ESD05D6BU
ESD05D6BU
    MDD(辰达半导体)
    DFN0603-2
    Bi PD=100W VRWM=5V VBR=6V VC=25V IPP=4A IR=0.1uA CJ=0.25PF 个人消费电子、智能家居、监控门禁、车载电子
ESD05D6BU 数据手册
ESD05D6BU Ultra Low Capacitance ESD Protection Diode DFN0603 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION ESD05D6BU is a low-capacitance transient voltage Suppressor (TVS) desingned to provide electrostatic events discharge (ESD) protection for high-speed data interfaces.With typical capacitance of 0.25pF, ESD05D6BU is designed to protect parasitic-sensitive systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device model (CDM) ESD and cable discharge event (CDE), etc. ESD05D6BU uses ultra-small DFN0603 package. Each ESD05D6BU device can protect one highspeed data line. It offers system designers flexibility to protect single data line where space is a premium concem.The combined features of low capacitance, ultra-small size and high ESD robustness make ESD05D6BU ideal for high-speed data port and high-frequency line applications, such as cellular phones and HD visual devices. Features  Peak Power Dissipation :100 W (8/20μs)  IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns) Cable Discharge Event (CDE)  Package optimized for high-speed lines  Protects one data, control line  Working voltages : 5V  Low Capacitance: 0.25pF (Typical)  Low leakage current  Low clamping voltage Applications        Serial ATA Desktops, Servers and Notebooks Cellular Phones MDDI Ports USB Data Line Protection Display Ports Digital Visual Interfaces (DVI) Pin Configuration Circuit Diagram Mechanical Characteristics  Package: DFN0603  Flammability Rating: UL 94V-0  Terminals: Gold plated, solderable per MIL-STD-750, method 2026  Packaging: Tape and Reel  Marking: 5BU Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit VESD ± 30 ± 20 KV Peak Pulse Power(8/20us ) PPP 100 W Operating Temperature TOPT −55 to +125 °C Storage Temperature TSTG −55 to +150 °C ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) The above data are for reference only. DN:T20402A0 http://www.microdiode.com Rev:2020A0 Page :1 ESD05D6BU Ultra Low Capacitance ESD Protection Diode Electrical Characteristics (TA=25°C unless otherwise specified) Symbol bol Param Test Condition Min Typ Max Units 5.0 V VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IT = 1mA IR Reverse Leakage Current VRWM = 5V 100 nA IPP = 1A, tp = 8/20μs 13 V IPP = 4A, tp = 8/20μs 25 V VC Clamping Voltage CJ Junction Capacitance VR = 0V, f = 1MHz 6.0 V 0.25 pF The above data are for reference only. http://www.microdiode.com Rev:2020A0 Page :2 ESD05D6BU Ultra Low Capacitance ESD Protection Diode ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :3 ESD05D6BU Ultra Low Capacitance ESD Protection Diode Outlitne Drawing DFN0603 Package Outline Dimensions Symbol A D E b c e L1 L2 Dimensions In Millimeters Min. Max. 0.275 5 340 0.570 0 670 0.270 0 370 0.225 5 295 0.050 REF. 0.365 5 435 0.125 5 195 0.030 REF. Dimensions In Inches Min. Max. 0.011 0.013 0.022 0.026 0.011 0.015 0.009 0.012 0.002 REF. 0.014 0.017 0.005 0.008 0.001 REF. Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size DFN0603 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 10,000 210×210×205 100,000 445×445×230 400,000 7' http://www.microdiode.com Rev:2020A0 Page :4
ESD05D6BU 价格&库存
很抱歉,暂时无法提供与“ESD05D6BU”相匹配的价格&库存,您可以联系我们找货
ESD05D6BU
  • 1+0.14619
  • 10+0.12598
  • 30+0.11468
  • 100+0.10794
  • 500+0.10213
  • 1000+0.09891
库存:14195
ESD05D6BU
  • 5+0.15779
  • 20+0.14309
  • 100+0.12839
  • 500+0.11369
  • 1000+0.10683
  • 2000+0.10193
库存:1332
