山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
MM1Z2V0W THRU MM1Z75W
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 500mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±5%
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
▪Case: SOD-123W
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪ Approx. Weight:16mg/0.00056oz
Simplified outline SOD-123W and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
500
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
340
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
(1)
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
T A , Temperature (°C)
2019.08
150
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
SOD-123W-W-MM1Z2V0W~MM1Z75W-500mW
Page 1 of 3
山东晶导微电子股份有限公司
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
MM1Z2V0W
4A
1.8
2.0
2.15
5
100
120
0.5
MM1Z2V2W
4B
2.08
2.2
2.33
5
100
120
0.7
MM1Z2V4W
4C
2.28
2.4
2.56
5
100
120
1
MM1Z2V7W
4D
2.5
2.7
2.9
5
110
120
1
MM1Z3V0W
4E
2.8
3.0
3.2
5
120
50
1
MM1Z3V3W
4F
3.1
3.3
3.5
5
130
MM1Z3V6W
4H
3.4
3.6
3.8
5
130
10
1
MM1Z3V9W
4J
3.7
3.9
4.1
5
130
5
1
MM1Z4V3W
4K
4
4.3
4.6
5
130
5
1
4.7
5
MM1Z4V7W
4M
4.4
5
130
2
1
MM1Z5V1W
4N
4.8
5.1
5.4
5
130
2
1.5
MM1Z5V6W
4P
5.2
5.6
6
5
80
1
2.5
MM1Z6V2W
4R
5.8
6.2
6.6
5
50
1
3
MM1Z6V8W
4X
6.4
6.8
7.2
5
30
0.5
3.5
MM1Z7V5W
4Y
7
7.5
7.9
5
30
0.5
4
MM1Z8V2W
4Z
7.7
8.2
8.7
5
30
0.5
5
MM1Z9V1W
5A
8.5
9.1
9.6
5
30
0.5
6
MM1Z10W
5B
9.4
10
10.6
5
30
0.1
7
MM1Z11W
5C
10.4
11
11.6
5
30
0.1
8
MM1Z12W
5D
11.4
12
12.7
5
35
0.1
9
MM1Z13W
5E
12.4
13
14.1
5
35
0.1
10
MM1Z15W
5F
13.8
15
15.6
5
40
0.1
11
MM1Z16W
5H
15.3
16
17.1
5
40
0.1
12
MM1Z18W
5J
16.8
18
19.1
5
45
0.1
13
MM1Z20W
5K
18.8
5
50
0.1
15
MM1Z22W
5M
20.8
22
23.3
5
55
0.1
17
MM1Z24W
5N
22.8
24
25.6
5
60
0.1
19
MM1Z27W
5P
25.1
27
28.9
5
70
0.1
21
MM1Z30W
5R
28
30
32
5
80
0.1
23
MM1Z33W
5X
31
33
35
5
80
0.1
25
90
0.1
27
MM1Z36W
5Y
34
36
38
5
MM1Z39W
5Z
37
39
41
2.5
100
2
30
MM1Z43W
6A
40
43
46
2.5
130
2
33
MM1Z47W
6B
44
47
50
2.5
150
2
36
MM1Z51W
6C
48
51
54
2.5
180
1
39
MM1Z56W
6D
52
56
60
2.5
180
1
43
MM1Z62W
6E
58
62
66
2.5
200
0.2
47
MM1Z68W
6F
64
68
72
2.5
250
0.2
52
MM1Z75W
6H
70
75
79
2.5
300
0.2
57
(1) V ZT is tested with pulses (20 ms)
2019.08
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123W
A
D
b
E
A1
C
∠ALL ROUND
L1
E1
SOD-123W mechanical data
A
C
D
E
E1
L1
b
A1
max
1.3
0.22
1.8
2.8
3.9
0.45
0.7
0.2
min
0.9
0.09
1.5
2.5
3.6
0.25
0.5
max
51
8.7
71
110
154
18
28
min
35
3.5
59
98
142
10
UNIT
mm
9°
8
mil
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2019.08
Page 3 of 3
很抱歉,暂时无法提供与“MM1Z56W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08732
- 600+0.06881
- 1200+0.06778
- 3000+0.05495
- 国内价格
- 20+0.13260
- 100+0.08250
- 800+0.05440
- 3000+0.03890
- 6000+0.03690
- 30000+0.03420
- 国内价格
- 50+0.09526
- 500+0.07506
- 3000+0.05994
