MMSZ5221B THRU MMSZ5260B
Zener Voltage - 2.4 to 43 Volts
Peak Pulse Power - - 0.5 W
SURFACE MOUNT ZENER DIODE
Features
SOD-123
Total power dissipation: Max. 1W.
Wide zener reverse voltage range 2.4V to 43V.
Small plastic package suitable for surface mounted design.
Tolerance approximately ±5%
0.008(0.20)max.
Cathode bar
0.071(1.80)
0.028(0.70)
0.020(0.50)
0.059(1.50)
0.110(2.80)
0.098(2.50)
0.154 (3.90)
Mechanical Data
ORDERING INFORMATION
Type No.
MMSZ5221B-MMSZ5260B
MAXIMUM RATING
0.019 (0.475) ref.
0.080 (0.0031)
0° to
0.010 (0.25)
0.150 (0.0059)
8°
0.008 (0.2 )
0.018 (0.45)
Dimensions in inches and (millimeters)
Marking
Package Code
See table 2
SOD-123
@ Ta=25℃ unless otherwise specified
Characteristic
Forward Voltage
1.250 (0.049)
Case : JEDEC SOD-123 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00056 ounce, 0.016 grams
1.050 (0.041)
0.142 (3.60)
Symbol
@ IF=10mA
Value
Unit
VF
0.9
V
Power Dissipation
Pd
500
mW
Thermal resistance,junction to ambient air
RθjA
350
℃/W
Junction temperature
Tj
150
Storage temperature range
Tstg
-65-150
Notes: 1. Device mounted on ceramic PCB; 7.6 mm x 9.4 mm x 0.87 mm with pad areas 25 mm2.
2. Tested with pulses, Tp ≤1.0ms.
http://www.microdiode.com
Rev:2024A1
Page :1
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Type
Type
Number
Code
Zener Voltage Range
Vz@IZT
Test
Maximum Zener
Maximum Reverse
Current
Impedance
Leakage Current
IZT
Nom(V)
Min(V)
Max(V)
mA
ZZT@IZT
ZZK@IZK=0.25mA
Ω
IR
@VR
μA
V
MMSZ5221B
C1
2.4
2.28
2.52
1200
100
1.0
MMSZ5223B
C3
2.7
2.57
2.84
1300
75
1.0
MMSZ5225B
C5
3.0
2.85
3.15
1600
50
1.0
MMSZ5226B
G1
3.3
3.14
3.47
1600
25
1.0
MMSZ5227B
G2
3.6
3.42
3.78
1700
15
1.0
MMSZ5228B
G3
3.9
3.71
4.10
1900
10
1.0
MMSZ5229B
G4
4.3
4.09
4.52
2000
5.0
1.0
MMSZ5230B
G5
4.7
4.47
4.94
1900
5.0
2.0
MMSZ5231B
E1
5.1
4.85
5.36
1600
5.0
2.0
MMSZ5232B
E2
5.6
5.32
5.88
1600
5.0
3.0
MMSZ5233B
E3
6.0
5.70
6.30
1600
5.0
3.5
MMSZ5234B
E4
6.2
5.89
6.51
1000
5.0
4.0
MMSZ5235B
E5
6.8
6.46
7.14
750
3.0
5.0
MMSZ5236B
F1
7.5
7.13
7.88
500
3.0
6.0
MMSZ5237B
F2
8.2
7.79
8.61
500
3.0
6.5
MMSZ5238B
F3
8.7
8.27
9.14
600
3.0
6.5
MMSZ5239B
F4
9.1
8.65
9.56
600
3.0
7.0
MMSZ5240B
F5
10
9.50
10.50
600
3.0
8.0
MMSZ5241B
H1
11
10.45
11.55
600
2.0
8.4
MMSZ5242B
H2
12
11.40
12.60
600
1.0
9.1
MMSZ5243B
H3
13
12.35
13.65
9.5
13
600
0.5
9.9
MMSZ5245B
H5
15
14.25
15.75
8.5
16
600
0.1
11
MMSZ5246B
J1
16
15.20
16.80
7.8
17
600
0.1
12
MMSZ5248B
J3
18
17.10
18.90
7.0
21
600
0.1
14
MMSZ5250B
J5
21.00
6.2
25
600
0.1
15
MMSZ5251B
K1
22
20.90
23.10
5.6
29
600
0.1
17
MMSZ5252B
K2
24
22.80
25.20
5.2
33
600
0.1
18
MMSZ5254B
K4
27
25.65
28.35
5.0
41
600
0.1
21
MMSZ5255B
K5
28
26.60
29.40
4.5
44
600
0.1
21
MMSZ5256B
M1
30
28.50
31.5
4.2
49
600
0.1
23
MMSZ5257B
M2
33
31.35
34.65
3.8
58
700
0.1
25
MMSZ5258B
M3
36
34.20
37.80
3.4
70
700
0.1
27
MMSZ5259B
M4
39
37.05
40.95
3.2
80
800
0.1
30
MMSZ5260B
M5
43
40.85
45.15
3.0
93
900
0.1
33
Rev:2024A1
Page :2
Typical Characterisitics
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
The curve above is for reference only.
Rev:2024A1
Page :3
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-123
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
1.2
1.2
0.047
B
C
3.2
0.126
D
2.0
0.079
E
4.4
0.173
0.047
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“MMSZ5240B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.12410
- 100+0.09666
- 300+0.08144
- 3000+0.07226
- 6000+0.06437
- 9000+0.06016
- 国内价格
- 20+0.22670
- 100+0.13520
- 800+0.09460
- 3000+0.06760
- 6000+0.06430
- 30000+0.05950
