山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
MM1Z2V0BW THRU MM1Z75BW
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 500mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±2%
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
▪Case: SOD-123W
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪ Approx. Weight:16mg/0.00056oz
Simplified outline SOD-123W and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
500
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
340
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
(1)
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
T A , Temperature (°C)
2019.08
150
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
SOD-123W-W-MM1Z2V0BW~MM1Z75BW-500mW
Page 1 of 3
山东晶导微电子股份有限公司
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
MM1Z2V0BW
4A
1.96
2
2.04
5
100
120
0.5
MM1Z2V2BW
4B
2.16
2.2
2.24
5
100
120
0.7
MM1Z2V4BW
4C
2.35
2.4
2.45
5
100
120
1
MM1Z2V7BW
4D
2.65
2.7
2.75
5
110
120
1
MM1Z3V0BW
4E
2.94
3
3.06
5
120
50
1
MM1Z3V3BW
4F
3.23
3.3
3.37
5
130
MM1Z3V6BW
4H
3.53
3.6
3.67
5
130
10
1
MM1Z3V9BW
4J
3.82
3.9
3.98
5
130
5
1
MM1Z4V3BW
4K
4.21
4.3
4.39
5
130
5
1
4.7
4.79
MM1Z4V7BW
4M
4.61
5
130
2
1
MM1Z5V1BW
4N
5
5.1
5.20
5
130
2
1.5
MM1Z5V6BW
4P
5.49
5.6
5.71
5
80
1
2.5
MM1Z6V2BW
4R
6.08
6.2
6.32
5
50
1
3
MM1Z6V8BW
4X
6.66
6.8
6.94
5
30
0.5
3.5
MM1Z7V5BW
4Y
7.35
7.5
7.65
5
30
0.5
4
MM1Z8V2BW
4Z
8.04
8.2
8.36
5
30
0.5
5
MM1Z9V1BW
5A
8.92
9.1
9.28
5
30
0.5
6
MM1Z10BW
5B
9.8
10
10.2
5
30
0.1
7
MM1Z11BW
5C
10.78
11
11.22
5
30
0.1
8
11.76
12
12.24
5
35
0.1
9
0.1
10
0.1
11
MM1Z12BW
5D
MM1Z13BW
5E
12.74
13
13.26
5
35
MM1Z15BW
5F
14.7
15
15.3
5
40
MM1Z16BW
5H
15.68
16
16.32
5
40
0.1
12
MM1Z18BW
5J
17.64
18
18.36
5
45
0.1
13
MM1Z20BW
5K
19.6
5
50
0.1
15
MM1Z22BW
5M
21.56
22
22.44
5
55
0.1
17
MM1Z24BW
5N
23.52
24
24.48
5
60
0.1
19
MM1Z27BW
5P
26.46
27
27.54
5
70
0.1
21
MM1Z30BW
5R
29.4
30
30.6
5
80
0.1
23
MM1Z33BW
5X
32.34
33
33.66
5
80
0.1
25
35.28
36
36.72
5
90
0.1
27
2.5
100
MM1Z36BW
5Y
MM1Z39BW
5Z
38.22
39
39.78
2
30
MM1Z43BW
6A
42.14
43
43.86
2.5
130
2
33
MM1Z47BW
6B
46.06
47
47.94
2.5
150
2
36
MM1Z51BW
6C
49.98
51
52.02
2.5
180
1
39
MM1Z56BW
6D
54.88
56
57.12
2.5
180
1
43
MM1Z62BW
6E
60.76
62
63.24
2.5
200
0.2
47
MM1Z68BW
6F
66.64
68
69.36
2.5
250
0.2
52
MM1Z75BW
6H
73.5
75
76.5
2.5
300
0.2
57
(1) V ZT is tested with pulses (20 ms)
2019.08
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123W
A
D
b
E
A1
C
∠ALL ROUND
L1
E1
SOD-123W mechanical data
A
C
D
E
E1
L1
b
A1
max
1.3
0.22
1.8
2.8
3.9
0.45
0.7
0.2
min
0.9
0.09
1.5
2.5
3.6
0.25
0.5
max
51
8.7
71
110
154
18
28
min
35
3.5
59
98
142
10
UNIT
mm
9°
8
mil
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2019.08
Page 3 of 3
很抱歉,暂时无法提供与“MM1Z5V1BW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11880
- 500+0.09256
- 3000+0.07798
- 国内价格
- 20+0.17180
- 100+0.10680
- 800+0.07050
- 3000+0.05040
- 6000+0.04780
- 30000+0.04430
- 国内价格
- 50+0.10890
- 600+0.08484
- 1200+0.08357
- 3000+0.07148
