B0520WS THRU B0540WS
Reverse Voltage 20-40 Volts
Forward Current - 0.5 Ampere
SCHOTTKY BARRIER RECTIFIERS
Features
SOD-323
Low forward voltage drop
Guard ring construction for transient protection
High conductance
Also available in lead free version
0.008(0.20)max.
Cathode bar
0.055(1.40)
0.016(0.40)
0.0098(0.25)
0.047(1.20)
0.071(1.80)
0.063(1.40)
0.108 (2.75)
Absolute Maximum Ratings at 25 °C
0.010 (0.25)
0.019 (0.475) ref.
Dimensions in inches and (millimeters)
Symbols
B0520WS
B0530WS
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
14
21
28
V
Maximum DC Blocking Voltage
VDC
40
Average rectified output current
I0
0.5
A
Non-reptitive Peak Forward Surge Current at 8.3ms
I FSM
22
A
Typical Thermal Resistance (1)
RθJA
500
°C/W
Operating Temperature Range
Tj
-55 ~ +125
°C
Storage Temperature Range
Tstg
-55 ~ +150
°C
Parameter
0.0031(0.08)
0.0059 (0.15)
0.018 (0.45)
8°
0.008 (0.2 )
Case: JEDEC SOD-323 molded plastic body
Terminals: Plated leads solderable per MILSTD-750, Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.00019 ounce, 0.00548 grams
Marking: B0520WS:SD, B0530WS:SE, B0540WS:SF
0° to
0.043 (1.00)
Mechanical Data
0.032 (0.80)
0.100 (2.55)
B0540WS
Units
(1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
Characteristics at Ta= 25 °C
Parameter
at 0.1A
Maximum Forward Voltage at If
at 0.5A
Symbols
B0520WS
VF
0.33
0.39
0.36
0.45
0.51
at 1.0A
75
at 10V
Peak Reverse Current at VR
http://www.microdiode.com
at 15V
at 20V
at 30V
at40V
IR
250
B0530WS
75
100
500
B0540WS
Units
V
0.62
10
uA
Rev:2024A2
Page :1
Typical Characterisitics
Forward
1
Characteristics
Reverse
10000
Characteristics
Pulsed
Pulsed
Ta=100℃
a
T=
25
0.1
REVERSE CURRENT IR
00
=1
Ta
IF
FORWARD CURRENT
(uA)
(A)
1000
0.01
0.0
0.1
0.2
0.3
FORWARD VOLTAGE
0.4
VF
0.5
Ta=25℃
10
1
0.6
10
(V)
15
VR
REVERSE VOLTAGE
Capacitance Characteristics
1000
100
25
30
(V)
Power Derating Curve
250
Ta=25℃
(mW)
200
PD
300
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
100
30
10
10
REVERSE VOLTAGE
15
VR
(V)
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
The curve above is for reference only.
Rev:2024A2
Page :2
Packing information
P0
unit:mm
P1
d
Item
E
F
B
A
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-323
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.028
B
0.7
0.7
C
2.15
0.085
D
1.8
0.071
E
2.85
0.112
0.028
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“B0520WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.18302
- 100+0.14908
- 300+0.13022
- 3000+0.09754
- 6000+0.08769
- 9000+0.08234
- 国内价格
- 1+0.10500
- 100+0.09800
- 300+0.09100
- 500+0.08400
- 2000+0.08050
- 5000+0.07840
