BZT52B12
BZT52B12
    LGE(鲁光)
    SOD-123
    ±2% 23Ω Single 11.8V~12.2V 500mW 12V SOD-123 Zener Diodes ROHS
BZT52B12 数据手册
BZT52B2V4-BZT52B51 Surface Mount Zener Diodes SOD-123 0.022(0.55) Typ. Min. 0.053(1.35) Max. Features — Wide zener voltage range selection:2.4V to 51V . — VZ Tolerance selection of ±2%(B series). — Ideally suited for automated assembly processes. — Moisture sensitivity level 1. 0.152(3.85) 0.140(3.55) 0.112(2.85) 0.100(2.55) 0.010(0.25) Min. 0.067(1.70) 0.055(1.40) 0.006(0.15) Typ. Min. 0.004(0.10) Max. Applications — — Dimensions in inches and (millimeters) Zener diode. Ultra-small surface mount package. Ordering Information Type No. BZT52B2V4-BZT52B51 Marking Package Code See table 2 SOD-123 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Characteristic Symbol Value Unit VF 0.9 V Power Dissipation Pd 500 mW Thermal resistance, junction to ambient air RθjA 305 ℃/W Junction temperature Tj 150 ℃ Storage temperature range Tstg -65 to+150 ℃ Forward Voltage @ IF=10mA Notes: These ratings are limiting values above which the serviceability of the diodes may be impaired. Revision:20181025-P1 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com BZT52B2V4-BZT52B51 Surface Mount Zener Diodes ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Type Number Marking Code VZ@IZT Maximum Reverse Current Maximum Zener Impedance Zener Voltage Range IZT ZZT@IZT IZK ZZK@IZK IR @VR Nom(V) Min(V) Max(V) mA Ω mA Ω μA V BZT52B2V4 2WX 2.4 2.35 2.45 5 94 1 564 45 1 BZT52B2V7 2W1 2.7 2.65 2.75 5 94 1 564 18 1 BZT52B3V0 2W2 3.0 2.94 3.06 5 89 1 564 9 1 BZT52B3V3 2W3 3.3 3.23 3.37 5 89 1 564 4.5 1 BZT52B3V6 2W4 3.6 3.53 3.67 5 84 1 564 4.5 1 BZT52B3V9 2W5 3.9 3.82 3.98 5 84 1 564 2.7 1 BZT52B4V3 2W6 4.3 4.21 4.39 5 84 1 564 2.7 1 BZT52B4V7 2W7 4.7 4.61 4.79 5 75 1 564 2.7 2 BZT52B5V1 2W8 5.1 5.00 5.20 5 56 1 470 1.8 2 BZT52B5V6 2W9 5.6 5.49 5.71 5 37 1 451 0.9 2 BZT52B6V2 2WA 6.2 6.08 6.32 5 9 1 376 2.7 4 BZT52B6V8 2WB 6.8 6.66 6.94 5 14 1 141 1.8 4 BZT52B7V5 2WC 7.5 7.35 7.65 5 14 1 75 0.9 5 BZT52B8V2 2WD 8.2 8.04 8.36 5 14 1 75 0.63 5 BZT52B9V1 2WE 9.1 8.92 9.28 5 14 1 94 0.45 6 BZT52B10 2WF 10 9.80 10.20 5 18 1 141 0.18 7 BZT52B11 2WG 11 10.78 11.22 5 18 1 141 0.09 8 BZT52B12 2WH 12 11.76 12.24 5 23 1 141 0.09 8 BZT52B13 2WI 13 12.74 13.26 5 28 1 160 0.09 8 BZT52B15 2WJ 15 14.70 15.30 5 28 1 188 0.045 10.5 BZT52B16 2WK 16 15.68 16.32 5 37 1 188 0.045 11.2 BZT52B18 2WL 18 17.64 18.36 5 42 1 212 0.045 12.6 BZT52B20 2WM 20 19.60 20.40 5 51 1 212 0.045 14.0 BZT52B22 2WN 22 21.56 22.44 5 51 1 235 0.045 15.4 BZT52B24 2WO 24 23.52 24.48 5 65 1 235 0.045 16.8 BZT52B27 2WP 27 26.46 27.54 5 75 0.5 282 0.045 18.9 BZT52B30 2WQ 30 29.40 30.60 5 75 0.5 282 0.045 21.0 BZT52B33 2WR 33 32.34 33.66 5 75 0.5 306 0.045 23.0 BZT52B36 2WS 36 35.28 36.72 5 84 0.5 329 0.045 25.2 BZT52B39 2WT 39 38.22 39.78 5 122 0.5 329 0.045 27.3 BZT52B43 2WU 43 42.14 43.86 5 141 0.5 353 0.045 30.1 BZT52B47 2WV 47 46.06 47.94 5 160 0.5 353 0.045 33.0 BZT52B51 2WW 51 49.98 52.02 5 169 0.5 376 0.045 35.7 Notes: 1. The zener voltage (VZ) is tested under pulse condition of 10ms. 2. The device numbers listed have a standard tolerance on the nominal zener voltage oI±2%. 3. The zener impedance is derived from the 60-cycle ac voltage,which results when an ac current having an rms value equal to 10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK. Revision:20181025-P2 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com BZT52B2V4-BZT52B51 Surface Mount Zener Diodes TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Revision:20181025-P3 PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // www.lgesemi .c o m mail:lge@lgesemi.com
BZT52B12 价格&库存
很抱歉,暂时无法提供与“BZT52B12”相匹配的价格&库存,您可以联系我们找货
BZT52B12
  • 20+0.14680
  • 200+0.11770
库存:388
BZT52B12
  • 1+0.39930
  • 200+0.13310
  • 1500+0.08316
  • 3000+0.06600
库存:4303
