 1.80 0.60 1.00 0.25 0.75 0.05 0.45 SMD1206P450SLR 3.00 3.40 1.50 1.80 0.60 1.00 0.25 0.75 0.05 0.45 SMD1206P500SLR 3.00 3.40 1.50 1.80 0.60 1.00 0.25 0.75 0.05 0.45 SMD1210P550SLR 3.00 3.43 2.35 2.80 0.60 1.00 0.25 0.75 0.10 0.50 SMD1210P600SLR 3.00 3.43 2.35 2.80 0.60 1.00 0.25 0.75 0.10 0.50 SMD1210P650SLR 3.00 3.43 2.35 2.80 0.60 1.00 0.25 0.75 0.10 0.50 SMD1210P700SLR 3.00 3.43 2.35 2.80 0.60 1.00 0.25 0.75 0.10 0.50 SMD1210P750SLR 3.00 3.43 2.35 2.80 0.60 1.00 0.25 0.75 0.10 0.50  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Environmental Specifications Operating Temperature -40ºC to +85 ºC Maximum Device Surface Temperature in Tripped State 125ºC Thermal Shock MIL-STD-202 Method 107G +85ºC /-40ºC 20 times -30% typical resistance change Solvent Resistance MIL-STD-202, Method 215 No change Vibration MIL-STD-883C, Method 2007.1, Condition A No change Moisture Sensitivity Level Level 1, J-STD-020C  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 7 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Packaging Quantity and Marking Recommended Pad Layout (mm.) C A B B A Solder Pad B SMD0402P010SLR 10000 0.70 0.60 0.40 SMD0402P020SLR 10000 0.70 0.60 0.40 SMD0402P035SLR 10000 0.70 0.60 0.40 Part Number Marking SMD0402P050SLR Quantity C 10000 0.70 0.60 0.40 SMD0603P075SLR N 4000 1.00 1.00 0.80 SMD0603P100SLR S 4000 1.00 1.00 0.80 SMD0603P150SLR T 4000 1.00 1.00 0.80 SMD0603P175SLR V 4000 1.00 1.00 0.80 SMD0805P200SLRT L 4000 1.50 1.00 1.20 SMD0805P260SLRT U 4000 1.50 1.00 1.20 SMD0805P300SLRT X 4000 1.50 1.00 1.20 SMD1206P350SLRT LC 4000 1.80 1.00 1.80 SMD1206P400SLR LE 3000 1.80 1.00 1.80 SMD1206P450SLR LF 3000 1.80 1.00 1.80 SMD1206P500SLR LK 3000 1.80 1.00 1.80 SMD1210P550SLR LF 3000 2.50 1.00 2.00 SMD1210P600SLR LL 3000 2.50 1.00 2.00 SMD1210P650SLR LJ 3000 2.50 1.00 2.00 SMD1210P700SLR LN 3000 2.50 1.00 2.00 SMD1210P750SLR LS 3000 2.50 1.00 2.00 ˖ġ 8 mm tape on 7 inch reel per EIA-481 (equivalent to IEC286, part 3) Physical Specifications Terminal Material Solder-Plated Copper (Solder Material: Matte Tin (Sn)) Lead Solderability Meets EIA Specification RS186-9E, ANSI/J-STD-002 Category 3.  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 8 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Tape Specifications: EIA-481 (mm.) 0402 0603 0805 1206 1210 P010SLR P075SLR P150SLR P200SLRT P300SLRT P400SLR P550SLR P020SLR P100SLR P175SLR P260SLRT P350SLRT P450SLR P600SLR P500SLR P650SLR P035SLR P300SLRT P050SLR P700SLR P750SLR W F E1 D0 D1 P0 P1 P2 A0 B0 T K0 8.00 ± 0.10 8.00 ± 0.30 8.00 ± 0.30 8.00 ± 0.10 8.20 +0.10/-0.30 8.15 +0.15/-0.30 8.00 ± 0.30 3.50 ± 0.05 3.50 ± 0.05 3.50 ± 0.05 3.50 ± 0.05 3.50 ± 0.05 3.50 ± 0.05 3.50 ± 0.05 1.75 ± 0.05 1.75 ± 0.10 1.75 ± 0.10 1.75 ± 0.10 1.75 ± 0.10 1.75 ± 0.10 1.75 ± 0.10 1.55 ± 0.05 1.55 ± 0.05 1.55 ± 0.05 1.55 ± 0.05 1.55 ± 0.05 1.55 ± 0.05 1.55 ± 0.05 ʈ 0.50 ± 0.10 0.50 ± 0.10 1.00 (min) 1.00 ± 0.10 1.00 ± 0.10 1.00 (min) 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.08 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 2.00 ± 0.05 2.00 ± 0.05 2.00 ± 0.05 2.00 ± 0.05 2.00 ± 0.05 2.00 ± 0.05 0.69 ± 0.03 1.10 ± 0.10 1.10 ± 0.10 1.60 ± 0.10 1.95 ± 0.10 1.92 ± 0.10 2.82 ± 0.10 1.23 ± 0.03 1.92 ± 0.10 1.92 ± 0.10 2.30 ± 0.10 3.65 ± 0.10 3.65 ± 0.10 3.50 ± 0.10 ʈ 0.20 ± 0.10 0.20 ± 0.10 0.25 ± 0.10 0.20 ± 0.10 0.25 ± 0.10 0.20 ± 0.10 0.60 ± 0.03 0.72 ± 0.10 0.96 ± 0.10 0.90 ± 0.10 0.87 ± 0.10 1.30 ± 0.10 1.30 ± 0.10 Leader min. 390 390 390 390 390 390 390 Trailer min. 160 160 160 160 160 160 160 Reel Dimensions: EIA-481 (mm.) C D H W Ø178 ± 1.0 Ø60.2 ± 0.5 11.0 ± 0.5 9.0 ± 1.5  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 9 of 10 2017/04/24 Revision: C SMD SLR Series Surface Mount PTC Devices Part Number System SMD 1206 P  SLR T / Special Voltage Rating (Optional) Thickness Version (Optional) Super Low Resistance Holding Current Rating Polytronics Symbol Device Dimensions: Length/Width (Unit: 1/100 inch) Surface Mount Device Cross Reference Polytronics / EVERFUSE® Cross Reference TE Connectivity / PolySwitch® Bourns / Multifuse® SMD0402P010SLR -- -- SMD0402P020SLR -- -- SMD0402P035SLR -- -- SMD0402P050SLR -- -- SMD0603P075SLR -- -- SMD0603P100SLR -- -- SMD0603P150SLR -- -- SMD0603P175SLR -- -- SMD0805P200SLRT -- -- SMD0805P260SLRT -- -- SMD0805P300SLRT -- -- SMD1206P350SLRT nanoSMD350LR MF-NSML350 SMD1206P400SLR -- MF-NSML400 SMD1206P450SLR -- -- SMD1206P500SLR NanoSMD500LR -- SMD1210P550SLR -- -- SMD1210P600SLR -- -- SMD1210P650SLR -- -- SMD1210P700SLR -- -- SMD1210P750SLR -- -- “EVERFUSE” is a registered trademark of Polytronics Technology Corp. “Multifuse” is a registered trademark of Bourns, Inc. “PolySwitch” is a registered trademark of TE Connectivity Ltd.  㖗䫠ⷩ䦸⭟ⷌ㥔⛹⌧ⷌ㥔㝘⛂巖 24-1 噆 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 10 of 10 2017/04/24 Revision: C
SMD0603P150SLR 价格&库存
很抱歉,暂时无法提供与“SMD0603P150SLR”相匹配的价格&库存,您可以联系我们找货
