1N4148W
Surface Mount Switching Diode
SOD-123
0.022(0.55)
Typ. Min.
Features
0.053(1.35)
Max.
Fast Switching Speed
Surface Mount Package Ideally Suited for
Automatic Insertion
For General Purpose Switching Applications
High Conductance
0.152(3.85)
0.140(3.55)
0.112(2.85)
0.100(2.55)
0.010(0.25)
Min.
Mechanical Data
Case: SOD-123, Molded Plastic
Polarity: Cathode Band
Marking: Date Code only or Date Code and
Type Code
0.067(1.70)
0.055(1.40)
0.006(0.15)
Typ. Min.
0.004(0.10)
Max.
Type Code: T4
Dimensions in inches and (millimeters)
Weight: 0.01 grams (approx.)
Maximum Ratings and Electrical Characteristics
Rating at 25oC ambient temperature unless otherwise specified.
Maximum Ratings
Type Number
Symbol
1N4148W
Unit
VRM
100
V
VRRM
VRWM
VR
75
V
Non-Repetitive Peak Reverse Voltage
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VR(RMS)
53
V
Forward Continuous Current (Note 1)
IFM
300
mA
Average Rectified Output Current (Note 1)
IO
150
mA
IFSM
2.0
1.0
A
RMS Reverse Voltage
Non-Repetitive Peak Forward Surge Current @ t = 1.0ms
@ t = 1.0s
Pd
350
mW
RqJA
357
K/W
Tj , TSTG
-65 to +150
°C
Power Dissipation (Note 1)
Thermal Resistance Junction to Ambient Air (Note 1)
Operating and Storage Temperature Range
Type Number
Symbol
Min
Max
Unit
Test Condition
Maximum Forward Voltage
VFM
¾
0.715
0.855
1.0
1.25
V
Maximum Peak Reverse Current
IRM
¾
2.5
50
30
25
mA
mA
mA
nA
IF = 1.0mA
IF = 10mA
IF = 50mA
IF = 150mA
VR = 75V
VR = 75V, Tj = 150°C
VR = 25V, Tj = 150°C
VR = 20V
Junction Capacitance
Cj
¾
2.0
pF
VR = 0, f = 1.0MHz
Reverse Recovery Time
trr
¾
4.0
ns
IF = IR = 10mA,
Irr = 0.1 x IR, RL = 100W
Notes:
1. Valid provided that terminals are kept at ambient temperature.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
1N4148W
PD, POWER DISSIPATION (mW)
500
400
300
200
100
75
100
125
150
TA, AMBIENT TEMPERATURE (°C)
Fig. 1 Power Derating Curve
10,000
IR, LEAKAGE CURRENT (nA)
50
IF, INSTANTANEOUS FORWARD CURRENT (mA)
1000
100
10
1.0
0.1
0.01
2
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 2 Forward Characteristics
1000
100
10
VR = 20V
1
200
Tj, JUNCTION TEMPERATURE (°C)
Fig. 3 Leakage Current vs Junction Temperature
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“1N4148W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07118
- 600+0.05514
- 1200+0.05431
- 3000+0.04504
- 国内价格
- 1+0.25630
- 200+0.08536
- 1500+0.05335
- 3000+0.04235
- 国内价格
- 50+0.07766
- 500+0.06016
- 3000+0.04914
- 6000+0.04331
- 24000+0.03824
- 51000+0.03554
